wannabe
Trade: carpentry
Floor Protection
We just started a good sized remodel...mainly a 2 story addition, with some alterations to the existing home. This project is likely to last 6-9 months....
There's going to be a LOT of traffic on old DFir flooring....I imagine all floors will be sanded and re-coated later... We buy scrap card board by the pallet from a local container company....so we rolled out 6 mil plastic then put down card board and taped. No doubt we'll be pulling it all up in a couple months and re-doing. Anyway, it made me curious about what some of you folks do to protect your projects when you know you'll be there a while ( BTW, No one is living in the home!) Just for S&G's, I took some pics of the project, but not the floor....That'll be my next post.
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... Last edited by WNYcarpenter; 10-01-2009 at 08:45 PM. |
Re: Floor Protection
We freshen up a little more often, but red rosen paper and blue tape is usually our sop. If we are on a real highend floor, i will also drop cloth the whole area.
topsail's trimcat
craft paper or plastic taped down first, then wall leveller we salvage off houses which we re-side, and then osb.
wall leveller we get free as its pulled off houses, osb is thicker and cheaper than masonite
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake |
wannabe
Trade: carpentry
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
Its all ball bearings
Trade: Tile
I have done kitchen remodels over existing hardwood. First, uber-clean the floor of any debris. I use a layer of rosin paper, layer of cardboard (from cabinet boxes) and then a layer of luan...all taped at the seams. Since a kitchen floor isn't that big (typically), it has been cost effective so far. I have read about products that are made for this application I have considered.
Single use and cheaper: http://www.blakeproducts.com/index.a...TS&Category=42 Reusable but more expensive: http://www.blakeproducts.com/index.a...TS&Category=41 Just saw this on here a week or two ago. Looks decent: http://www.ramboard.com/
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Trade: Carpenter/GC
Re: Floor Protection |
Trade: Custom Home Builder
I have used red rosin paper in the past with 1/4" masonite over top. I duct tape the masonite togeather.
I will never use red rosin paper again as I had one instance when the paper got wet and the red dye leached into the wood floor and stained it. Check out protectiveproducts.com they have some great products for hardwood and carpet. The tub protection works like a champ as well. |
I have been pitching ramboard here since I have seen it on a few jobs ans seems really nice. Little expensive for the taste of many here.
O yea, we have also used carpet remnents to protect floor, just make sure you place the abrasive backing up, i once came in and a couple of guys where placing the carpet good face up
, The underside of many carpets will scratch the **** out of any wood floor(carpet padding works well also). Of coarse on a reno that you know the carpets are coming out, leave them down as floor protection till the last minute. G, man i am home recovering from surgery, thank god for CT.
#10 | |
Re: Floor ProtectionQuote:
Didn't know you had a problem. I do envy your perks, you certainly have a good lookin' nurse.
| The Following User Says Thank You to neolitic For This Useful Post: | genecarp (10-02-2009) |
#11 | |
across carpets, and especially for stairs. http://www.dropcloth.com/cleanandsafe2a.html BTW: We have a sticky..... http://www.contractortalk.com/f18/du...odeling-31707/
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 10-02-2009 at 12:07 PM. |
Builder/Remodeler
I use Dow Protection Board III quite a lot:
![]() ![]() It's about $35 for a fan fold unit... 3'x50'.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
#13 | |
Builder/Remodeler
I looked for one, but all I could find was a DOW spec page with no pic.
#15 | |
This stuff already has a plastic sheet laminated to it and reinforcements so it ddoesn't tear, so you can elimintae the multi-layer approach. you still need masonite or whatever for the really heavy areas with equipment on it like someone said, but otherwise this is a one and done solution. waterproof too. |
#16 | |
Builder/Remodeler
Sorry, it's actually 4'x50'...
#17 | |
), where did you buy it? BTW: What I like about the Clean&Safe is that it's easy to roll up and redeploy in occupied homes.
#18 | |
Builder/Remodeler
I'd like to find some other alternatives... this stuff is not exactly GREEN... But I like that it's waterproof and gives a bit of cushion--and is easy to cut and form to wherever we need it to go.
#19 |
Trade: Home Improvement General Contractor
Masonite, the thinner stuff. It runs about $6.00 for a 4X8 at the box stores.
I like the stuff you posted Chris, but I'm too damn tired to do the math to see the cost comparison with masonite.
"Enjoy Every Sandwich" Warren Zevon |
#20 |
wannabe
Trade: carpentry
That's exactly what we did today over the cardboard...2nd floor demo with carpet, so we used it to protect the hard wood better.
Thanks Neo, the idea to post this question just came to me during the jobsite prep. I should frequent this remodelling forum more! My compnay can be 'penny wise, pound foolish' at times. Projects like this always have a grunt. Some of our long time employees have their ways and like to give the low man a project like pulling the protection and re-laying new stuff. 'Busy Work' if you ask me...if we invested a little more in protection materials, we'd save $$ IMO.
