Trade: Hardwood flooring
Hard Water Spots On Glass Block
I had to remove a glass block wall so I can rebuild a damaged shower pan.
The blocks have what looks like hard water spots. I tried cleaning with vinegar, scum-away (purchased at trade show), Spot-x, goof off, even tried oven cleaner. There wasn't even any improvement. These are 4 x 8 Wick blocks. I would like to save them as there is another wall in the same bathroom with same block. Wick no longer makes 4 x 8 end blocks, only 8 x 8. Thanks |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Fire up the BBQ
![]() Trade: GC
Rewards Points: 468
Re: Hard Water Spots On Glass Block
You try CLR?
Advertisement |
Yes. CLR produced the same results. = 0
Fire up the BBQ
![]() Trade: GC
Rewards Points: 468
How about muriatic acid & 0000# steel wool. If you have not used this before BE CAREFUL. Well vented, gloves, goggles etc. Also commercial glass shops have a polishing compound they use. A friend at the shop gives me some when I need it.
Thanks for the tip with muratic acid. I was concerned that the acid might etch the block. would soaking in a 50/50 solution be advisable or just apply the liquid and clean with cloth.
Soaked a block in a 70% Meritac acid / 30% water. Scrubbed with an bathroom scrubbing pad. Let dry and washed with soap and water. nothing doing
![]() I now think the hard water (after 7 years) has etched the block beyond repair. ![]() |
Fire up the BBQ
![]() Trade: GC
Rewards Points: 468
Re: Hard Water Spots On Glass Block |
Do you think I can give them to some one for target practice
Fire up the BBQ
![]() Trade: GC
Rewards Points: 468
Trade: Construction
Rewards Points: 2,394
Try a glass scratch removing polishing kit. With a powered polisher it could take less than 20-30 mins for a normal size shower.
www.bcconstructionllc.com |
Great, I'll try that.
Where would you purchase this polishing kit? |
Trade: Remodeling contractor
Rewards Points: 250
Well, dumb as it sounds, try WD-40. Sure seems to work on alot of stuff to remove stains, etc.
The Following User Says Thank You to Hmrepairs For This Useful Post: |
hardwoodboss (11-26-2010)
I just happen to have some WD 40 in the garage, so I jumped up, sprayed the block and rubbed like crazy. I didn,t work
![]() Thanks for the tip |
#14 | |
Trade: Bath Remodeling
Rewards Points: 250
Re: Hard Water Spots On Glass BlockQuote:
![]() I've read that sometimes the metals in hard water deposits bond with glass leaving permanent stains, so you might be screwed. Best bet is to sand the block down and repolish, but that's a ton of work. Last edited by Remodelor; 11-26-2010 at 11:18 PM. |
Rewards Points: 75
Use a product called Zaino, it's there clear-view glass polish. I had the worst water spots from acid rain on a truck I bought and was about to get new glass for it. I got this product from there website about $15 and WOW, it now looks like a new piece of glass.
Rewards Points: 90
We had a Glass block partician that had "Permanent" waster spots on them.
I used toothpaste and a dremel with the cloth buffing wheels to get them out. Before we finished, we broke out the 4 1/2 in angle grinder with a buffing wheel to quickly finish the job. If you do this, you will have to do them all so they all look the same. Another friend tried this in Portland after i told him about it. He said in his case, the glass block had a slight haze. But, he said, it was way better than the Obvious water spot look. Try it in a small area and see if it polishes it out for you.
"I dont Fear Failure, I Fear being Good at Things That Dont Matter" |
Trade: Licensed Remodeling Contractor
Rewards Points: 97
Try "Nothin's Better" located via auto parts stores. Works incredibly.
Do everything in life with quality, integrity and reliability. You will sleep better at night and not fret when your phone rings
#18 |
It's Not a Toomaa!!
Trade: Remodels
Rewards Points: 1,000
Got one of these yet?
![]() Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Specialty Exterior Reflective Glass Cleaning: Stains, Runoff, Iridescence, Hard Water | Unscratch | Windows, Siding and Doors | 1 | 08-05-2009 12:07 PM |
Glass Block 411 | andeeznuts | Remodeling | 14 | 01-22-2009 07:17 PM |
instant hot water | mowpar | Plumbing | 6 | 03-23-2008 09:56 PM |
!!!! Thrust block your valves or ending water Stubs... | Little | Excavation & Site Work | 14 | 10-18-2006 10:18 PM |
Go to Page... |
