Clint
Estimate To Change Window To Ext. Door
Hi,
Happy to have happened onto this site. I have a question someone might be able to answer. I read a post about the cost of remodeling a outside window and installing an exterior door in its place. I seems like the most were leaning towards the $600.00 mark. The guy wanting the work done says he has a $300.00 limit, to do this job, and to build a small deck 5'x5' off the front entryway. Now I'm thinking to myself, it ain't gonna happen. The job would be done by me and my partner. I was thinkin before I even found the thread on this site, that it would be more like $2-300.00 each plus materials, for the window/door job, and probably in the $50-75.00 +materials for the deck. Can I get some input on this as to what the going rate is for a job like this. And I know the permits need to be included. Our county, no permit needed for the deck if under 30" above grade, but the doorway definately. Thanks, Clint I should have added that its lath and plaster. Last edited by Shnippy; 09-29-2008 at 01:07 AM. Reason: added more |
#2 | |
Trade: Specializing in residential remodeling
Re: Estimate To Change Window To Ext. DoorQuote:
#3 | |
Handle It!
You will not any further decline in todays economy to be quickly out of business with prices like that.
Money Changer
Trade: Residential Remodeling
You guys would be better off working for a case of beer and some lunch groceries.
Your profit will be in the $ you save not driving to the store..... |
Clint
Hi,
Sorry for the introduction. So whats a good estimate for the window/door job? We did some foundation work for this guy, and came out pretty good, although it was nasty under the house. Crawling in insulation soaked by about about 3 inches of standing water, and about 18" clearance. So what I am thinking is he is wanting more work done at a heavy discount. Sorry for getting right to the point, he is wanting the job to start friday, and I could use some help getting a decent estimate that will make us all happy. Thanks again, Clint |
Professional Instigator
Confucius think u no contractor. real contractor no price for this. If you no price maybe it not job for you.
apologies to my Chinese contractors for the stereotyping |
Max Gorietti
Trade: Complete Renovations
I recently did a job like that (for an outside door) according to the size of the door and window if you can install a door with out making the opening wider I would tell you that I get $500 with the door (not more than $ 150) if you need to make the door opening bigger and there is nothing in the way like electric I would charge $850 that is if you want to stay in business.
Max |
Clint
Ok, Thanks for confucious's input.
Re: Estimate To Change Window To Ext. Door |
Clint
Thank you Max,
Now that sounds like a reasonable bid. Much appreciated! Thanks, Clint |
It's bad luck to start a job on Friday.
That is more information than you have given or received here so far. Maybe you're lucky, and everything about this deal will just go swimmingly. I hope so, but none of us here have a clue about what you are looking at, and it doesn't sound as though you do either.
Try this.
Do the job carefully in your head. Ask yourself questions. Will I need to patch plaster? Will I need to match trim? Will I need to enlarge the header? Fill the opening? Is it balloon framed, or platform? Will I need to batch flooring? And about a hundred more questions that should come to mind while you think it through. Then apply this.... http://www.contractortalk.com/f84/door-installition-45573/
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 09-29-2008 at 05:44 PM. |
#13 | |
#14 | |
generous mood? Besides, I just pulled that out of a fortune cookie!
Dude, you need to change your title (occupation) listed. There is no way that you are a General Contractor.
You sound more like a Handy Man with a Buddy operation. There is nothing wrong with that. Just be honest about what you do.
- Build Well - |
#16 | |
contracts, generally.
you're going about this the wrong way. If you're trying to underbid the other Craigslist guys, you're off to a good start. That $300 figure is crazy-a new cheap steel door is $200-install rates would be easily $500-800 depending on type of siding and if the opening is large enough for a 36" door.
Try this, make a list of the items which this project will require. i.e. 1) buy materials (list out ALL materials), 2) remove siding, 3) remove window, etc... then add a time to each item. Finally, add up times, materials and multiply by whatever you choose to use as your base pay. For instance, if you come up with 25hrs and want to charge $8/hour, you're got an estimate for $200! Now you're coming in less than the guys $300 price limit. Seriously, $300 to install a door and build a deck? Get this: I'm building a brick stoop and someone rolls up in a MB, so I walk over and the driver asks if I "do this stuff on the side". The embroidered shirt gave away that it's not a side job working for beer money. Is this your sidejob or your sustenance? |
#18 |
is it not funny? the only way for a new guy to get info on pricing is from another new guy, now if new who gave the pricing info stays around long enough, he to will become jaded and will soon be giving wise ass remarks to the new guy with a pricing question!!!! what did i just say?
#19 | |
![]() I could have told him I just did a 32" change out for $2k. But that has nothing to do with his job.
#20 |
Besides, in case you haven't
noticed yet, how much per door is the question du jour!
| Need Window & Door installer in Miami, FL | Amber | Help Wanted or Looking For Work | 8 | 01-21-2011 10:21 AM |
| Exterior Door Installation | BoydS | Remodeling | 59 | 02-20-2009 04:54 PM |
| Door install hell - customer angry | HellisLikeNewrk | General Discussion | 17 | 06-04-2008 10:40 AM |
| Cut and install new house window | mustanger | Remodeling | 2 | 11-30-2007 09:39 PM |
| Honoring your original estimate | A.W.Davis | General Discussion | 8 | 10-11-2007 11:28 AM |
