Moving A Heavy Wood Stove
Old 09-20-2008, 06:53 PM   #1
Capra aegagrus
Tinstaafl's Avatar
Other than a furniture dolly or 4-wheeled "low boy", does anyone have a slick way for one man to move a 350 lb stove into a house? One step upward involved at the entrance.
Tinstaafl is offline
Old 09-20-2008, 07:21 PM   #2
mdshunk's Avatar
Re: Moving A Heavy Wood Stove
Stair climbing dolly.
Labor Ready.
mdshunk is offline
Old 09-20-2008, 07:48 PM   #3
reveivl's Avatar
Trade: Renovations
Drill two holes in each of two 2x4's for the legs to sit in (not all the way through), then use pipe under the 2x's to roll it up planks and into the house. ABS plumbing pipe makes good cheap rollers.
reveivl is offline
Old 09-20-2008, 07:51 PM   #4
Home Serve's Avatar
Trade: siding windows soffit fascia
One bottle whiskey and one really cold night. Moved by myself but was 25 years ago. It wasn't a "slick" job but did get it done.
Use whiskey sparingly until stove in place. Protect ALL surfaces.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 09-20-2008, 08:38 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Labor Ready.
Uh... is that one suggestion, or two?
Thanks for that. I've used that technique quite a few times; just brain-blanked and forgot all about it this evening.
Coincidentally, that's the exact same (hic!) recipe I used 22 years ago. However, this one is for a customer, and I need to at least pretend to be halfway professional.
Normally I'd have a couple of extra guys to strongarm it, but that just isn't in the cards for this one.
Old 09-20-2008, 08:42 PM   #6
mickeyco's Avatar
Trade: Squirrel Handler
Moving straps and two guys, easy job.
mickeyco is offline
Old 09-20-2008, 08:53 PM   #7
Professional Instigator
rbsremodeling's Avatar
that's not real. The fridge is not really levitating I can see the straps from here.
He said one man move
rbsremodeling is offline
Old 09-20-2008, 09:26 PM   #8
mickeyco's Avatar
If he can't use a furniture dolly or 4-wheeled "low boy" or find an extra guy, I'm going to recommend magic then.
mickeyco is offline
Old 09-21-2008, 12:18 AM   #9
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
You could strap the stove to a square of ply wood . Then rent a hand truck for moving a frig and roll it in .350 is lite for a stove We moved 2 last week one was 650 the other was 750.
wellbuilthome is offline
Old 09-21-2008, 12:20 AM   #10
O.C.Inc.'s Avatar
Kinda off topic but I used to remodel grocery stores and move their safes all the time. We used ice to move them into their final place if it was tight. A half a bag of cubed ice will take a lot of weight as long as you can get the floor wet...
Pat
Union Carpenter/Super started my own shop.
O.C.Inc. is offline
Old 09-21-2008, 11:08 AM   #11
Capra aegagrus
Tinstaafl's Avatar
Yeah, this one's actually a pellet stove. I've wrestled my share of the big ones. But I'm not 25 any more--a fact that my back delights in reminding me when I forget, at least a couple of times a year.
Old 09-21-2008, 11:11 AM   #12
Capra aegagrus
Tinstaafl's Avatar
Neat! Not off topic at all, as far as I'm concerned. We can all use tips on moving heavy stuff and saving the back/fingers. Which in a broad sense, is what this thread is all about.
Old 09-21-2008, 11:35 AM   #13
mdshunk's Avatar
Where you at in Central PA anyhow?
mdshunk is offline
Old 09-21-2008, 12:25 PM   #14
Sean
SLSTech's Avatar
"Air Glider" supports 750 pounds with a ramp for the step - probably need 1 other person for safety's sake plus getting the glider under the stove
SLSTech is offline
Old 09-21-2008, 12:48 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Enola. Have truck, will travel.
Old 09-21-2008, 12:59 PM   #16
J-Peffer's Avatar
Trade: Roofing & Siding Contractor
350 is not even that much for 2 guys, comon!
I just had to move a 1940's electric 6 burner stove for a customer. Did it for free, but she gave me the roof and siding job on her house.
J-Peffer is offline
Old 09-21-2008, 01:01 PM   #17
JonM's Avatar
Have it delivered....
JonM is offline
Old 09-21-2008, 01:02 PM   #18
Capra aegagrus
Tinstaafl's Avatar
Originally Posted by SLSTech View Post
"Air Glider"
No doubt, but a tad high-tech and pricey for once in a blue moon use.
I'm looking more for ideas that use a little thought and materials at hand. For instance, my wife's dad, who wasn't a big man by any means, would have scoffed at Mickey's picture. He would loop a cargo strap around the bottom rear of a refrigerator, with the upper end across his forehead. Just bend over, and the entire load is on your legs--not your back.
In a different vein, an old man who used to live near me showed me how to uproot a huge oak tree with no power equipment. He fastened a come-along as high up on the tree as he could reach with an extension ladder, with the other end attached to the base of another large tree. Then for several weeks, he would go out every day or two and crank that come-along just one more click. Sure enough, one day I drove by and saw that tree lying on the ground, with the root ball up in the air.
Sometimes we let "Git 'er done!" outweigh good old patience and ingenuity.
Old 09-23-2008, 10:13 PM   #19
Newd Guy
remomarc's Avatar
Trade: remodeling, renovating, restoring
Bigger tires on the hand truck, ratchet straps one step at a time and a whole lotta back
remomarc is offline
Old 09-23-2008, 10:49 PM   #20
General Contractor
Snow Man's Avatar
Trade: Construction Management
1/4'' masonite across the floors.
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Alcove for Wood Stove Agolk2 Construction 0 09-02-2008 01:23 PM
Wall around a wood stove guyute65045 Carpentry 5 12-14-2007 03:06 AM
Moving heavy appliances nealglen37 Off Topic (Non Trade) 2 08-08-2007 11:50 AM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 11:47 AM
Wood stove and furnace exaust Glasshousebltr HVAC 1 10-24-2005 09:45 AM
