Help
Old 02-03-2006, 11:10 PM   #1
Remodeler
MinConst's Avatar
Help
I have a question that is rather hard to explain with out seeing it but here goes.
I started a job to replace some damaged sheet rock in a basement. When I opened the wall up I found rot. two studs completely fell apart, and the sill and top plates are rotten in a couple of sections. The leak is still a problem that I need to address but my concern is there is a small 8" or so section of the band joist that is also bad. Can this be saved with Get Rot or some other such product? It is between two floor joists and these joists are tied to good wood.
I have built a temp wall so i can remove and replace the sill and top plates of the wall. This half wall is setting on top of the blocks. If there is anything I can add to get a good reply ask away. And thanks as always.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 02-04-2006, 07:19 AM   #2
jmic's Avatar
Re: Help
It's like cancer, I'de cut it out and get some fresh meat in there. Also but most important, correct the water problem.
Joe
jmic is offline
Old 02-04-2006, 08:50 AM   #3
bassmaster's Avatar
Trade: Home Improvement/ Handyman Services
Re: Help
Jmic, is right (imo)
a little more work but, I would cut out all the rot & replace.
bassmaster is offline
Old 02-04-2006, 09:41 AM   #4
Paulsan's Avatar
Trade: New home construction
Re: Help
If you find rot, cut it out and replace.
Paulsan is offline
Old 02-04-2006, 09:47 AM   #5
Custom Builder
Glasshousebltr's Avatar
Re: Help
Keep in mind, bugs love rot, it's like offering free drinks with the dinner plate special.
Bob
Bob
Glasshousebltr is offline
Old 02-04-2006, 10:08 AM   #6
skylands's Avatar
Trade: restoration
Re: Help
In upstate NY we don't have a termite problem. Therefore, the rot you see is never the end (or begining) of the problem.
Since you will most likely have to remove the siding to fix the bandboard, I always remove a few more courses to check the house framing. Is this a typical older home with no sheathing? If so, then check the framing around the windows above the rotted band board.
I've found that when it comes to rot, "things just ain't as little as they appear to be".
skylands is offline
Old 02-04-2006, 12:03 PM   #7
Remodeler
MinConst's Avatar
Re: Help
Originally Posted by skylands
Since you will most likely have to remove the siding to fix the band board, I always remove a few more courses to check the house framing. Is this a typical older home with no sheathing? If so, then check the framing around the windows above the rotted band board.
This also would require removing a deck that is fastened to this band board. I can see the whole band board and this the only spot I cannot replace easily. I know this is caused by no flashing on the deck but removing this deck will be much more than the client will want to pay for. I will run this by them on Monday and let them decide.
Thanks for the replies guys I knew than answer but wa hoping for an easier fix.
Paul
Website
MinConst is offline
Old 02-04-2006, 02:40 PM   #8
skylands's Avatar
Trade: restoration
Re: Help
I just did this very thing over in Otego. The deck was 42 feet and the whole project took one day with 3 guys.
Good luck.
skylands is offline
Old 02-04-2006, 10:17 PM   #9
Teetorbilt's Avatar
Re: Help
I wish that I could give you better info, GitRot is limited to small, non-structural problems.
You could contact E-Bond in Ft. Laud. and ask them about a bridge restoration material that they formulated for one of the Virginia states. I've used it on a couple of old rotten wood boats right down to the garboard strakes. The downside is that it smells like 10,000 rotting tunas until it cures.
Albert Einstein
Teetorbilt is offline
