Mold? - Remodeling - Contractor Talk
Mold?
Old 11-02-2017, 11:19 AM   #1
Jrno1's Avatar
Rewards Points: 80
Mold?
In the northern part of Michigan tearing up there's drywall and insulation to have a local contractor spray foam insulation did some research on it and it's probably a better idea to sub this one out. But as far as the mold or is this mold?
Jrno1 is offline
Old 11-02-2017, 03:02 PM   #2
hdavis's Avatar
Rewards Points: 1,845
Re: Mold?
The black stuff looks like it is.
hdavis is offline
Jrno1 (11-02-2017)
Old 11-02-2017, 03:38 PM   #3
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
Great now what? Obviously get rid of all of it.
Jrno1 is offline
Old 11-02-2017, 03:58 PM   #4
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,592
Re: Mold?
Did you just answer your own question?
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 11-02-2017, 04:01 PM   #5
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Re: Mold?
Looks like it to me also. Have the customer call their insurance co. and check for coverage, and go from there! Nothing to play with, how much do ya have or seen?
Dave in Pa is offline
Old 11-02-2017, 04:57 PM   #6
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
That's about it I wouldn't have seen it at all but I had to skim coat the whole house they had paneling on every wall and removing it damaged the drywall because of the glue Nails Etc..
And then they came up with the idea to spray foam in the walls facing Lake Huron. So as I was removing it I've noticed it along the bottom foot for about 3 or 4 feet. I appreciate any information on what someone else might do. I would obviously remove it and Doucet real good with microban. Right to wait till it stops raining and peel back the siding on the exterior see if I can find anything else that may have made this happened. Also in the crawl space. Thanks again
Jrno1 is offline
Old 11-03-2017, 05:43 PM   #7
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
Re: Mold?
You should check with the owner of the property and with your insurance company as "The M word" can open up a major can of worms. To get a reality check, talk to your local realtor about it.
"Nobody is more inferior than those who insist on being equal" -Friedrich Nietzsche
Krok is offline
Old 11-03-2017, 05:49 PM   #8
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 462
Re: Mold?
What....Wait..What did you say??
Delta
I have an Edifice Complex.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
illbuildit.dd (11-03-2017), MarkJames (11-03-2017), ScipioAfricanus (11-03-2017)
Old 11-03-2017, 05:56 PM   #9
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,517
Re: Mold?
The last job I did that had mold on the backside like that (and some on the wall face), the house needed repointing in a major way. The brick had been painted so it covered a lot of sins.
MarkJames is online now
Old 11-03-2017, 07:04 PM   #10
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,062
Re: Mold?
Delta
My thoughts exactly
illbuildit.dd is offline
Old 11-03-2017, 07:33 PM   #11
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
Delta
Not understanding your humor
Jrno1 is offline
Old 11-03-2017, 07:34 PM   #12
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
Originally Posted by illbuildit.dd View Post
My thoughts exactly
You either?
Jrno1 is offline
Old 11-04-2017, 01:30 AM   #13
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,648
Re: Mold?
if you are ripping it out what else can you do... is it only the framing? is it any wear else..
cedarboarder is offline
Old 11-04-2017, 07:28 AM   #14
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
I'm hoping it is, its low and behind the baseboard heating unit. I guess I could crawl in the crawl space and see if there's anything out of the ordinary. That I guess microban the affected areas call it good. Thanks for your response.
Jrno1 is offline
Old 11-05-2017, 11:31 AM   #15
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
Yikes! When I get back up there I'm going to pull the siding back from the face of the house to see if there's any other issues. Thanks for your coming
Jrno1 is offline
Old 11-05-2017, 12:24 PM   #16
Talking Head
EthanB's Avatar
Rewards Points: 110
Re: Mold?
If there's any significant area of mold coverage(more than a foot or so) then I wouldn't touch it. Your insurance almost definitely doesn't cover you for mold remediation and that's probably stachybotrys chartarum which is the mold that everyone is scared of.
Even just demolishing the affected materials can cause the spores to spread and then you are potentially liable for any future mold issues or health problems. It's relatively easy to get it taken care of and can be devastatingly expensive if you do it yourself so I don't see the benefit of taking the risk.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Jrno1 (11-05-2017)
Old 11-05-2017, 01:11 PM   #17
Krok's Avatar
Rewards Points: 844
Re: Mold?
Isn't there some sort of form realtors have that states if anyone has ever had any knowledge of mold on the property? I think that's where the liability of "M word" goes backward to that homeowner and then that homeowner can dump it on a contractor(s) because nobody likes holding the party bag alone.
Krok is offline
Old 11-05-2017, 04:21 PM   #18
Big Shoe's Avatar
Rewards Points: 1,874
Re: Mold?
If it is just around windows only that is pretty common no big deal. If itís everywhere thatís another issue.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
Old 11-05-2017, 04:44 PM   #19
Jrno1's Avatar
Rewards Points: 80
Re: Mold?
I appreciate you! thank you very much For your reply
Jrno1 is offline
Old 11-05-2017, 06:47 PM   #20
Talking Head
EthanB's Avatar
Rewards Points: 110
Re: Mold?
Realtors really have nothing to do with it. Lawyers do. If there is an issue where the mold needs to be remediated(for whatever reason) or someone is suffering from health issues due to the mold, then the insurance company that is footing the bill for either of those situations is going to look for someone else to pay the tab. If you, as a professional service provider, have tampered with the area, knowing that there is mold present, then you are probably going to be involved in the lawsuit. Because it's unlikely that your insurance covers you for mold remediation, they will be going directly after your personal assets.
At least that's my understanding of the usual scenario. I have worked in this field before and had extensive conversations with litigation attorneys and various people within the insurance field but that doesn't mean I have it exactly right.
Planer.....
EthanB is offline
The truth about MOLD Lee752 New Member Introductions 5 04-01-2010 06:05 PM
