Carpenter/fencing
First Time Framing With Steel Studs
I'm remodeling a new store for a friend of mine ,its my first time using steel studs.it was much easier than i thought,didn't even have to cut too much,we used full size 10's and 12's for the walls.Took more time to plan for the theater room than it took to frame half the store,Its going to be a high end store :theater,audio and video. built a big office,a small office,three closets,a conference room and a 19' x 21' theater room.i'm going back tommorow to frame out the theater room ceiling and build a two level stage for the seating.The theme is going to be roman ,we got some awsome plans for that in the up coming weeks.I'm very excited and can't wait to warm up my table saw.
Learning without thought is labor lost; thought without learning is perilous. |
It's all about the Avatar
Trade: I have no face!
Re: First Time Framing With Steel Studs
I have never seen a wall built with steel layed on the floor like that. It appears to have worked for you so wha-hooo for you. the wood in the doors and windows is good for hanging the door and attaching casing, our guys use track on the sides and line that with scrap 2x4 this way the wood does not bend the side studs when drys and warps....and you can frame to the required R.O.
#3 | |
Re: First Time Framing With Steel StudsQuote:
Very nice job on the Steel framing Nywoodwizard. FWIW-We like to use fir studs for the door openings (straighter)...
- Build Well - |
The way we do it is lay the gid for the T-bar or Suspend drywall then attach to it, goes real fast........
Home Repair Specialist.co
Trade: carpentry
Check in too the nail guns for the trim work your base boards they make nails just for that shoots right through the ten can stds
#6 | |
Carpenter/fencing
Re: First Time Framing With Steel Studs |
#8 | |
I guess it all depends on the design and function of the space. Medical areas require going to the top deck (soundproofing) Some office layouts just want open partition walls = No ceilings. Etc...
- Build Well - |
Carpenter/fencing
Finished up the metal framing,and just finish up the wood framing yesterday got the theater room seating platform done,the platform will have an arch over it with two collums sitting on the knee wall,ceiling with projector lift opening done.just waiting for the electrician to finish and then the drywall,in the mean while i'm trying to design something for the theater room screen wall,we've pick a roman theme.I found an idea i'm going to build and have the screen drop down out of. I'm excited and can't wait to get started on it.
Working with steel is so easy. im currently doing a commercial space where the owner made many changes with the layout. I practically moved entires walls with ease. Try that with wood.
#11 | |
Carpenter/fencing
| Framing Nailers | dfoldoe | Tools & Equipment | 17 | 07-16-2008 12:15 AM |
| glass coated steel | haskl33 | Excavation & Site Work | 3 | 10-23-2007 11:33 AM |
| Steel framing | trekr | Construction | 3 | 01-07-2005 07:18 PM |
| Steel Framing Alliance. | boardslinger | General Discussion | 0 | 05-10-2004 11:00 PM |
