Filling Nail Holes In Trim
Old 05-19-2007, 07:13 AM   #21
daparsonshsc's Avatar
Trade: General Contractor, Remodeling
Rewards Points: 16
Cool
Re: Filling Nail Holes In Trim
I use Sherwin Williams 955A Latex Caulk on wood to drywall and seams that are to be painted only. It's durable and expands and contracts with the season. You can paint right away. On nail holes I use Minwax stainable filler, for painting only. It does not absorb stain likes it says it does, but it makes a great filler because of its sanndy texture. On stain jobs I fill the holes with something thats matches after the wood has been stained.
daparsonshsc is offline
Old 05-21-2007, 08:10 PM   #22
Builtbybeck's Avatar
Rewards Points: 25
Dap 33 is awsome under oil paint but I found out the hard way it yellows latex paint, even latex primmer! I used to realy like the lightweight spakle that goes on pink and dries white but I can't find it anymore. I've been using various brands of easy sand lightweight non shrink fillers. there all about the same except The stuff pictured early in this thread is not, in my opinion, easy to sand, I tried it on some crown moulding! It's more like a latex version of the old miracle wood stuff. I always overfill a bit and sand when it's dry but had a painter tell me he smooths the lightweight spakle out with his finger and paints it without sanding when it dries!
Darin Beck
Beck Construction and Remodeling
Commmercial construction, renovations, and government contracts
www.BeckConstruct.com
Builtbybeck is offline
Old 05-22-2007, 12:55 PM   #23
rjordan392's Avatar
Rewards Points: 75
I agree with daparsonshsc.
I prefer to stain wood first, then match the color with the available stain sticks. In some cases, I have used childrens crayons and it seems to work well. I just push it in and wipe smooth with a damp cloth. When doing it this way, you do not want to use anything abrasive on the wood as you will just mess up the area surrounding the hole.
rjordan392 is offline
Old 05-25-2007, 07:22 PM   #24
JPF's Avatar
Trade: Handyman Services
Rewards Points: 75
This works great for me. Just wipe in with your finger, dries quick, almost don't have to sand at all........
http://www.sherlink.com/sher-link/ca...lyDetails=true
JPF is offline
Old 05-26-2007, 12:36 AM   #25
C.C.R.'s Avatar
Trade: Remodeling contractor
Rewards Points: 250
Originally Posted by twlinks View Post
Sure, slap it up, bang it full of holes and then HOPE the painter is going to do a good job of filling YOUR holes before he paints. I know that in a lot of areas, the painter is expected to fill the holes...however, my contention would be "Why would you trust someone else to do that?" If he does a crappy job, it's a reflection on your work as well as his.
Just my .02 worth, but I'm not trusting my work to anyone else.
I say it's the painter's job because on my jobs it is the painter's job. When I hire them I make sure it's part of the contract. If they do a
sh-ty job filling then they go back and do it again, and again, and again if necessary then they get paid.
If you don't know the painter or you don't hire the painter (My job - My sub) then yes use the smallest nails suitable for the trim and then fill I like "MH Patch" (red and black can) if not available lightweight spackle.
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline
Old 05-26-2007, 02:46 PM   #26
Teetorbilt's Avatar
Rewards Points: 2,000
Many times we are the painters as most contractors don't want to be bothered with just a little base & case in a bath or two.
Albert Einstein
Teetorbilt is offline
The Following User Says Thank You to Teetorbilt For This Useful Post:
SK Remodeling (01-23-2011)
Old 05-26-2007, 10:28 PM   #27
Remodeler Extraordinare
A.W.Davis's Avatar
Rewards Points: 510
Lately I have been using Dap "Plastic Wood" and havent had any problems
http://www.dap.com/product_details.aspx?product_id=69
plus it smells real nice
A.W. Davis Construction Co.
http://www.awdavisremodel.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 05-14-2010, 05:13 AM   #28
Sponge
tyler durden's Avatar
Rewards Points: 150
Everything seems to shrink some what.
That is the main problem, needs 2 coats
tyler durden is offline
Old 05-31-2010, 09:58 PM   #29
Ultimate touch
ultimatetouch's Avatar
Trade: General contractor, Remodeling
I use the pink dap spackle
ultimatetouch is offline
Old 05-31-2010, 10:10 PM   #30
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
I like using caulk, but it always shrinks up and has to be done again.
