Dust-Free Remodeling
Old 12-11-2011, 05:19 PM   #161
plazaman's Avatar
Rewards Points: 1,202
Re: Dust-Free Remodeling
Originally Posted by sbcontracting View Post
I have something pretty similar - it`s 3400 cfm, 12 inch hose - I try to have it outside, but the hoses are only 25 feet long and pretty bulky. Not a great solution for winter either, it sucks ALL the warm air out of the house I usually put it in a window where I`m working and cut a peice of hardboard around to fit the window frame.
I tell people that it`s the compromise - dust free or lower heating bill. I don`t have any form of sock on it to collect the dust blown outside though. That`s a nice option to have.
Mine was used, it`s loud and cost me about 5 bills for one 25`hose and the blower. I wouldnt mind getting a second hose.
do you have any pics?
plazaman is online now
Old 12-11-2011, 08:41 PM   #162
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Get a filter sock for a dust extractor. The ones you use in the shop kind. Then use big cable tie to attach it to the hose. Its a easy way to get a exhaust filter.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-11-2011, 09:00 PM   #163
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Nah - but here it is: The hose is a 25' yellow one.
http://www.vhrrental.com/rental/blow...rs/exhaust-fan
Ottawa General Contractor
http://www.springer-boyd.com
sbcontracting is offline
Old 01-18-2012, 10:42 PM   #164
KAP's Avatar
Trade: Custom
Rewards Points: 26,862
Extension pole (8' -16') + rectangle paint pad + 3mil plastic = ZIP wall
Velcro strip on paint pad edges, velcro tabs for plastic = easy up
MUCH less money...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
ShearerReno (08-14-2012)
Old 01-30-2012, 02:19 AM   #165
Herboth's Avatar
Trade: General Remodeling Contractor
I use third hand tools with plastic to create a dust barrieras well as a way to separate my work space from the customers living area. Ialso use zipper doors to get in and out of the plastic walls I erect. I alsofabricated a metal 20 x 20 air intake that has 20 x 20 air filters. Combinethis with a portable exhaust fan I created a work area air cleaner and it alsoprevents dust from entering my customers living spaces by creating a negativepressure within my work area.http://www.herboth-remodeling.com/Be..._Grace_Ln.html
Herboth is offline
Old 02-21-2012, 10:39 PM   #166
go terps
peakecg's Avatar
Trade: general contractor
Check out protectiveproducts.com
peakecg is offline
Old 03-27-2012, 07:10 AM   #167
Shark49's Avatar
Rewards Points: 25
Originally Posted by HandyHails View Post
This is the bees knees in smaller work areas. I know this doesn't meet lead requirements, but works well where this does not apply.
Here is the hose for it.
I use this all the time. Works great on fine and not so fine dust. I purchased to use when I resurface bathtubs and tile.
where can i get this!!!!????
Shark49 is offline
Old 03-27-2012, 07:57 AM   #168
Tom M's Avatar
Rewards Points: 6,062
Harbor frieght
Tom M is online now
Old 05-12-2012, 01:56 PM   #169
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Another Dust Free renovation here in Vancouver. We love using this large fan and on this job to much air was blowing in off Vancouver's False Creek. To get the right negative pressure we used some 6mil vapour barrier and some tape to slow the migration of air in from outside.
This worked very well. Our client had a diner party that night like he did a few years back when we reno'd the other bathroom. You know your onto a good system when your clients are not afraid of entertaining durning the demolition process of a bathroom remodel.
JohnFRWhipple is offline
Old 05-12-2012, 02:09 PM   #170
Trade: Construction
John i expected better from you lol thats even worse than my old system
Here's mine setup today doing some spraying. I have it on a remote system so I can shut it on and of from inside work area.
John also dont forget to open enough other windows or doors to let air in from outside. I have blown my pilot light out on my furnace a few times and when the water heater is running CO2 levels increase and trigger my carbon monoxide alarms as its pulling in air back through the flue so exhaust being sucked back through to living areas.
The Following User Says Thank You to BCConstruction For This Useful Post:
Tom Struble (05-21-2012)
Old 05-12-2012, 02:44 PM   #171
Remodeling GC
kevjob's Avatar
Rewards Points: 4
Attachment 71649
Attachment 71652
Attachment 71650
Attachment 71651
Who makes that set up?
Nice I have been using www.demoairnet.com attached to box fans and portable ridgid air filtration units.
Kevin
www.ObrienConstructionDenver.com
kevjob is offline
Old 05-12-2012, 02:51 PM   #172
Hey it works great. This system might not be as fancy as yours but it does the job. I have seen better rigs like yours available at the rental stores but find the hoses stink. Stink as in smell bad not that they don't function well.
My fan is easily cleaned and works amazingly well.
The key is in the prep with the plastic walls and zip poles. We use the plastic walls to measure our success. If the plastic sucks in we are golden. If not we redesign the rig.
JW
Old 05-12-2012, 03:05 PM   #173
Trade: Construction
Hey Kev it's made by allegro. The reason I went for this model was its reversible so it can blow as well as suck. It ain't cheap but the motor is def much better quality than other models I gave seen and it's fully sealed so no dust can get to brushes.
John ain't noticed any smell from the unit. It's mainly designed for supplying air in man holes or extracting air in man holes so prob why it don't smell. The hose is much better quality than the type you would see as most tool stores. They look similar but up close the material is a laminated rip stop kind of material and pretty tuff.
Old 05-14-2012, 08:35 AM   #174
What's the cost on that unit?
JW
Old 05-14-2012, 08:55 AM   #175
Trade: Construction
JW
$617 with 25ft of duct. They do a 15ft duct option but it's only $60 cheaper
They also do a 8" which is quite a bit cheaper but its almost 3x less cfm.
Old 05-21-2012, 02:23 PM   #176
Rewards Points: 562
That's not a bad price. I paid close to that for a used unit at a rental store. 3500 cfm, but the hose is pretty beat up. Sucking only - if I blow with it half the dust escapes the hose
Old 06-09-2012, 12:57 AM   #177
perinavomel's Avatar
Trade: RTA Kicthen Cabinets
As far as carpet dust concern the focus is on maintaining carpet dust free through dust sucker machine rather than change it.
kitchen Remodeling
perinavomel is offline
Old 06-09-2012, 01:09 AM   #178
Dirtywhiteboy's Avatar
Rewards Points: 8,006
Nice webpage Are you a Chinese cabinet importer?
Dirtywhiteboy is offline
Old 08-14-2012, 03:05 PM   #179
everhartconstruction
jrlong's Avatar
Other than using box fans and taping off the work area, the best way to minimize dust in my opinion is to moisten the are. When dust starts to rise you can spray a very fine mist from a hose or other water delivery device. This will clear the dust fast, but may make your work area a little slippery. For cleanup, we use a wet rag to mop up and wipe up dust. If you start sweeping and vacuuming it up, it will just spread throughout the air more. Don't forget to wear a mask though, the dust is terrible for your sinuses.
jrlong is offline
Old 08-23-2012, 09:45 PM   #180
Lion Hunter's Avatar
Trade: General contractor/ carpentry
Rewards Points: 75
great before booming up at the shop, or cutting concrete, shoveling plaster. do it all the time
Lion Hunter is offline
Free Tacos for America - Tuesday the 30th JamesNLA Off Topic (Non Trade) 1 10-30-2007 10:52 AM
