How Long
Old 04-18-2008, 10:58 PM   #1
Xtremski77's Avatar
How Long
I am framing out a basement with block walls. The room is roughly 44X12.
I'll also be removing 2 6x6 windows and installing 2 sets of french doors( cutting one row block top and bottom and installing header), furring down ceiling. then installing sheetrock, painting, and trim. I have 2 questions. 1st how long to frame block wall using tapcoms with 2 people. 2nd. How much would you charge. Include laying tile on floor. Ill also be installing spiral stairs to 1st floor and framing for closet.
My Est. Materials and Labor 20,531
How is my est. Not sure how much time to allow for framing using tapcom screws. The price is for me and one laborer. Thanks You
Xtremski77 is offline
Old 04-19-2008, 10:59 AM   #2
kip's Avatar
Trade: general house builder
Re: How Long
$20,530 and I'll have it done one day sooner
kip is offline
Old 04-19-2008, 11:18 AM   #3
Remodeling Professionals
buildenterprise's Avatar
Re: How Long
Use a ramset or hilti gun for the firring strips, it will go three times faster.
buildenterprise is offline
Old 04-20-2008, 09:45 AM   #4
Xtremski77's Avatar
Re: How Long
After reading the other post on here it seems that people prefer tapcom to ramset. I know alot of you guys dont want to help on giving a price so dont do that. Just help me figure how long it would take to put up the furring strips. Any help would be appreciated. As for the "how much" does do you think the price is fair and if not what other things should i consider.
Old 04-20-2008, 09:52 AM   #5
tcleve4911's Avatar
Trade: Remodeling contractor
Re: How Long
First of all, I wouldn't attach anything to the block wall - ever - ever - ever!!!
Build 2x4 walls 1-2" away from the masonry wall with a pressure treated shoe. This allows you to get straight walls, install insulation & electrical. Say nothing of the moisture / vapor barrier issues you will create.
It's a lot faster that tapcon or other methods, too.
That's the way the pros do it and it's just my opinion.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 04-20-2008, 10:23 AM   #6
Xtremski77's Avatar
Re: How Long
there is only one wall that is back filled and it is only 4'(backfill). The other walls are exposed to ext.
Old 04-22-2008, 12:07 PM   #7
AtlanticWBConst's Avatar
Re: How Long
Generally, framing off a basic basement is about one day.
If you are bringing the lumber yourself, factor in the loss of a day: Picking up lumber, transporting, loading job, picking up tools, setting up tools, marking out floor, setting up for "production", etc = at least 3/4 of a day...before you actually start framing.
Large basement: 1,2 or even three days. Walls go up quick, if you are framing in for drywall ceilings, that is the part that will eat up your time (boxing in soffits, etc)
...as already stated: I suggest using a powder actuated .22 cal fastener for the wall framing = much faster.
- Build Well -
AtlanticWBConst is offline
Old 04-22-2008, 10:19 PM   #8
TimNJ's Avatar
Re: How Long
I second that opinion.
TimNJ is offline
Old 04-22-2008, 10:29 PM   #9
orson's Avatar
Trade: Kitchen & Bath
Re: How Long
If you want the walls to stay put Tapcon them to the floor. Get an SDS Plus drill and it will go fairly quickly.
I second tcleve, don't fasten anything to the block,frame walls an inch off the block so they have a dead air space between the block and the insulated wall.
orson is offline
Old 04-23-2008, 06:12 AM   #10
Re: How Long
If you are worried about the walls not being anchored enough....remember that Hilti's and .22 cal powder actuated fasteners are the standard anchoring tool for wall and concrete when doing steel framing (commercial and some industrial). They don't use tapcons = takes too long, and unnecessary.
Now, on the other hand, if you are still worried about using a Hilti alone, then you could go thru and add a tapcon evey 6' +/-, or so, after you are done framing the walls using the Hilti. This way, the actual framing process will still go faster.
- Build Well -
Old 04-25-2008, 06:16 PM   #11
orson's Avatar
Re: How Long
Atlantic,
Just because something is standard spec does not make it a good way to build. The first thing we do before setting doors in a commercial building is tapcon all the walls to the floor at the door openings because they will move.
I agree with your method of framing up w/ the Hilti and then adding fewer tapcons. Acutally I would say a 1/4" tapcon every 2 feet would be sufficient, just something to keep the floor where it was nailed so the nails can't work the crete loose.
orson is offline
Old 04-25-2008, 09:20 PM   #12
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Re: How Long
Two things I would use;
  • Hilti
  • pl-200
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Premium tools...worth it (warning, long post) samthedog General Discussion 25 12-31-2011 06:57 AM
Long island traffic rules update nywoodwizard Off Topic (Non Trade) 10 01-15-2008 10:48 PM
How long do charcoal filters in range hoods last? dkillianjr General Discussion 5 11-11-2007 11:39 PM
How long is to long of a backlog. ruskent Business 16 05-28-2007 09:40 PM
Roofer vs. Roofer (Just a long winded hypothetical) Thunder1 Roofing 7 12-01-2005 10:22 PM