I typically use spackle out in the field because shrinkage is minimal, getting your job done faster.
I don't use sandpaper on spackle, I just normally run a damp rag across it, cleans right up, ready for paint.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 05-31-2010, 10:22 PM   #31
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
it can go both ways, sometimes a painter is so good, they want to fill the holes. i am always wondering the BEST stuff to use to fill holes. if i use the wrong stuff and the painter complains to me that they shrunk etc. then i look bad. THE PAINTER is fully responsible for the finished product looking smooth with no signs of a nail anywhere. if he can't do that, then he's not a real quality painter. I rarely fill nail holes unless it's a small project that I have to finish myself. I hate painting. priming I do no problems but I hate painting. I only paint at my house.
ApgarNJ is offline
Old 05-31-2010, 10:38 PM   #32
AustinDB's Avatar
Rewards Points: 464
on nice jobs I'll use a SW spackeling paste, comes in a small tub. by the time I fill, wipe, caulk (in the case of crown, casing or base) and it's a warm enough day, make the second trip around the room and touch up. I've got the touch and usually leave it frationally proud the first time, so when it's time to paint a light sanding knocks it down. Be sure to get the sandable version.
I started off with using the same caulk I caulk the edges of the trim (SW 950, 850 or Alex 230 is my #1 choice in a tube) to fill the nail holes, but it's not sandable and generally not the right product for nail holes....I've learned, it doesn't look good enough in my book.
AustinDB is offline
Old 05-31-2010, 11:05 PM   #33
Renaissance Man
superseal's Avatar
Rewards Points: 4,856
Plastic wood for me too...love snorting that stuff
superseal is online now
Old 05-31-2010, 11:52 PM   #34
AustinDB's Avatar
Rewards Points: 464
Originally Posted by tyler durden View Post
Fight Club fan?
AustinDB is offline
Old 06-01-2010, 07:16 AM   #35
mrmike's Avatar
Trade: Electrical & Carpentry
I've always used plastic wood myself but after reading these posts I am gonna try the Glazing compound as the PW shrinks quite a bit........... Thanks
mrmike is offline
Old 06-06-2010, 09:42 PM   #36
TimNJ's Avatar
Rewards Points: 1,966
If the painter is so bad that he can't fill nail holes, then it really doesn't matter what your job looks like because he will also do a lousy paint job. I fill and caulk outside to be weather tight. Most painters I talk to are very specific about what THEY like to use.
TimNJ is online now
Old 06-06-2010, 09:44 PM   #37
TimNJ's Avatar
TimNJ is online now
Old 06-07-2010, 09:08 PM   #38
Call My Contractor™
mcpainter02's Avatar
Originally Posted by Luke's Dad View Post
Dap "33" glazing compound. Just rub a little in the nail hole and you can paint over it almost right away! Doesn't shrink or crack!
Have to agree with Luke's Dad, The Professionals use glazing compound. I have been in the painting industry for over 30 years and Glazing compound is the only way to go.
Cincinnati Remodeling Contractor - Call My Contractor™ LLC
mcpainter02 is offline
Old 06-09-2010, 11:12 PM   #39
SaN AnToNiO PaInTeR
Rent A Painter's Avatar
Trade: PaInTiNg
Rewards Points: 168
Crawford's Painter's Putty
RENT A PAINTER - Interior & Exterior Painting Specialist
| Facebook
| Google + | You Tube |
Rent A Painter is offline
Old 06-11-2010, 10:11 PM   #40
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Painters Putty '53
http://www.dap.com/product_details.a...52&SubcatID=24
Seems to be nicer on latex products then '33
TBFGhost is offline
Filling Small Holes in Vinyl Siding slickshift Windows, Siding and Doors 9 07-05-2008 09:33 PM
Quickest, best way to fill prefinished hardiboard trim nailholes? pinesol Painting & Finish Work 8 07-31-2007 07:47 AM
Nail holes and cleaning Tom M Finish Carpentry 7 06-16-2007 09:43 PM
filling nail holes on white trim Traditions Painting & Finish Work 11 08-26-2006 03:24 AM
