GRK - Caliburn XL Screw - Into Concrete -- Bits ?
Old 07-16-2017, 07:54 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,980
Anyone tell me if only the GRK 1/4" blitz bit can be used with the 1/4" x 3 3/4 mushroom head concrete screws ?
Are there difficulties using other 1/4" masonry bits such as Bosch ?
I can't seem to determine from the GRK literature if it's a "must" for the Blitz bits ?
Steve
We Fix Houses is offline
Old 07-17-2017, 06:57 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,456
Re: GRK - Caliburn XL Screw - Into Concrete -- Bits ?
I don't see anything stating in the cut sheet saying you need to use their special bits.
Inner10 is offline
Old 07-17-2017, 10:48 AM   #3
Dan_Watson's Avatar
Rewards Points: 2,466
No special bit needed, just use the right size.
Dan_Watson is offline
Old 07-17-2017, 12:48 PM   #4
GregB's Avatar
Rewards Points: 886
No reason to use GRK drills. Seems strange that GRK makes great screws but not as good drills or driver bits.
We have standardized on Hawera Drills, GRK Fasteners, driven by Wiha Terminator Bits.
GregB is offline
Old 07-18-2017, 12:21 PM   #5
Mike-B's Avatar
Rewards Points: 626
Use whatever brand you'd like but the 1/4" screws require a 3/16" bit and the 19/64" screws require a 1/4" bit.
Mike-B is online now
The Following User Says Thank You to Mike-B For This Useful Post:
Californiadecks (07-18-2017)
Old 07-18-2017, 05:22 PM   #6
Inner10's Avatar
Their bits are the worst. Screws never strip..but those damn bits...
Inner10 is offline
Old 07-20-2017, 05:30 PM   #7
Dan_Watson's Avatar
It still amazes me how many of you complain about the driver bits. We NEVER strip them, we lose them all the time, but never have I seen a broken or stripped one. And we go through 10's of thousands of GRK screws a year.
The Following User Says Thank You to Dan_Watson For This Useful Post:
Xtrememtnbiker (07-20-2017)
autofeed screw guns for decks and/or drywall dale rex Tools & Equipment 11 02-24-2016 09:16 AM
17-ton concrete slab overhang fell from a bank building in Stroud Township AmeliaP Masonry 27 09-05-2013 07:16 PM
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
Concrete MPa F7ank Concrete & Paving 15 05-04-2012 05:01 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
