Deck Designer/Builder
Garage/Shop Preparations
My GF and I have purchased another home (not the one I was asking about a month ago - a different one in a LOT better condition) and will be moving at the end of March. The new house has a detached 16x20 garage that I will be taking over and making into my shop. I've already laid the ground work for this with her - I've told her all the decisions in regard to the house and what we do/don't do are all up to her but the garage is mine to do with however I see fit
1. My biggest concern is security. The garage has a single garage door with a garage door opener, 2 regular entry doors at the back of the garage on either side and 2 large windows (back and side) about 36"x36", give or take. First thing I plan to do is add deadbolts to the entry doors, the kind that are keyed on both sides. The question I have here is what is the best thing for me to use to secure the windows - they're single pane glass and would be pretty easy to break into. I don't want to lose the light so what would be the best way for me to secure the windows, metal grills or something else? 2. The walls are framed with 2x4's and not insulated. What would be the suggested method of insulation/finishing the walls? I know I could insulate with fiberglass insulation and drywall but I was looking for alternatives. Keep in mind it will be a shop and the walls will end up having peg board, work benches and shelving along most of them. 3. Further to the insulating question. If I am going to go ahead with insulating the walls, I realize it would be a waste to not do the roof at the same time. The garage is open to the roof with loose boards laid over beams to make a makeshift ceiling/storage area. I don't want to lose storage space above the "ceiling" by closing it off. Will insulating the ceiling trusses be enough? Keep in mind I'm not winterizing it - I just want to keep it more comfortable to work in during the winter & summer. 4. Also, any tips, suggestions or ideas on how best to set up the shop. I realize everyone has their own preferences, it's just that I am working with a blank slate here and would love to hear ideas from others on how they have or would set up a shop if they had the opportunity I'm getting. I am thankful for any and all suggestions for my questions above and I know pictures would help but I won't have the opportunity to take any until March 27th (the closing date). Last edited by DecksEtc; 02-09-2006 at 02:15 AM. |
Trade: General Contrator
Re: Garage/Shop Preparations
Definatly insulate that shop!! I bought my house last fall didnt insulate and was miserable all winter. This summer I insulated walls and ceiling and am loving it a comfortable 55*. I also have storage in my attic above so i just used wall insulatin r-19 i think. Isnt as efficient as other stuff but does the job good enough.
If you are planning on putting peg board up so you can hang stuff. I found out its best to figure out how much shelving peg board, ect youll need then put 7/16plywood where you need alot of support. I used plywwod for the first 8' then sheetrock for the last 2'. Worked out perfect for my shelves that are 2' below the ceiling. Another big thing is build a bench thats TUFF. I made one of mine about 3' deep and about 42" off the groung with a 1/4 steel plate on top so it can take a beating. Hope that helps. GoodLuck |
I'd make sure my TS, jointer, planer and lumber storage were in-line with the garage door. You want to be able to move everything right out of your truck and into/onto your equipment. Swinging a 16' piece of lumber, hitting everything in sight gets old.
My garage doors are wired to a dedicated light switch so the power can be turned off to them. After I know I'm in for the night, the power is turned off to the doors. I'd also go with plywood 8' up. I hate pegboard. I'd also go with metal grates on the windows. My garage is attached and the entire dwelling is wired for home security. EVERY single door and window has a sensor along with a few motion and sound detectors. If I didn't have the security, the garage windows would definately have metal grates. I'd run 220 out there...compressors, welders, etc. A few 110 outlets on the ceiling is convenient. Don't know how carried away you want to get, but if you plan on painting the floor, do it now with a quality expoxy/paint before any equipment gets in. All kinds of other stuff, but I'm running late this morning.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Trade: carpenter
attic space is nice...
Remodeler
Drop cords from the ceiling. Be sure to layout any saws, planners, etc so the work will flow between them. Try and make all tables the same height as your machinery as they can be used for supports between machines. Seeing you do decks make sure to setup lumber storage so it is easy to get to and near where you will use it first.
I'm jealous, fun setting it up. The insulation goes without saying. Dust collection is a nice thing to have. Maybe a skylight for natural light. |
Thanks for the tips thus far. Keep them coming!
A lot of the ideas given are things I was thinking of doing - the confirmation is nice to have. I plan on putting my two existing work benches on the side away from the garage door. Sounds like I'll be going with plywood over the insulation that way I don't have to worry about hitting the walls and putting holes in the drywall. Plus, the height to the existing "ceiling" is about 8' so I'll probably fore-go drywall altogether. I have a dust collection system I am going to recycle from my Dad's basement and an industrial size belt drive table saw (on wheels) that I cannot wait to get into the new shop. Another question, about the power... The garage has existing electricity - it's only a 15A circuit on 14/2 wire that runs to a couple of plugs, a couple of fluorescent lights and the garage door opener. I realize this isn't nearly enough power for what I need. Our short to long term plans for the house are to blow out the wall of the house closest to the garage and expand the house in the direction of the garage. We will either incorporate the garage into the addition or turn it and move it to the side lawn - we haven't decided yet. Anyway, back to my question. My eventual plans are to wire 220 to the garage with a separate 60A breaker. In the mean time would it be feasible/practical to put a dedicated panel with a 15A breaker between the wire coming into the garage and everything in the garage? I ask this for 2 reasons: 1. I want to be able to reset the breaker when it trips as opposed to going all the way into the house and reset it and 2. I don't want to waste the time, effort and expense of running conduit and wire back to the panel when I'm probably going to change/replace this once we start renovations in the fall. Thanks again! Last edited by DecksEtc; 02-09-2006 at 01:35 PM. |
Trade: builder of stuff, real nice stuff
You will need a fridge, (at least I do) how about Rebar criss crossed over the window? Might be able to use bigger opnenings then mesh. The power situation kind of sucks. wont be running much at once until you get that fixed. Cool though I am planning my shop to build it in the end of July or August. 32x48 with radiant floor
For windows, eveytime I build a garage for a shop or car guy I always recommend using a slider style so it keep the window up and out of the way of benches and typical waist high beating with grinders and such. typical double hungs hang too low if it's an older taller style window.
