MFWIC
Trade: house painter
Intense Cat Smell
How can I get rid of totally intense cat smell in 1200sqft house? This is worst I ever smelled. Many cats, many years.
Hope to kill the smell first so I can do the remodel work. Then, how to seal it all off ??? walls, lid, and subflooring??? Any ideas, short of the torch, would be appreciated ! Can't hardly walk in the door, now. r |
Re: Intense Cat Smell
Bin Zinser. That's all I can think of. Spray it everywhere, no pun intended. others will say Kilz
Old School Marine
Trade: Union Journeyman Electrician
Remove all rugs, floor coverings, etc. Then go in with an airless sprayer and coat the whole place with Kilz primer sealer.
Chief Toilet Mover
Trade: Bathroom Remodeling
I always run an ozone machine for 3-4 days, then silicone every crack, every opening (like the gap between the sub floor and the bottom of the base molding), then like said already 2 coats of kilz rolled on the floor and any walls that are suspects.
Cats are from the devil. |
most of the higher end paint stores sell a primer thats made specifically for this, it's not cheap and you won't find it at any of the box stores. check around at a Sherwin williams of similar place.
A gun in the hand is better than a Cop on the phone !!! |
Trade: general contractor
I am actually doing the same thing to a house right now.I cut out some of the worst spots on the floor and replaced them then kilzed everything before paint.Smells pretty good now.All fabric products like curtains and carpet or similiar items that can absorb odor have to go!Ozone machine is a good Idea!
Priced In
Trade: Exiled For Life
I vouch for kilz or anything similiar. Been there done that. Had to remove all carpet,pad and base moulding. After re-did the room couldn't tell it was a stinking mess as had that new carpet and paint smell. I lived in the house for a year and the smell never returned.
Trade: Electrical
What about skunk smell in a crawl space under a house? Currently no plastic covering the dirt.
Jim R |
Trade: Handyman
Do not forget to check the A/C duct work. I did a remodel a few years ago with the same problem. Did the sealing of the floor, walls and ceiling with primer, new flooring and paint. Then found that the smell remained after I turned the A/C back on.
Chief Toilet Mover
Exactly why an ozone machine is so effective in these situations.
#11 | |
Re: Intense Cat SmellQuote:
![]() There's got to be some type of chemical neutralizer or something.
Where did you get your ozone machine. I've been trying to find one and haven't had much luck.
Trade: HVAC/R
Only very high level of ozone remove the smell from pet danders. When used in homes that are occupied the level far exceeds safe levels. (safe levels are <.070 ppm for an 8 hour average .090 ppm for a 1 hour average) Most people think they increase IAQ because it actually impairs the sense of smell. If you are using it in a space that is not occupied then they will help some odors. Chemical reactions in some homes can actually increase formaldehyde even at <.050 ppm
Edit: Opps forgot to relevant info.... The above mentioned procedures are how it is taken care of here. Rip anything saturated or stained out and seal the entire place floors and all. Smoke smell is even worse than cats depending on how much they smoke. Same procedure two coats may be required. If it's in your HVAC/R systems you may need to look into getting those items cleaned out. If the insulation is saturated with the smell the only way may be to remove the insulation it would really just depend on the actual conditions. Last edited by BigJon3475; 10-18-2007 at 12:38 PM. Reason: Adding Information |
Mod / ArchiBuilder
I hate cats, what are they good for?
Nothing!
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
#15 | |
Chief Toilet Mover
Read the instructions, they kill living things - germs- odors - bugs - cats- people. Ozone is heavier than air so set it up as high as possible in the room. They run on timers so you set it... anyways, just read the instructions and do be in the house while you run it. I always ran it at night at full strength set to run until about 3 hours before I planned on getting there the next morning. |
Mine keep the snakes and mice at bay at our farm. Every day we get a "present" from one of them on the front steps
Haven't stepped in any poop yet!Off subject, we had a snake come DOWN through our roof last year. Can only figure one way he got up there, a bird dropped it. Kinda freaky walking down the hallway and a snake is dangling from the ceiling.
Trade: painting and carpentry
Re: Intense Cat Smell |
#18 |
Trade: Decking, Fencing and Remodeling
Killz or Zinser after everything has been taken out. You might also want to bleach the floor. Have a hvac cleaning co come in and clean the whole system. I turned one on after a big remodel once and had to reclean the whole house
not just the area we worked in and had already cleaned!
#19 | |
Chief Toilet Mover
We are talking about a device that is used temporarily. This is similar to extermination. While the extermination chemicals are harmful to humans, you avoid the problems by using them correctly. The process of fumigation and using an ozone generator are very similar. You don't want to be in the house during the process and there needs to be a buffer zone of time between when you do it and when you renter. Last edited by Mike Finley; 10-21-2007 at 02:34 PM. |
#20 | |
G.C.
www.InterlinkSupply.com |
| Cant Ya Smell That Smell | PARA1 | Plumbing | 10 | 12-23-2007 01:08 PM |
| Sulfur smell in water anyone heard of "sulfur admittance" part? | TurnkeyConst | Plumbing | 1 | 06-08-2007 09:02 AM |
| The smell of ?? | K2 | Off Topic (Non Trade) | 9 | 12-19-2006 07:17 PM |
| You smell fruitey too?? | IHI | Off Topic (Non Trade) | 44 | 03-21-2006 10:33 PM |
| Removing Musty Smell | 25BRIAN | General Discussion | 4 | 10-26-2005 12:56 PM |
