Filling Nail Holes In Trim
Just curious in what product everyone else was using. One of my trim guys uses a caulk that doesn't agree with paint, another uses something that shrinks like crazy and the 3rd uses something like acrylic spackle that is sandpaper resistant.
I've just realised that this a bottom line issue for the painters. With the fuel and ins. issues, I'm streamlining like crazy.
Deck Designer/Builder
Re: Filling Nail Holes In Trim
I've always used latex caulk but I'm no painting expert. I'm sure they'll be along soon for you Teetor.
Back from the dead...
Trade: Paperhanger/Painter
Elmers:
Dap makes a painters putty that works well. Its like a thicker version of glazing compound. Glazing compound works too.
Minwax makes a white putty which is just like thier colored stuff and we just used that recently and it works pretty well. All of these are soft and remain so for a while. I would only recommend for small nail holes and very small gaps. For larger problem areas on painted surfaces we use auto body filler. Put in on heavy, and slice it off with a very sharp chisel before it gets too hard, then sand smooth. Shrinkage won't be a problem. Caulk on nail holes usually leaves the owner's fingerprint on the wood. |
I've switched to vinyl spackling for nail holes. Dries fast, very easy to sand.
For non-painted surfaces, filling the holes is the last thing I do, I use the colored wax sticks.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
| The Following User Says Thank You to Robie For This Useful Post: | jb4211 (01-08-2012) |
Trade: Work
Re: Filling Nail Holes In TrimLast edited by old27; 01-07-2006 at 12:41 AM. |
| The Following User Says Thank You to old27 For This Useful Post: | sk071077 (01-23-2011) |
Priced In
Trade: Exiled For Life
Crawfords spackling paste. Low shrinkage and is wet sandable.
Rehabs painters caulk, but it shrinks, and more than often its visible.
Others, wood filler, 99% of the time i dont need to sand after i apply wood filler to trim. when i apply it, i use my hand to even it out. |
Professional Tradesman
We use lightweight shrink free spackeling for painted trim. apply with finger or putty knife, light sand and nail holes are invisible. Stained wood, use oil color putty only after the wood has been sealed or the oils in the putty will stain the wood which there is no return once its in the pores...
| The Following User Says Thank You to GPI For This Useful Post: | sk071077 (01-23-2011) |
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
(keep in mind this is coming from a drywaller)....but I use durabond mixed in a pan with a little plus 3.....ONLY IF ITS GETTING PAINTED OF COURSE. I can touch up an entire house quick. I've only been asked to do it a few times but it works great. Say for example you got an old doorway inside the house that has the old markings of the old door hinges. I take some dry 5 minute durabond and work it.....lol
100% perfect in less than 10 minutes.....ready to paint.
Trade: carpenter/remodeler
i have used various things, but at the moment i am using 'plastic wood'.
When It Rains, It Pours..
Trade: Remodeling(Everything)
Patch N Paint for painted trim work, colored wood filler on stainable...after the stain. sometimes I have to mix a couple diff. tubes to get the right color or mix a little stain w/ Natural filler ... I use bondo for big jobs like door jambs or building up a window sills..works great..Elmers has a White wood filler out now...I picked a couple up the other day at walmart on clearance but I haven't used it yet so we'll see...since it was a clearance item, who knows.
"When It Rains, It Pours".... |
| The Following User Says Thank You to highlife77 For This Useful Post: | sk071077 (01-23-2011) |
Mike Danahy
Trade: Signature Painter
Pink Dap spackle
Had a painter use glazing compound and it looks great 2 years later no shrinking. He literally put it on then painted.
I use MH Spackling Paste by Zinsser. Dries fast and shrink resistant. I only putty the outside nail holes on the doors I hang. Anything inside I leave for the painter.
Thom
I use E-Z sand. doesn't shrink, dries fast, easy to sand. I put it on with a 1" knife and rarely need to sand. For baseboard inside corners I use latex caulk. I try to leave a small gap to squeeze the caulk in. It stays flexible and holds well. Oftentimes requires a second coat.
Trade: Remodeling contractor
filling nail holes is the painters job
Complete Custom Remodeling "When Quality is Top Priority" www.completecustomremodeling.com |
#18 |
Trade: General contracting
I agree filling holes should be the painters job,however if you care what the finished product looks like don't count on the painter. best bet is to do a neat trim job and use brads where possible. (Smaller holes.) Bondo for the big gaps is preferable. spackle works or anything HD has cheap for the small holes
#19 |
Trade: Home Improvement
Sure, slap it up, bang it full of holes and then HOPE the painter is going to do a good job of filling YOUR holes before he paints. I know that in a lot of areas, the painter is expected to fill the holes...however, my contention would be "Why would you trust someone else to do that?" If he does a crappy job, it's a reflection on your work as well as his.
Just my .02 worth, but I'm not trusting my work to anyone else. |
| The Following User Says Thank You to twlinks For This Useful Post: | sk071077 (01-23-2011) |
#20 |
Walsh Construction Svcs.
Dap "33" glazing compound. Just rub a little in the nail hole and you can paint over it almost right away! Doesn't shrink or crack!
http://www.dap.com/product_details.aspx?product_id=66 |
| Filling Small Holes in Vinyl Siding | slickshift | Windows, Siding and Doors | 9 | 07-05-2008 09:33 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Quickest, best way to fill prefinished hardiboard trim nailholes? | pinesol | Painting & Finish Work | 8 | 07-31-2007 07:47 AM |
| Nail holes and cleaning | Tom M | Finish Carpentry | 7 | 06-16-2007 09:43 PM |
| filling nail holes on white trim | Traditions | Painting & Finish Work | 11 | 08-26-2006 03:24 AM |
