Need Help Estimating A Remodel
Old 03-09-2006, 01:52 PM   #1
bellair's Avatar
adding a full kitchen in a finished basement. its about 200 sq. ft . puting down 250 sq. ft. of tile, riping up carpet in the area knocking down a closet wall runing all the utilities drain, water supply, gas, electrical,, 3 18 x 30 x 12 wall cabinets, sink base, 18" base, stove and range, 2 21" base, 2 24" base, and a 36 x 36 x 24 lasy susan base with countertops, all cabinents have to be assembaled first then installed. base trim and other trim, and sink and faucet. any help would be appreciated
thank you,
eric
bellair is offline
Old 03-09-2006, 03:51 PM   #2
Bob Kovacs's Avatar
Trade: Consultant
Re: Need Help Estimating A Remodel
And what is it that you were looking for help with? You don't actually expect anyone to tell you what the whole job is worth, do you?
Bob
Bob Kovacs is offline
Old 03-09-2006, 10:08 PM   #3
Teetorbilt's Avatar
I could "Bip" this at about $10K, then add from there as Bippy does.
Fixed are gas, elecs., plumbing, etc. From there on it's up to the HO. Depending on them, you could easily put in $130K (last in home pool hall).
Albert Einstein
Teetorbilt is offline
Estimating help Sparky General Discussion 16 04-10-2011 08:12 PM
Anyone Make Their Own Excell Spreadsheets for Estimating? TurnkeyConst Technology 1 03-17-2007 11:49 PM
Estimating programs Alkyd Painting & Finish Work 9 02-19-2006 07:01 PM
What is your way of estimating? saucedo80 Painting & Finish Work 7 11-05-2005 11:08 PM
Estimating Article Series hatchet Business 15 07-15-2004 12:47 PM
