Major Smoke Damage Cleaning Help
Old 11-18-2016, 09:07 PM   #1
SDF's Avatar
Trade: quite a few things
Rewards Points: 14
I can't seem to find an appropriate sub-forum for this so I'll try here. Mods can move it if needed...
So I have an apartment to renovate where a grease fire happened about 8 months ago. It's a full gut down to framing and block and is approximately 30'x50' for a scope of ceiling and floor area. It's a second floor unit with concrete ceilings that aren't going anywhere. They are smooth and were painted. Still basically smooth with some bubbled paint here and there but that's whatever. The smoke damage is serious. The entire ceiling is blacker than black and I'm looking for help with cleaning solutions. There's no way I can simply paint over it.
-My original thought was a TSP solution but I'm reading that water based cleaning will embed the smoke even further into the surface. So long as that gets it fairly clean would the possible embedding make much of a difference after a good paint spray job?
-After a little bit of searching I'm thinking the best thing to use would be some powerful degreaser solution.
Either way the elbow grease involved seems daunting. Even though I'll have guys to do it for me I'm obviously looking for the least laborious yet thorough way. The floors are concrete so I don't have much concern for spillage and messes. I keep wondering if there is some type of pressure washer power scrubber attachment that spins with a return hose connected to the scrubber and hooked to a pump outside to suck the dirty water out. That would seem efficient and fast but likely a dream.
So who's got real experience with this kind of thing and is willing to share a tip? I've done one fire job several years ago in a house. The smoke damage there was bad but nowhere near what this apartment has. The areas of that house that we had to clean were pretty intense and it still took two coats of Zinnser, iirc, to cover what smoke we couldn't remove. Thanks ahead of time for any help!
SDF is offline
Old 11-18-2016, 09:25 PM   #2
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 6
Re: Major Smoke Damage Cleaning Help
You might investigate having it performed by a cryogenic cleaning company (dry ice blasting or CO2 blasting). I know almost nothing about this, but I searched online and this technology can do what you want done, which is remove soot from concrete. It came to mind because this process was used a half block from our office to remove paint from the interior side of an historic multiwythe brick wall.
P42003 is online now
The Following User Says Thank You to P42003 For This Useful Post:
SDF (11-18-2016)
Old 11-18-2016, 09:35 PM   #3
SDF's Avatar
Rewards Points: 14
Thanks. Unfortunately I have already bid this and I'm thinking I've underbid this portion no matter which option I have let alone the cryogenic cleaning of the future. I will look into it though.
SDF is offline
Old 11-19-2016, 08:29 AM   #4
hdavis's Avatar
Rewards Points: 4,695
http://www.jondon.com/chemicals/smok...-cleaners.html
hdavis is online now
Old 11-19-2016, 08:46 AM   #5
hdavis's Avatar
If you're using BIN pigmented shellac to seal, don't worry about the odor, just get the surface so you get adhesion, then 2 coat it followed by top coats.
Kilz Original will also do a decent job of odor control if you can tolerate an oil base product.
Sir Mixalot (11-19-2016)
Old 02-01-2017, 01:10 PM   #6
Insuranceclaims's Avatar
Trade: Insurance Restoration
Rewards Points: 201
So, where are you on this project now?
Insuranceclaims is offline
Old 02-01-2017, 05:54 PM   #7
hdavis's Avatar
Broke?
Help me with a photo? I need FLAT roof hail damage photo. Grumpy Roofing 52 01-08-2014 01:52 PM
Non union jobsite (quaker church)vandalized in philadelphia $500,000 Damage mastersplinter Carpentry 41 04-19-2013 02:06 AM
Insurance Needs for Cleaning, Drying, & Restoration Contractors ARMR Business 0 10-17-2012 12:23 PM
Certified Roof Cleaning in Tampa Bay Florida BARCC, INC. Introductions 4 11-14-2010 10:03 PM
Post Construction Window Cleaning wpschoch General Discussion 0 02-01-2010 02:00 PM
