Filling Nail Holes In Trim
Old 01-24-2011, 04:57 PM   #61
lshomesolutions's Avatar
Rewards Points: 75
Re: Filling Nail Holes In Trim
Dap crackshot is what we use
lshomesolutions is offline
Old 01-30-2011, 07:16 PM   #62
The Dude
smalpierre's Avatar
Trade: home improvement
Rewards Points: 1,946
I usually paint my own work. I fill with wood filler, and use a wet rag when it's dry. I shoot 15 ga. into framing for most trim, 18 ga brads into other trim for small stuff like shoe. I have used the pink vinyl spackle, but only to fill nail holes in old drywall when I don't already have a mud pan going, but we're talking about trim.
I would never use caulk. A painter I used to use used caulk for everything. I didn't like it, and he refused to use something that wouldn't shrink / show nail holes. He also liked switching up paints, and all but refused to oil base doors / trim even though I specified before he bid. He used latex on a job I spec'd oil on, and that's why I paint my own jobs now. Less hassle, and I make more money. I got to where I only have a sparky, and a plumber. I only have a sparky because of licensing, and I'm working on fixing that too. My plumber is awesome though
Edit: I have a cabinet guy too, because I don't want to invest in the equipment. He works alone, and when I asked him why he has 3 huge table saws - "one for rips, one for crosscut, one for dado ..." Not an investment I want to make unless he pisses me off REALLY bad
Last edited by smalpierre; 01-30-2011 at 07:24 PM. Reason: Oops!!! I forgot someone!
smalpierre is offline
Old 01-31-2011, 06:56 AM   #63
Vice President
designbuildnj's Avatar
Trade: builder/general contractor
Rewards Points: 25
Yes I know my friend, sometimes it can be more cost effective to sub work out ssuch as the painting of cabinets, I think I would do the same tking.
www.designbuildnj.com
designbuildnj is offline
Old 01-31-2011, 11:51 AM   #64
Ole34's Avatar
Trade: Painting Contractor
Rewards Points: 75
glazing for NC or jobs not worth the effort...........wood filler and a rag for most jobs...........wood filler and sand paper for a glass finish
on average i use wood putty and a rag for all the low work and putty/sand paper for anything eye level
Ole34 is offline
Old 02-13-2011, 12:28 AM   #65
Archbishop of Titipu
Sweebs's Avatar
Trade: Residential Remodeling
Rewards Points: 75
Minwax Stainable Wood Filler, interior/exterior,
accepts oil, gel and water based stains
latex based, quick drying, sandable, soap & water clean up
Sweebs is offline
Old 04-10-2011, 03:19 AM   #66
vwnuck's Avatar
Trade: general contracter
i use pink dap drydex on nail holes, don't put heaps on just enough to fill the hole. sand and you are good to paint. i caulk the top with painters caulking... that seems to work well... the drydex if you put enough on it has limited shrink....
vwnuck is offline
Old 04-12-2011, 09:01 PM   #67
dmr2701's Avatar
Trade: home remodeling and business remodeling
Pink Dap Spackle (Drydex) is the best I've used. Done well, there is very little sanding and it doesn't shrink hardly at all. Also, changes color when it's dry. Doug w/ D&S, 36 years exp.
dmr2701 is offline
Old 07-08-2011, 09:40 PM   #68
hewdamwright's Avatar
Trade: siding/remodeling
latex chaulk good but flashes as well as auto filler wtf which flashes worse wood filler is good but even the stainable shows i quit buying small cups of filler for five bucks to just sit on the shelf and get hard after awhfile if you do drywall repairs you should have a bag of twenty minute drywall mud this stuff dries fast hard as concrete sands eazy hardly ever flashes doesnt set on the shelf and get hard but its not stainable
hewdamwright is offline
Old 11-01-2011, 12:32 AM   #69
hgoldfein's Avatar
Trade: remodeler
dap fast and final. or sometimes we use 20/20. structo light for gaps.
hgoldfein is offline
Old 01-08-2012, 06:30 PM   #70
Robinson_Cnst's Avatar
Trade: general contractor
Rewards Points: 109
Crawfords hands down. Easy to work with and sands like butter.
Robinson_Cnst is offline
Old 01-08-2012, 06:32 PM   #71
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
I use drydex, and sometime I used the PL wood filler. Depends on the job both work great for me.
Tylerwalker32 is offline
Old 01-08-2012, 07:01 PM   #72
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
I use Drydex for paint grade work.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 01-14-2012, 01:04 AM   #73
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Anyone use durhams water putty?
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 01-14-2012, 01:27 AM   #74
Dirtywhiteboy's Avatar
Rewards Points: 8,044
I like the Pink stuff too
Dirtywhiteboy is offline
Old 01-29-2012, 12:22 PM   #75
andeeznuts's Avatar
Rewards Points: 150
the little blue lid of spackle not sure of the name but roll up a ball and let it dry out a little then fill wipe with your and and ready for paint
andeeznuts is offline
Old 01-31-2012, 04:09 PM   #76
Squidhead's Avatar
Trade: Home Improvement
I used to use light weight spackle but I would occasionally miss areas on the clean up and have globs of now hardened spackle that are painted over. I never thought about the pink stuff for it. At least I can see if I miss a glob of it. I'm going to try it tomorrow. I was using DAP painters laytex and still will for along the edges. The corners, splices and nail holes that stuff has been giving me trouble with shrinking the last couple years. Especially this time of year when the heats on.
I considered using window glazing but I thought you HAD to use oil base for that to cure?
Squidhead is offline
Old 01-31-2012, 07:58 PM   #77
Repair & Renovation
Rich D.'s Avatar
I just used the white ellmers wood filler in the squeeze tube. Dried fast.. I liked it. Will buy again
The pl solvent based wood filler in the can is very good also. Just smelly!
Alex fast dry for all seams and on top of trim.
Rich D. is offline
Old 01-31-2012, 08:00 PM   #78
Repair & Renovation
Rich D.'s Avatar
Never heard of that? I've used the stuff and it dried without the paint no problem
Rich D. is offline
Old 01-31-2012, 09:23 PM   #79
The Pink stuff only Pink when it's wet,, when dry it's white and ready to sand.
Old 02-01-2012, 07:32 PM   #80
Squidhead's Avatar
I went to the DAP website. It used to say "use only" oil based paint unless you let it cure for a few days. Now the lable just reccomends using oil based paint. That was the canned stuff. The laytex tube just says let it dry then paint it with anything. It also said it took several days to dry. I used to like the DAP "33" stuff in the can because it would mold real nice into the crack and when you painted it, it would smooth out with the brush and the joints where undetectable.
Used the Pink stuff today and I wasn't too impressed. I guess I'll keep on trying until I get something I like to work with. I have quite a few Crown jobs coming. Maybe I'll try the Elmers again.
Filling Small Holes in Vinyl Siding slickshift Windows, Siding and Doors 9 07-05-2008 08:33 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
Quickest, best way to fill prefinished hardiboard trim nailholes? pinesol Painting & Finish Work 8 07-31-2007 06:47 AM
Nail holes and cleaning Tom M Finish Carpentry 7 06-16-2007 08:43 PM
filling nail holes on white trim Traditions Painting & Finish Work 11 08-26-2006 02:24 AM