Windows themselves, assuming these are older sinlge barn sash type units would be replaceing with some "bullet proof" lexan/plexglass, you can get it in about any thickness you deisre, 1" is more than enough to stop any would be baseball bat weilding thugs. Or you can go with windows that are hurricane rated. We recently did an security upgrade for a doctor and his wife-long story but the guy that stalked and damn near beat her to death after he raped her got out after a 17yr stint and they were nervious he may come back for vengence. Anyways, for all their windows/patio door we installed some very expensive hurricane rated units, they are supposedly capable of stopping a 2x4 shot at 150mph from 5', so it should be enough to stop/slow down the azzwipe and make enough noise that she has time to get into her safe room and call for help. Definately plywood down low for durablity and ease for shelves/hangin things. You shop is small enough, to maximixe ceiling space install the poly chutes under the sheeting, finalize you wiring and have the sprayed on insulation installed. Better r value and allow you get gain alot of attic sspcae that way.
Hot Rod Work Van ![]() Car video clip Web The Photo Gear- Type Josh into Contact name when ordering Last edited by IHI; 02-09-2006 at 05:08 PM. |
Just maybe a few 'room-saving' ideas I'll run by ya' here.
The first picture shows my cabinet saw, - - it's set just a few inches from the overhead door, - - that way the stock feeds OUTSIDE, - - there's also an overhead aluminum awning out there to keep the stock dry even if it's raining. Those 'out-feed' rollers (about $250) you see fold down against the saw when not in use and still allow the overhead door to close. I inserted the router set-up to get more use out of the extension table, - - and as you can see, - - I hooked on an auxiliary router fence to the saw fence to be able to use either/or with no set-up changes. In the second picture you can see that my 13" surface-planer ships the wood right through the cut-out in the wall, which has a removable door, and also doubles as a mail/drop-off slot. I'll sometimes feed the wood through the planer and right onto the truck. At the front of the picture, you can see the top of my 20" planer, which I can get away with having more towards the center of the shop, because I mainly use it for short-work, such as raised-panels and such. It's all about getting the best use of the space you got, - - 'cuz I don't care how much it is, - - It's never gonna be ENOUGH!! Good Luck with it.
http://www.tr-built.com Last edited by Tom R; 02-20-2006 at 06:44 PM. |
#10 | |
Re: Garage/Shop PreparationsQuote:
Nice shop and very nice equipment. I don't recall seeing a fridge in there, how do you keep the brew cold? Jeesh with all those toys out there I bet Mrs Tommer has to go out there every once in a while and drag you into the house by your ear. See Ya!
Interior Remodeling
Trade: Interior Remodeling
Hey Tom,
Where did you get that roller table on your table saw? I have a similar sized workshop and am in the process of reorganization. I like the holes in the walls for the outfeed tables too. |
#12 | |
She just tells me to save some room for a BED out there!!
http://www.tr-built.com |
Thanks for the visuals Tom. I won't have quite that much space or that much equipment for that matter. Also, it will be a work in progress. At first I'll just be moving over my existing stuff plus bringing the cabinet saw up from my Mom's place. Seeing your wall cabinets did give me a thought though. We're going to be gutting the kitchen and bathroom in the new house so I'll recycle the old cabinets into the shop.
At first, my biggest concerns are the security, insulation and power issues, oh and the FRIDGE |
#14 | |
I do remember they ran around $250, - - and they'll fit most, if not all, saws. Basically, you just gotta drill a few holes in the back of your cabinet for attachment. Just takes a little extra playin' around to line 'em up perfect, - - they need to be set dead-on with the plane of your table, - - in both the up and the down position, - - because even in the down position, one row of rollers is being used. But once they're set, - - they don't 'move' on ya'. They real sharp, they 'release' with just a push with your foot.
Here ya' go, K, - - I can't get the URL to work, - - but if you just go to Amazon.com and do a search on 'outfeed rollers', it'll come right up.
GC/ Master Electrician
That 15A circuit is not gonna do much with the shop lights on it too. If your gonna cover the walls with plywood why not install a $50 100Amp workshop panel. Just run the service overhead and make sure its bonded. Total cost depending on the house panel wouldnt be more then $200 or $300 and it would all be reuseable after the remodel/addition. Just my 2 cents.
Ken |
#17 | |
Interior Remodeling
#18 | |
I like the idea of a 100A panel but the house only has 100A service and we wont be in a position to upgrade the panel right away. The most I think I'll have room for is a 60A panel to the garage. So, this begs the following questions... What gage wire do I need to run to the shop for a 60A panel? The main panel is at the far end of the house, about 40-50 ft. from the garage. Do I run conduit along the outside of the house to the closest corner and then up the side of the house to get to the right height before I span the distance between the house/garage? Is it okay for the wire that spans the space to be exposed i.e not in conduit? If I can collect all the right info, I'd be doing all of the grunt work as far as running the conduit, wire, panel, etc. and then just get an electrician in to do the hook-ups so I pass the inspection. |
#19 | |
