The Fascia Thread
Old 05-21-2017, 09:42 PM   #21
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,372
Re: The Fascia Thread
Originally Posted by Tom M View Post
Go Boral and don't look back. It holds paint well and stable. Down side is breathing it in. Very dusty.
That fascia that's existing is about 20 years old. It was just painted regular old spruce.
_______________________
"Hindsight Specialist"
_________
Californiadecks is online now
Old 05-21-2017, 09:43 PM   #22
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Got any blocking under the scaffold legs on the lawn?
Without blocking might wreck the lawn.
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
A&E Exteriors (05-21-2017)
Old 05-21-2017, 10:05 PM   #23
GC/carpenter
Yes I put a peice of plywood under it.
_________
The Following User Says Thank You to Californiadecks For This Useful Post:
jlhaslip (05-21-2017)
Old 05-21-2017, 10:13 PM   #24
tjbnwi's Avatar
Rewards Points: 3,416
Originally Posted by Lettusbee View Post
What is boral? A fiber cement product?
Boral is fly ash.
I'm using it in Highlands Ranch. Your welcome to stop by and take a look at how it works.
tjbnwi is online now
Lettusbee (05-21-2017)
Old 05-21-2017, 10:17 PM   #25
tjbnwi's Avatar
I use a TS and dust extractor. Mikes KS should handle Boral well.
Californiadecks (05-21-2017)
Old 05-21-2017, 10:33 PM   #26
Lettusbee's Avatar
Rewards Points: 2,610
Originally Posted by Californiadecks View Post
A couple hours to set up is a small price to pay to be safe. I'm not concerned about the time.
That can't be done very well off of ladders. The window situation and the depth of the eaves make it a bitch.
_________
A quikgrip clamp that can grab shingle and soffit is very helpful for solo fascia work. But you probably already knew that.
Lettusbee is online now
The Following 3 Users Say Thank You to Lettusbee For This Useful Post:
asevereid (05-22-2017), Californiadecks (05-21-2017), overanalyze (05-22-2017)
Old 05-21-2017, 10:42 PM   #27
Lettusbee's Avatar
Originally Posted by tjbnwi View Post
Boral is fly ash.
I was in Littleton for a car show today. Woulda been easy from there. I'm gonna be working out on the lonesome prairie all week this week.
Old 05-21-2017, 10:45 PM   #28
GC/carpenter
No but I've been pondering a strategy. The clamp idea is probably what I'll use. Clamp it in the center.
Old 05-21-2017, 11:25 PM   #29
avenge's Avatar
Rewards Points: 2,790
If I had to do it by myself I'd probably try a standoff on a ladder and adjustable legs with the clamp idea, lot of ladder moves though.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Old 05-22-2017, 02:01 AM   #30
Dirtywhiteboy's Avatar
Rewards Points: 8,044
I don't know if that board is 45º or square butt? The way I would do it is. Hook the barge board with a tape measure and get a number to the center of the middle tail and make a mark,, or get a mark some where. Measure from the same end of the board alone the bottom or some where it will line up with the mark you already have. Shove the board in place line up your marks and hit it with the framing gun. If the corner is 45ºit's easy to get a number if it's butted you'll have to adjust for the butt.
Dirtywhiteboy is offline
Old 05-22-2017, 02:34 AM   #31
VinylHanger's Avatar
Rewards Points: 7,586
_________
Isn't that going to bend your plastic grass?
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
Californiadecks (05-22-2017), Xtrememtnbiker (05-22-2017)
Old 05-22-2017, 06:08 AM   #32
Tom M's Avatar
Rewards Points: 6,410
I wrapped all of the framing on a screened in porch with it last year. I used the TS as well as every other tool. Routers...etc... after a while it was on everything. I used the air hose to keep blasting the saw clean.
Tom M is online now
Old 05-22-2017, 10:57 AM   #33
GC/carpenter
Because I'm not replacing all the fascia and need to match it with the existing I belittle I'm going with Windsor One.
_________________
Old 05-22-2017, 02:20 PM   #34
GC/carpenter
The cuts!
_________________
Old 05-22-2017, 05:44 PM   #35
Tom M's Avatar
Treat those end cuts. Looks like all one piece Fascia which is good. 16' runs?
Tom M is online now
Old 05-22-2017, 07:27 PM   #36
GC/carpenter
Yeppers!
_________________
Tom M (05-22-2017)
Old 05-22-2017, 08:32 PM   #37
GC/carpenter
We have success!
_________________
Old 05-22-2017, 08:51 PM   #38
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 892
So what did that job cost? Cali rates can't be cheap...
Sent from my SM-G920V using Tapatalk
overanalyze is online now
Old 05-22-2017, 09:25 PM   #39
GC/carpenter
Materials were 250 bucks.
_________________
Old 05-22-2017, 09:26 PM   #40
GC/carpenter
If it weren't my house I'd probably charge about 2500 to 3k for that.
_________________
Fascia grooves pegasush Windows, Siding and Doors 56 08-14-2013 08:26 PM
Quickest easiest way to remove fascia boards? realelectrician General Discussion 30 03-20-2013 09:47 PM
aluminum soffit and fascia Something new General Discussion 13 02-22-2013 05:01 AM
Fascia used as drip edge? canuk_guy Roofing 13 06-25-2012 11:04 PM
