Trade: cabinet installer
Microwave Conundrum
1st off I'm glad I'm just a sub/installer on this job .
Cabinet designer put the range and microwave right against the wall in a very tight kitchen . Everything seemed to be going great as I finished up the job EXACTLY per kitchen plan . So we get all the appliances in place but the microwave doesn't show up until the end of the day . Well I hang it and damn if the door won't open even 1 inch before it starts to dig into the drywall. Silestone tops are already in place and there is no way to move just the uppers without making the microwave off center to the range and the cabinet over the sink off center in relation to the sink as well . I call the designer and she says OOPS . They tell me the options they have are to make the owner go with a regular range hood and a micro on the counter . I start laughing and say good luck . They call back and say they found a Dacor model that has a frame around the door and can be mounted right against a wall on the left side . Too bad it's $1,100 and the one he paid for was $700 . Not my problem though . I feel a little bad I didn't question this setup earlier but damn I don't ask them how I should do my job so I shouldn't have to do their job for them should I ? As long as I have been doing cabinets I have never encountered this setup/mistake before . I also haven't seen a undercabinet micro /hood setup with a zero clearance door which they say they can get . Has anyone else ? |
Re: Microwave Conundrum
Since the electrician (me) typically gets tasked with appliance installation and startup, I have learned to always question any appliance that is installed smack up against a wall without wiggle room. Certain refrigerators have the problem you describe as having with the microwave.
HEAD'S UP.... most every 30" GE range now has the back "console" piece nearly 32" wide. The range will slide in a 30" hole, but if you have anything in the way of the console (like a wall or refrigerator end panel), the range will not fit. The solution? Every GE range made like that is also available in the absolutely identical version under the Hotpoint name, but the only difference is that the console is also exactly 30" wide. |
| The Following 3 Users Say Thank You to mdshunk For This Useful Post: |
#3 | |
solar guy
Trade: solar contracting
Re: Microwave ConundrumQuote:
#4 | |
KemoSabe
I took a wall out in my house because it concerned me.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:55 AM. |
solar guy
Re: Microwave Conundrum |
#6 | |
KemoSabe
Trade: Kitchen & Bath
Residential ranges are insulated so as to not be a fire hazard.
Do you have room to cheat the uppers over? I was working on a large apartment complex and the sub doing the overflow kitchens I couldn't handle installed in the manner you're describing. I took 1/2 inch out of the filler on the other end and rehung the uppers as 1 piece, only took about 20 minutes to fix. The uppers can be slightly offset from the lowers without it really jumping out and catching the eye. Happens sometimes on stock kitchen installs when one of the walls is out of plumb 1/8 inch per foot and you're already maxed out with a three inch filler against a BCC.
KemoSabe
I was concerned with an open flame rolling out from under a large pot more than anything. Thanks for the information though.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Good point, I've only seen it done with electric so far.
solar guy
#11 | |
Trade: Home Improvement General Contractor
First thing to pop into my head.
"Enjoy Every Sandwich" Warren Zevon |
| microwave circut | cabinet runner | Electrical | 20 | 05-22-2009 12:17 AM |
| Microwave in the van??? | Mr. Wms | General Discussion | 28 | 05-20-2009 10:20 AM |
| 2008 Code & Microwave | SLSTech | Electrical | 23 | 03-05-2009 04:18 PM |
| Microwave antennae exposure? | Tonkadad | Electrical | 11 | 03-02-2008 11:44 PM |
| Microwave in your truck? | mdshunk | Tools & Equipment | 10 | 01-22-2008 10:03 PM |
