Mirror Glue
Old 01-07-2018, 01:17 PM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,198
Mirror Glue
I want to hang an 80x32 frameless mirror with a french cleat or similar so it can float away from the wall 3/4" and have no visible clips.
Can anyone recommend a glue that I can trust to glue a 1x4 to the back of this mirror to support all its weight, and that won't mess up the mirror finish?
Golden view is offline
Old 01-07-2018, 01:35 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 764
Re: Mirror Glue
I have done this 3 times without any issues. I used a urethane type caulking. I can't say for sure if it will eat the silver over time but it is definitely a solid bond. All times I did it I glued a 5/4 PVC frame and let it lay flat and cure over night before hanging.
The client wanted the mirror edge all lit up. I built the PVC frame about 1" back from the edge and used led tape lighting adhered around the frame.
overanalyze is offline
The Following 8 Users Say Thank You to overanalyze For This Useful Post:
Golden view (01-07-2018), KAP (01-07-2018), Metro M & L (01-07-2018), Railman (01-07-2018), Rio (01-07-2018), tang (01-17-2018), Tom M (01-07-2018), Xtrememtnbiker (01-07-2018)
Old 01-07-2018, 01:44 PM   #3
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
We played with the lighting idea too and then decided to keep it simpler. Can you tell me the specific caulking you use? Don't want to take any chances.
Old 01-07-2018, 02:23 PM   #4
Always Learning
Rewards Points: 764
Re: Mirror Glue
Oh boy...I think I used TiteBond weathermaster. Really was something I had in the van. Might have used NP1 for the first one. Sorry I am not 100% sure what it was. I just know I didn't use silicone because if you use the wrong silicone it can eat the silvering. I was nervous too but the first one I did has been up a few years now with zero issue.
Old 01-07-2018, 03:18 PM   #5
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 703
Re: Mirror Glue
why not just use mirror mastic from a glass supplier?
nicko
"Quality work for those who know the difference"
nickko is offline
The Following User Says Thank You to nickko For This Useful Post:
Bummie (01-07-2018)
Old 01-07-2018, 03:37 PM   #6
rrk's Avatar
Rewards Points: 1,564
Re: Mirror Glue
nicko
Mirror mastic does not like heat, it will not hold the weight of the mirror. It will hold it against the wall but to up in the summer. Ask me how I know.
I would not use any type of glue, they have L clips and rail that are just about invisible. My glass guy just uses 1 at the bottom, over time any adhesive will eat through the silvering on the mirror except for mirror adhesive
rrk is offline
The Following 2 Users Say Thank You to rrk For This Useful Post:
Golden view (01-07-2018), tang (01-17-2018)
Old 01-07-2018, 03:58 PM   #7
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
Yeah mirrors are too easy to remove when installed with mastic. But I guess not all adhesives will eat through the silvering, since mirror mastic exists...
Old 01-07-2018, 04:10 PM   #8
Talking Head
EthanB's Avatar
Rewards Points: 22
Re: Mirror Glue
PL makes a glass specific adhesive but not sure if it would affect the backing. I'd be inclined to just use silicone and give it enough time to set.
Planer.....
EthanB is offline
Old 01-07-2018, 04:23 PM   #9
tjbnwi's Avatar
Rewards Points: 2,588
Re: Mirror Glue
Seal-Bond.
tjbnwi is offline
Old 01-07-2018, 05:43 PM   #10
rrk's Avatar
Re: Mirror Glue
no silicone, many have some sort of additive that will eat the silvering. Notice the ones that really smell? Again, ask me how I know.
Just ask any glass guy who has been in business a while and they will tell you what to do. Mine uses the L bracket.
The crash of a mirror to the floor is sound you will remember.
rrk is offline
overanalyze (01-07-2018), Rio (01-07-2018)
Old 01-07-2018, 10:14 PM   #11
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 206
Re: Mirror Glue
Many moons ago, I used 'proper' mirror adhesive to glue a hunk of ply to the back of a smallish (2x3) mirror. That got hung with eyelets and wire.
Until it came crashing down a few years later. Happily, it was my own place.
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Old 01-16-2018, 10:18 PM   #12
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,972
Re: Mirror Glue
"typical" mirror install relies on a mechanical fastener for the vertical load while using an adhesive bond for lateral load....typical being J channel for the mechanical... if it were me, and I wanted to sleep well,,,I would push for a (complimentary/low visibility ) L bracket for the vertical load..
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 01-17-2018, 12:32 AM   #13
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
The glass co gave me a tube of stuff that says no mechanical fasteners needed. Reaches 30% strength in 24 hours, so I'm letting it sit a few days before I hang it. I'll post back if I get a call back in a year...
parkers5150 (01-19-2018)
Old 01-19-2018, 09:15 PM   #14
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
Went to hang the mirror today. Almost last thing for a major 4 room remodel with 1000 square feet of tile, $40k in cabinets, etc. I glued the damn french cleat on backwards! I belong in the wall of shame. Holy crap what an idiot.
The Following 3 Users Say Thank You to Golden view For This Useful Post:
asevereid (01-21-2018), Rio (01-20-2018), rrk (01-20-2018)
Old 01-20-2018, 06:56 AM   #15
rrk's Avatar
Re: Mirror Glue
I wish I could say I have never done that but.........
You were thinking too much
rrk is offline
Old 01-20-2018, 08:12 AM   #16
tjbnwi's Avatar
Re: Mirror Glue
On the wall or the mirror?
tjbnwi is offline
Old 01-20-2018, 09:22 AM   #17
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
On the mirror. Glued. I'll try changing the slope with a carefully set dovetail router bit. Otherwise, buying a new mirror. Cost is not a big deal, but it'll take a week or more to get it cut, delivered, glued back up, etc.
Old 01-20-2018, 10:30 AM   #18
rrk's Avatar
Re: Mirror Glue
Having a mirror guy doing it is sounding better and better
rrk is offline
Old 01-20-2018, 10:43 AM   #19
edward trowelhands
Trade: Diplomat
Re: Mirror Glue
No kidding.
rrk (01-20-2018)
Old 01-20-2018, 12:51 PM   #20
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,630
Re: Mirror Glue
Oh man....I feel bad laughing...but I am.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Golden view (01-20-2018)
