Mirror Glue - Page 2 - Remodeling - Contractor Talk
Mirror Glue
Old 01-20-2018, 02:51 PM   #21
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 114
Re: Mirror Glue
Originally Posted by Golden view View Post
On the mirror. Glued. I'll try changing the slope with a carefully set dovetail router bit. Otherwise, buying a new mirror. Cost is not a big deal, but it'll take a week or more to get it cut, delivered, glued back up, etc.
Why not just make another cleat and glue???
goneelkn is online now
Old 01-20-2018, 07:26 PM   #22
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,568
Re: Mirror Glue
Not sure I understand or you understand. The cleat glued to the mirror is sloped so it'll slide down and away from the wall. I don't want to permanently attach the mirror to the wall because A: it defeats the purpose of doing it this way and B: there's an AAV vent behind it.
Golden view is online now
Old 01-20-2018, 08:17 PM   #23
goneelkn's Avatar
Rewards Points: 114
Re: Mirror Glue
Leave that cleat on mirror. Make a new cleat for the mirror and glue it on the mirror lower(or higher if there is room) than the bad cleat. The wall cleat will have to be adjusted if it's in place already.
Old 01-20-2018, 08:32 PM   #24
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
Gotcha. Went through that idea already but it is still viable. Originally I glued a full picture frame on the mirror to give more gluing surface and perimeter spacer for the floating look. Paranoid about the glue breaking eventually and it crashing off the wall. I could glue the new cleat also to the old one, that would probably be sufficient.
Also it's a bit embarrassing to move the cleat on the wall. The wall is completely tiled. Extra holes in the tile.
The router trick should work, as long as I don't set the depth too deep
Old 01-20-2018, 08:37 PM   #25
goneelkn's Avatar
Rewards Points: 114
Re: Mirror Glue
Make sure to set up video cameras while your doing it. One on the work, and one for your expressions!!
Good luck
The Following User Says Thank You to goneelkn For This Useful Post:
Golden view (01-21-2018)
Old 01-21-2018, 09:04 AM   #26
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
Good luck
I thought about it. Failures are at least as fun to watch as successes.
goneelkn (01-21-2018)
Old 01-21-2018, 03:49 PM   #27
Stunt Carpenter's Avatar
Rewards Points: 1,122
Re: Mirror Glue
I know this is late to the discussion but you could have built your picture frame and had two of these of the bottom to hold then weight and then glued the mirror to the frame.
Stunt Carpenter is online now
Old 01-21-2018, 05:34 PM   #28
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
No problem and thanks. That's the normal way but we wanted floating with no visible clips. Plus this mirror has to be removable.
Old 01-21-2018, 05:45 PM   #29
rrk's Avatar
Rewards Points: 2,280
Re: Mirror Glue
They also make those without the front part that goes up
If you wanted to make the mirror removable all you had to do was not tighten the upper clips. Put the upper edge un the groove lift to clear lower lip and set in lower groove. The clips will lower and mirror is secure. To remove mirror lift up pull bottom out pull mirror down.
No silvering issue ever
rrk is online now
Old 01-21-2018, 06:00 PM   #30
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
That's typically how I do them.
Old 01-22-2018, 10:39 AM   #31
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Re: Mirror Glue
Went to hang the mirror today. Almost last thing for a major 4 room remodel with 1000 square feet of tile, $40k in cabinets, etc. I glued the damn french cleat on backwards! I belong in the wall of shame. Holy crap what an idiot.
sorry to hear that but....you made my morning!!!!
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 01-22-2018, 06:20 PM   #32
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
Fixed it with a dovetail bit. Easy enough. But the saga continues. The mirror has a huge curve in it. I presume from glueing it to this frame. We glued it on a surface that was flat within 1/16th, let it dry for 5 days, then moved it to the garage over the weekend where it's 40 or 45 degrees and now it has a 1" bow, even after warming up all day. Really weird.
Old 01-22-2018, 08:11 PM   #33
rrk's Avatar
Re: Mirror Glue
You could call it a learning curve
I would have happily smashed that mirror days ago and called my glass guy
Cay you imaging installing it like that and the homeowner asks "do I look fat ?"
rrk is online now
