Grand Rapids Remodeling
Glass Block
Installed glass block wall in a bathroom. Used white silicone for grout lines. Looked good. Then put the vanity light up, about 3" away from wall (small bathroom). Looked terrible. Light showed every little fudge. Tried to go over top with more white silicone, looked worse. First; anybody got a trick to get silicone out of glass block grout lines? Second; is there a unsanded grout recomended for glass block?
Re: Glass Block
nobody has any idea's huh?
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Glass Block
It's a silicone installation, that is supposed to be what it looks like (silicone DIY, not Mortar Pro results).
I don't think you can remove the silicone and substitute grout now... isn't the silicone installation totally different installation method and you need that silicone in there to hold it together? The only thing I think you can do if you are determined to remove it and replace it is to go to an acrylic based caulk such as the ones in the tile industry and use that, since it is water soluable you will be able to tool it with a wet spong and get better results. |
Re: Glass Block
Yeah its a silicone install with the dividers ancored into the opposing walls. There is plenty of silicone between the blocks for structure its just the grout lines for show that look VERY bad. The thing is I've done a bunch of glass block in basements and such and there has never been a light that shines up against them. I'm hear to tell ya it shows and magnifies EVERYTHING! I have done the latex caulk trick before but I've already got 2 coats of silicone in the grout space. There's got to be a grout for glass block right?
Chief Toilet Mover
Re: Glass Block
What would be the difference between a grout for glass block or the acrylic based caulk?
If you're saying the structure is sound what you want is just for looks now. |
Re: Glass Block
The reason I was thinking grout is the method of letting it dry and set up then wiping off the extra. The grout in the joints is hard enough so your sponge won't leave marks. Caulk dries from exposed surface down, it has a skin at first then hardens up. If the caulk is wet enough to wipe away it leaves marks were the sponge took too much or to little. I know what you're saying though and if it wasn't lit up by that bright ass light shining down the rows it would be what I would do too.
Super B
Re: Glass Block
If it looks bad with a bright light on it, turn the light off.
Re: Glass Block
Too late the HO already called me on it. I agree with ya, whenever my motor starts knocking I turn up the car stereo, engine sounds just fine after that. Seriously though, there has to be a grout for glass block.
Chief Toilet Mover
Re: Glass Block
It's called mortar.
Or just use regular sanded tile grout. When we do a shower with glass block and we want the mortar lines of the glass block to match the tile grout we mortar the glass blocks in place and leave the lines between them dry then use the same sanded grout for the tile in the lines of the glass block. |
Re: Glass Block
Thanx Mike I've used the mortar to. I specified unsanded grout on my first post because the HO wanted it too look like the other side(shower side) that has white silicone and looks fine. I also was worried about the silicone already in the joints.
bathroom guru
Re: Glass Block
Grouting over silicone is not a great idea - even if you cut out the majority of the silicone, I would think it would be hard to get all the residue off.
As for grouting glass block, what size spacing is between the blocks?? If it is a 1/4" - unsanded grout will not work - too big of a space. I have done lots of glass block - have always used glass block mortar - blended with some additive - will normally "grout" the lines after the panel is built ( with grout float/sponge) |
Re: Glass Block
Thanx for the reply, I know about the silicone, it really doesn't sound like a good idea to me either. I have had 2 tries at making the silicone work and thats it for me. I wish I would have taken a pic, I have to go over there for additional work, I'll try to remember the damn camera weds. I'm telling you it looks like my first drywall job
. So what you are suggesting is first mortar the joint, then go over top with grout? Hmm. by the way the blocks are stacked on a guide and the edges are touching. |
#13 | |
bathroom guru
Re: Glass BlockQuote:
However, if the block edges are touching, I think you can forget any kind of grouting - you need some sort of a grout space. |
Re: Glass Block
hey, I was just at that job today and removed most of the old silicone. I didn't have much of a chance to work it though, HO has me repairing downstairs lath and plaster (extra's). Got a couple of pics of my screwed up job on the silicone. Although I will keep my system of stacking them with track and silicone I will grout them in with mortar.
Even though they are touching there is still a grout line due to the bevel of the block. Tried to upload 2 pic's. |
Chief Toilet Mover
Re: Glass Block
Looks good in pictures!
Re: Glass Block
I don't know what the hell happend to the one pic but it really is noticeable in that one. Oh well.
Trade: General Contractor, Carpenter
Re: Glass Block
Paulie, i have a bid in process of taking apart a glassblock wall surrounding a shower. The wall is about ten feet long and eight feet high, and the two reasons to take it apart are that the HO wants silicone joints instead of mortar joints, and that the wall has bowed. i am afraid that this will turn into one of those nightmare jobs that ends up costing me bunches, but i have done my research on cleaning the blocks with muriatic acid, and the connection systems for silicone, but i still think that the mortar seems like a better, stronger way to go, what do you think?
#18 |
Re: Glass Block
Probably should start a new thread.
First, a shower wall 10' long? Yikes! I agree mortar has got to be stronger and a better material.Second, I guess I want to know why it failed in the first place. Was it reinforced in the first place? I doubt it. To be honest I don't remember doing a 10' long, 8' high glass block wall, in my days, I usually do the 5' shower wall's or window's. Maybe theirs another that can help with the experience. |
#19 |
improving homes
Trade: Roofing/Remodeling
Re: Glass Block
I have used both the silcone and the mortar method to glass block walls and I will tell you that I will not use the silicone system unless it is a small glass window fully supported on all 4 sides. I tried to use silicone on a wall that was 3' wide by 5' tall and supported on the bottom, one side and the top. Used the wall ties to tie it into the wall for strength and it was really weak and I didn't feel comfortable leaving something that had the potential to come down if someone leaned on it. An 8'x10' wall I would not even think about using the silicone method, you will want to use the mortar so if someone leans on the middle of the wall it won't bust out.
http://www.platinumcontractingappleton.com |
#20 |
DRIFTWOOD
Trade: GEN CONTR.
Re: Glass Block
Years ago We did hundreds of Pittsburg corning Blocks. Always mortar.
400 for a bowling alley once. I,ve seen people screw them up often! Some fun, On a wet saw. I cut the tops off at about a 16 degree angle . Nice for flowers,sea shells ect. With a glass drill You can drill a hole and put white Xmass lites in. Nice nite lite for a child. |
| The Following User Says Thank You to Driftwood For This Useful Post: | DQM (03-13-2009) |
| Glass Block 411 | andeeznuts | Remodeling | 14 | 01-22-2009 08:17 PM |
| granite slab on a glass block wall | Mr. D | Construction | 3 | 05-03-2007 06:57 AM |
| Glass Block Transition | Paul_NJ | Ceramic & Stone Tile | 0 | 03-15-2007 08:14 AM |
| Question on Glass Block reusing | TurnkeyConst | Flooring | 0 | 02-26-2007 10:44 PM |
| glass block entry to shower | Mr. D | Masonry | 10 | 12-04-2006 02:14 PM |
