French Door Install On A Not So Level Floor - Remodeling - Contractor Talk
Old 08-11-2017, 07:33 PM   #1
Remodeler
jhicks226's Avatar
Rewards Points: 26
I need to install an exterior 6' french door on a concrete slab that is 1/4" out of level. What is the best way to level this up? I was considering a self-leveling underlayment- any thoughts?
Thanks!
jhicks226 is offline
Old 08-11-2017, 07:45 PM   #2
Tom M's Avatar
Rewards Points: 7,726
Re: French Door Install On A Not So Level Floor
That's not a terrible idea if you have the patience to make up a form.
The last couple I did I opted for a cup wheel on a grinder and took out the high spot.
Tom M is online now
Old 08-11-2017, 07:56 PM   #3
Remodeler
jhicks226's Avatar
Rewards Points: 26
Yeah, that's the way I would go if it were just high points, but this slab is sloped, so I would be taking out more material than I care to.
Old 08-11-2017, 09:37 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,607
I'd shim it. Long tapered shim.
Tinstaafl is offline
Old 08-11-2017, 10:03 PM   #5
TimNJ's Avatar
Rewards Points: 3,146
1/4" in 6'?
I wish half the houses I have to work in were that level.
Shim it and make sure there is enough support under the sill so when everybody steps on it, it won't move.
TimNJ is offline
Old 08-12-2017, 08:28 AM   #6
gbruzze1's Avatar
Rewards Points: 2,608
Shim it, get the installation done, then fill the void with dry pack
gbruzze1 is offline
Old 08-12-2017, 09:29 AM   #7
VinylHanger's Avatar
Rewards Points: 8,182
Just install it, nail the side fins, then support it with whatever.
Also, if it is only a 1/4 inch, you may be able to just install it to the slab slope. It should run with the siding. The last single window I just installed was 2 inches out of level in 4 feet. However, so was the shed. Best opening and closing window I ever did. :grin:
VinylHanger is offline
Can someone help me with this old level? Currahee General Discussion 15 03-20-2013 12:48 PM
level sub floor fugsly Flooring 5 02-16-2013 11:41 PM
Cross-laminated PE vapor barrier under floating floor after leveling with sleepers sjkm Flooring 11 06-14-2009 10:03 AM
Getting the first floor perfectly level... OntarioFramer Framing 8 05-06-2006 07:14 PM
