Hot Tub In Garage
Old 03-23-2010, 09:21 PM   #1
metiernan's Avatar
Trade: construction
Hot Tub In Garage
I have a customer who wants to put a hot tub in their garage. The garage is on a new house and is already insulated and sheetrocked. The main concern I have is what to do about the steam the hot tub will put out. Do I need to tear out the sheetrock around and above where it will be and install moisture resistance sheetrock? Do I just put in a good exhaust fan? Any advice is appreciated. Thanks
metiernan is offline
Old 03-23-2010, 10:33 PM   #2
j_builder's Avatar
Trade: Specializing in residential remodeling
Rewards Points: 250
Re: Hot Tub In Garage
You should check with your AHJ "Authority Having Jurisdiction" to find out the code requirements before assuming that it's permissible before installing.
To many safety factors to consider...such as children downing because of not being supervised or any barriers to prevent them from entering the hot tub, electrical hazards, chemical hazards from the hot tub (chlorine/bromine).
Your a little vague in mentioning what type of hot tub and I'll take it as being a portable hot tub/spa and not one of those inflatable spas that you can plug and play.
I'd personally try to talk your clients out of this and install it outside if at all possible.
j_builder is offline
Old 03-24-2010, 01:08 AM   #3
peterjames's Avatar
Trade: licensed plumber
Rewards Points: 25
Fix a good exhaust fan. Garage exhaust fans can stop the danger of high amounts of hazardous fumes from accumulating in the air inside the garage. This severe risk can cause numerous health troubles and even death. An exhaust fan also eliminates humidity and keeps the area dry, which prevents condensation from building up and causing additional problems.
peterjames is offline
Old 03-24-2010, 04:29 AM   #4
General Contractor
greg24k's Avatar
Rewards Points: 7,360
Tell them to have theirs head examined
greg24k is offline
j_sims (04-20-2010)
Old 03-24-2010, 04:45 AM   #5
Joasis's Avatar
Rewards Points: 1,466
I had a hot tub in a garage for years, no problem. Hoever, it does require a little common sense, like opening the door when in use, and keeping the cover on when not in use.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 03-24-2010, 07:32 AM   #6
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 168
You're asuming all the liabilty for having the hot tub inside?
Also, I would be concerned about the slab thickness.
Do you have manufacturers specs?
rjconstructs is offline
Old 03-24-2010, 07:38 AM   #7
genecarp's Avatar
Rewards Points: 2,000
Dehumidification and Air Exchanger are the correct things to consider. Humidity levels need to be controlled if you want a prof installation, I would be setting up a meeting with my HVAC guy, GMOD
genecarp is offline
Old 03-24-2010, 09:23 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 1,808
All the above like genecarp says. Don't count on the owner telling you "we'll turn on the fan & open the window when we use it".
griz is online now
Pole Barn Garage mrmike Carpentry 26 10-28-2009 07:29 PM
Framing 20'x20' garage carterarce Framing 12 09-29-2009 10:24 AM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 11:33 AM
Price for Fill / Garage Slab Prep -- Opinions? slr2974 Excavation & Site Work 9 06-17-2009 09:22 AM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 01:25 PM
