Chief Toilet Mover
Trade: Bathroom Remodeling
Help Me Out On How To Do This One.
This is the veiw above a dropped ceiling in a kitchen. I need to gain the 1 foot back taking the ceilings from 7 feet back to 8 by removing the dropped ceiling and tucking all the pipes and wires back up between the joists of the floor above. I'm not too worried about all the copper and electrical lines or the main 4 inch drain running parralel to the floor joists.
The problem is down on the far end where the 4 drains T back into the main (actually 3 into the main with 2 that T back into 1 in the photo that shows the left hand smaller branch) . How do I tuck that up into the joists? With the dropped ceiling removed there will be easy access to it all, but what about cutting into those joists to run the left and right branch into that main drain line? The joists are 2x10s, (9" actual). 2 to cross on the left hand smaller branch and 1 to cross on the right hand side. The place where these pipes are is right up against the rim joist at least and the span is about 12 feet coming back to the camera. Last edited by Mike Finley; 03-24-2006 at 11:36 PM. |
Re: Help Me Out On How To Do This One.
What size are those smaller branch pipes..1 1/2" or 2"??
Chief Toilet Mover
They should be 2 inchs on the left. The drains are for a bathtub and a vanity on the left the one going straight up in the middle picture should be from a toilet and the one on the far right I believe is a vent.
Mod / ArchiBuilder
Mike, that is a tough one.
I think you can come up with something but you need to remove the drop ceiling to get a better look at the situation.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Chief Toilet Mover
It all comes down to code right, as long as there is enough room to redo the plumbing, it all just comes down to being able to run it through the 3 joists legally.
Do I have the code correct here? For a floor joist you can't bore a hole greater than 1/3 the joist within 2 inches of the joist edge right? So I have a 9 " joist but a 4 inch hole so that pushes the code. For notching you can't do more than 1/6 the depth of the joist which only gives me 1 1/2" to notch and only notching allowed is on the end 1/3rds of a joist, which is where I am anyways. Notching won't do me really any good other than not gaining the full 1 foot I want to recover as I would at best still have to fur down at least 3 inches. I can bore the two joists on the left to run the 2" pipes and be legal it seems, but the one on the right looks to be too big to fit with the 1/3 maximum bore hole. Is there an exception if you sister the joists to strengthen them? |
You got yourself a goody here Mike. I can see pulling most of it off with the exception of the pipe coming in from the left in photo 1. It appears that the underside of the joist will have to be notched to maintain the pitch of the pipe, that's a no-no. You could notch and go with a tension strap, inletted or under but that is going to require an engineers stamp.
Home Improvement Guy
Trade: Renovations contractor
Mike, just curious what is that 14/2 Romex wire coming down dangerously close to the nails in pictures 2 and 3?
#8 | |
Chief Toilet Mover
Re: Help Me Out On How To Do This One.Quote:
#9 | |
Chief Toilet Mover
How about the copper pipes in picture 1 running through the bottom 2 inches of the joist. I'm wondering if the building dept is going to want that changed if we start mucking about up there?
Chief Toilet Mover
Anybody help me out with the code here? Should I just take these pictures up to my building dept and have them tell me what I can do?
Where's are all you geniuses at on this one????? Last edited by Mike Finley; 02-27-2006 at 11:40 PM. |
#11 | |
The Deck Guy
You should go and buy the CodeCheck books they sell. I am an absolute retard when it comes to remembering code details and those CodeCheck books are absolutely fantastic. I had an issue involving notching and they had the answers (with a diagram to boot!). They have them for all the trades. The diagrams are so good in fact, that I've actually proved I was right to an inspector who was ready to fail something because (as usual) he didn't know the code as well as he thought. |
#12 | |
Chief Toilet Mover
Those CodeCheck books are good though, I agree with you on how much of a good crutch they are. I'm retarded on the code too. What I do is everytime I run into an actual code situation I write it into my personal code book so I can refer back to it. Nothing like writing down what the inspector is telling you right in front of him, and it works pretty well since you usually end up running into a lot of the same stuff over and over again. Unfortunatly I haven't run into anything this complex before. They got me good on a laundry room we were remodeling. They want built in anti water hammers in any water lines feeding a "machine with a valve" as they put it. The plumber didn't know it and I didn't. Luckily they allowed a set of screw in ones at the taps. Now that little tid bit is in my book! |
Trade: i am a small remodeling contractor been at this most my life
i may not be getting this all right but i wonder if u cant just add on to the two inch for boring ur holes and reconnect your t ondown that pipe somewhere ..just something to think on im not sure but tryin
Trade: framing/ remodeling
what about turning the whole deal 180* and re-routing it the other direction into the far wall, then down, and re-hook it together?
alittle bit of drywall patch & repair, but it seems you are going to be doing a bunch of demo anyway so one more sheet of rock isn't gonna hurt. I guess I would also need to see into the room below to better understand the bigger picture. |
Commercial construction
Trade: Commercial construction
How much did you allow for this in your estimate?
What has your plumber suggested? What has your engineer suggested? Wood I joists? Microllam? Steel? Flitch beam? |
Mike, those copper pipes caught my eye right off. I assumed that they had already passed the first insp. and would be grandfathered in.
General Contractor
Trade: Class "A" Contractor with "BLD" Classification
I was able to run a 4" drain through 2 2x10 joists on a remodel I did last year. The plumbing supply sold these steel brackets in the shape of a long U that wrapped the joist. Sort of like a joist hanger but thicker guage. It was a bout 12" long and had a 4" hole through it. It can go anywhere on the joist. I don't remember if it gets screwed on or nailed on. put it uses plenty of fasteners. It all passed code. This is in Virginia so your code may be different.
#18 |
Can't ya just 'header' off the joists at the far end?? Then just move everything straight up?? Double-up with some sisters where you 'header-in'.
http://www.tr-built.com Last edited by Tom R; 03-01-2006 at 09:42 PM. |
#19 |
Interior Remodeling
Trade: Interior Remodeling
Is that a drywalled drop ceiling?
#20 | |
Chief Toilet Mover
Estimate isn't even on paper yet, these are repeat customers and we have lots of time, they are still recovering financially from the last round of stuff We are in the what can we do and what makes sense stage.As for the plumber, well without going into a long story, I'm trying to avoid bringing him in on this yet. To be honest both my plumber and electrician got me red flagged on both the rough plumbing and electrical inspections on the last project. I don't know what the deal is, both good guys, both doing this a while but damn, what the hell! I want to get my own information on this one since these guys seem to have a habit of getting into trouble with unusual circumstances.
