Ice Dams, Post-Build Fixes.
Old 12-15-2016, 07:18 AM   #21
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 62
Re: Ice Dams, Post-Build Fixes.
Sorry I missed this earlier - as others stated you should not have an air gap between insulation & the best method is insulation directly on the roof sheathing - this helps eliminate air gaps & thermal breaks. The other item is you will always have icicles & even some ice that form even with a perfect roof - the just is just making sure you don't end up with something worse
I am not sure of your climate zone but per the codes do require at least an R20 (maybe up to 35 in your area) of an air impermeable insulation (foam qualifies - mostly see; http://thehtrc.com/2013/ice-dams-ici...c-condensation)
One quick final caveat is if you are in an area with 50 psf of snow or more, then you should have an air gap (aka cold roof) where you vent between the insulation & roofing as a best practice
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
hdavis (12-15-2016), Tom Struble (12-15-2016)
Old 12-15-2016, 06:05 PM   #22
Box Builder
Morning Wood's Avatar
Rewards Points: 8,788
I just want to clarify what the home has at the moment. Tell me if this is correct. 3" of 2#(is that considered closed cell?) spray foam sprayed to underside of roof sheathing in rafter bays ridge to eave. Then an additional R21 of fiberglass batts. You also said that in 3/4 of the house is the fiberglass. Does that mean that in 1/4 of the house it is just the spray foam? Also, what is the rafter size?
Morning Wood is online now
Old 12-15-2016, 07:34 PM   #23
META's Avatar
Trade: General and Trades
Rewards Points: 812
Home is 2# foam entire shell, walls and rafters (top of wall to ridge). Rafters are 2x6 however the ceiling also has cathedral created with sistered ceiling joists. R-19 batts are in all areas where sistered joists exist.
Weather has been much colder the last couple days, I think it's made all the difference as mich less melt occurring.
META is offline
Old 01-10-2017, 03:21 PM   #24
Disasterman's Avatar
Trade: Insurance Restoration/General Contractor
Rewards Points: 46
Photos or a site visit are key to solving an ice damming issue caused by an architectural and/or builder defect. We typically use a thermal imaging camera to best understand what is going on in those areas that you can't see. A cold roof, combined (sleepers) with foam is a good probable solution but a complex roof can hamper the ventilation. This model would provide additional insulation reducing energy and improving comfort while providing outstanding ventilation.
We have found that we need to get at least R30 to isolate the interior climate from the exterior (retrofits/rebuilds).
Disasterman is offline
The Following User Says Thank You to Disasterman For This Useful Post:
META (01-10-2017)
Beam to Post Connection karmakarp Decks & Fencing 15 09-02-2014 05:37 AM
