Trade: Commercial door and window
Need Help On A Kitchen Hood
Im installing a new island hood, I have a single story with an 8' attic space. Can I duct to the existing vent about 10' away by by adding two 45's or does it have to be a straight shot out
Cabinetmaker
Re: Need Help On A Kitchen Hood
mark: not being smartas here but the manual should give you a maximum length for the vent run. Just remember any bend adds more than the physical length of the pc. For instance I believe a 6" elbow actually adds about 3' as far as the airflow knows. That said If you r using 6" or larger it sounds like you should be ok. I also think I would re pipe the whole run up to the existing roof vent, you may be able to "shorten" the run just by going 45 up and toward the vent then 45 to it.
Its all ball bearings
Trade: Tile
I agree, the blower motor will tell you what you can and cannot do. What does it say about your situation? I'd take skymaster's advice and see if you can just redo the vent if possible.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Mark, as long as you have a 100cfm intermittent or 25cfm continuous ventilation rate when you finish the installation you should be o.k. I do not know of any codes (IRC) that limit the length of a run for for a kitchen exhaust fan. The manufacture installation instructions should list information regarding how the length will affect the performance, if not you can always call the support number listed in the instructions. A clothes dryer duct does have a maximum of 25' run with a deduction of 2.5' for each 45 and 5' for each 90 not including the transition duct. You may also want to check your local codes to make sure there are not any local codes that are more stringent then the IRC codes. Remember though that manufacture installation instructions are allways the final say on how you do the install not the codes because the product is "engineered".
Trade: Commercial Loading Dock and Door Contractor
There are inline pumps available, but I am not sure if they meet code, or if they can be used as a booster.
http://www.fantech.net/kitchen.pdf |
| kitchen floor suggestions | Tom M | Flooring | 17 | 08-27-2010 03:37 PM |
| refacing cabinets-is it 'worth' it? | 72chevy4x4 | Kitchens & Baths | 16 | 08-05-2009 02:43 PM |
| Exhaust Fan Hood System Help... | Remco Air | HVAC | 1 | 06-27-2009 11:24 AM |
| Google Seminars For Success... | Ivinni | Marketing & Sales | 193 | 02-07-2009 08:22 PM |
| Venting large kitchen range hood | ChuckEA | HVAC | 5 | 01-12-2006 11:53 PM |
