Need Advice Installing An Entrance Door
Old 06-26-2007, 05:05 PM   #1
Pauly's Avatar
Unhappy
Hi folks,
Being a painter, I was a dummy and decided to venture off into a carpenter's world and replace an old garage entrance door (from the 50's) with a pre-hung door. Well.....as you can imagine, it wasn't so easy; the studs surrounding the door are off-vertical by about 1" and the door, even if it's pre-hung...is not stable. I have no clue how to go about tru-up the door, shim it, and bolt it in. There's a lot of space between the door and studs (oh between 1/2 and 1" - depending upon the location).
Is there anybody out there who coule provide a good no-hassle fool-proof process for going about solving the issue? (perhaps hire a carpenter?).
Any comments are most welcome.
Pauly
Pauly is offline
Old 06-26-2007, 06:41 PM   #2
Thom
thom's Avatar
Re: Need Advice Installing An Entrance Door
You got it exactly correct. Hire a carpenter.
Competence cannot be transferred over the internet.
thom is offline
Old 06-26-2007, 08:20 PM   #3
send_it_all's Avatar
if there is enough room in the rough opening to put the prehung in there plumb...do that..
Plumb up the hing side of the door...nail it in place and also run one long screw through one of the hinge screw holes in each hinge into the framing behind it. then close the door and shim the rest of the jamb until the gap is good all around and nail all of that into place.
send_it_all is offline
Old 08-11-2007, 12:28 PM   #4
BurellBuilt's Avatar
Send a message via AIM to BurellBuilt
Hire a carpenter and paint the door and trim when it is finished.
Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it’s profitable. - James Rouse-
BurellBuilt is offline
Need advice on fixing a stained door.... ProSide Specialty Coatings 5 07-01-2007 11:50 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
ADA Entrance door swing Luke's Dad Construction 5 01-01-2006 12:56 PM
Installing exterior door jdmtrim Finish Carpentry 5 12-31-2005 08:20 PM
