Flexible AL Foil Duct For Bath Vent
Old 06-09-2017, 07:25 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 974
We have about a 25' run in a basement bath, through ceiling joists, which takes (2) 90 degree bends along the way.
My experience is that venting for moisture, wherever there is drywall, should be sheet metal. I've replaced this foil coil in short runs (through accessible attics) that develop pinholes and slits in it, after a short number of years.
Not only is sheet metal sturdier, it is better shaped for internal moisture (no "continuous wire" catches).
Anyone using this for reasons beside cost and ease of install?
artinall is offline
Old 06-09-2017, 07:57 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,126
Re: Flexible AL Foil Duct For Bath Vent
Don't much care for the aluminum stuff; too delicate and generally a PITA to work with.
I prefer insulated plastic esophagus. Tough, flexible and a heck of a lot easier than rigid sheet metal. Plus, you really ought to have that insulation.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
artinall (06-09-2017), overanalyze (06-10-2017)
Old 06-09-2017, 07:59 PM   #3
artinall's Avatar
Rewards Points: 974
Where do you get this from?
artinall is offline
Old 06-09-2017, 08:09 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,275
the 4" x 25' insulated flex stuff will restrict air flow too much at that full length. How come you don't have a closer wall?
MarkJames is offline
Old 06-09-2017, 08:16 PM   #5
artinall's Avatar
Rewards Points: 974
Room sits on the other side of a garage/poured slab entry.
artinall is offline
Old 06-09-2017, 08:39 PM   #6
Capra aegagrus
Tinstaafl's Avatar
The box stores carry them in 25' lengths.
As for Mark's note about restrictions, I haven't found that to be a problem. I doubt rectangular metal ducting would fare any better, with sharp 90 turns. In either case, an inline booster would take care of that.
Old 06-10-2017, 06:50 AM   #7
ChatsworthCA123's Avatar
Trade: Scheer Construction - Chatsworth
Rewards Points: 24
Yeah I'd be careful with that.
ChatsworthCA123 is offline
Old 06-10-2017, 07:03 AM   #8
artinall's Avatar
Rewards Points: 974
Are you talking about Thermaflex ? http://www.homedepot.com/p/Thermafle...B&gclsrc=aw.ds
artinall is offline
Old 06-10-2017, 08:30 AM   #9
Capra aegagrus
Tinstaafl's Avatar
Yep, that would be one brand.
Old 06-10-2017, 08:51 AM   #10
Rewards Points: 24
Are you talking about Thermaflex ? http://www.homedepot.com/p/Thermaflex-KP
-- viglink huh? Weird way to try to score some affiliate cash... either way though, California has had some weird things happening getting enough of the thermaflex for some reason over the past couple weeks. Not sure what's up, something wrong with the suppliers?
Old 06-13-2017, 10:22 AM   #11
artinall's Avatar
Rewards Points: 974
Originally Posted by ChatsworthCA123 View Post
-- viglink huh? Weird way to try to score some affiliate cash... either way though...
You're implying that I'm getting a kickback for the link?
Now you show me exactly how that is happening.
Maybe you should actually know what you're talking about before you post.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
MonsieurBon (06-13-2017)
Old 06-13-2017, 05:54 PM   #12
Capra aegagrus
Tinstaafl's Avatar
I don't think so. Anyone who understands Viglink knows it's installed by the forum owners to squeak out a bit more ad revenue. He was just commenting on the fact it's installed here.
artinall (06-13-2017)
Old 06-13-2017, 10:25 PM   #13
Designer/Contractor
Rio's Avatar
Rewards Points: 772
Definitely want a booster with a 25' run and 2 90's...................
Rio is online now
Old 06-24-2017, 12:05 PM   #14
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 168
Only being a bath fan, I don't think the length is much of a factor if the flexible duct is stretched out properly and ran with as few bends as possible. Of course, one would like to keep the run shorter. We only use the insulated flex duct for bath fans. If done right, there has never been an issue. The aluminum flex is garbage, imo.
I would never use it for a dryer vent or range hood vent but bath fans are usually pretty light, CFM wise. In any of our new construction, we are recommending HRV's be installed as well so there is some dehumidification and constant air exchange without too much energy loss. Air exchange has become a big code issue up here in BC. The inspectors are all over it.
Ernie in Dawson is offline
Old 07-25-2017, 01:15 PM   #15
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,552
Who is this clown
A&E Exteriors is online now
Old 07-28-2017, 01:31 PM   #16
KitchenAndBath's Avatar
Trade: Kitchen and Bathroom Renovations
Rewards Points: 252
Totally agree with this! Was my first thought when read the post
KitchenAndBath is offline
Major Water Condensation in Furnace Flue Vent in Attic - Drywall Damage seaweed HVAC 11 01-13-2014 08:51 PM
Noisy Flexible Vent Pipe From Bathroom Exhaust Fan? Chris Sweeney HVAC 21 03-13-2013 03:08 PM
Question about vent work licensed-trim Finish Carpentry 9 03-06-2010 01:37 AM
Practical Discussion about Bus Duct ricky001 Electrical 4 08-26-2009 07:36 PM
Metal ducts or Flexible duct in use? Charlot HVAC 2 10-30-2008 04:52 AM
