Granite Tile Over Fireplace Bricks - Remodeling - Contractor Talk
Old 03-10-2004, 05:15 AM   #1
Frenchy's Avatar
How would I go about putting Granite tiles over an existing fireplace made out of brick? I would like to wrap the entire fireplace but I'm wondering if the heat /cool cycles will loosen the tiles. What kind of Thinset or adhesive should I use? How should I fill in the grooves on the old brick?
Frenchy
Frenchy is offline
Old 03-10-2004, 06:51 AM   #2
Custom Builder
Glasshousebltr's Avatar
Rewards Points: 2,000
Re: Granite Tile Over Fireplace Bricks
Check with the manufacturer on the thin set/ahesive. But as far as application goes, I would attach wire mesh with tap cons to the brick, then trowl over that. Bob
Glasshousebltr is offline
Old 03-10-2004, 06:56 AM   #3
Custom Builder
oh yea.....sorry about the lack of advice on the adhesive.....I can't remember what I used when I did that exact same thing ........come on give me a brake, it was the back in the 80s.
Bob
Old 03-10-2004, 08:07 AM   #4
General Contractor
hatchet's Avatar
Do a search on Google for refractory mortar. Not sure how well that adheres to granite - but it's the standard for fireplace applications - withstands heat.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 04-15-2004, 02:33 PM   #5
Simon's Avatar
Just a quick note. Make sure that brick is clean and solid. No loose crap to come off. It may seem to go without saying, but to miss it would be bad.
gotogo
Simon is offline
Granite Tile Countertops over Laminate c5150b Tiling 6 11-29-2007 10:20 PM
Granite Tile Countertops over Laminate c5150b Remodeling 17 09-11-2007 10:58 AM
add corbels to an EXISTING granite tile countertop jkrause Remodeling 4 06-28-2007 04:50 AM
Granite Tile Countertops over Laminate c5150b Flooring 5 04-05-2007 10:57 PM
Granite Tile counter over wood MattCoops Tiling 2 02-10-2007 08:19 AM
