Dust-Free Remodeling
Old 06-07-2009, 01:16 PM   #81
unhique
Guest
unhique's Avatar
Posts: n/a
Re: Dust-Free Remodeling
I have this shop dust collector from Jet for a long time but have ... no shop. http://woodworking.jettools.com/Prod...36K&cat=333122
So I plan to use just the blower, take out that dual inputs (4") to make it a 6" input as my air mover. Its specs says 1100 cfm. Wondering if that's good enough for a 100-150 sqft remodeling area.
Old 06-07-2009, 01:21 PM   #82
unhique
Guest
unhique's Avatar
Posts: n/a
Oh btw, anyone else using www.dropcloth.com products? If so, which one and how durable are they? I got samples from them last week, and trying to compare between their products & those on http://www.protectiveproducts.com/productline.html
I run into cases where I have to cover the whole floor (12'-15' ect). Last time I used that red construction paper from HD, after 3-4 months at the job, I have to spend 1 1/2 week cleaning up.
Thanks.
Old 06-07-2009, 01:31 PM   #83
neolitic
Guest
Posts: n/a
This stuff?
http://www.polytak.com/carpet_mask.shtml
Might be me but it was too narrow,
stuff got under it, and it moved around a lot.
Thinking about using regular vinyl runner, and holding it
with crown staples thru plastic caps?
(Like off of felt nails)
Originally Posted by Cole View Post
That looks pretty good.
I ordered a sample.
Me too!
They're gonna think business is on the up-tick
Well....
never did get the samples,
but I went ahead and bought some
on faith.
Ordered a week ago last Thursday,
got it on Tuesday (free shipping).
Used @4" piece of blue tape on
each side on every tread (clear finished
oak treads), and just loose on the landing,
down the hall, and through the family room.
(All hardwood)
So far so good, lots of traffic from my
partner and I, as well as a couple of subs
checking things out after we opened the walls.
HO said they didn't mind leaving it in place
over night, so it's also surviving traffic from
two teenagers, associated friends, and 2 dogs.
Pulled and rolled it for the weekend and it
was good as new.
Summary:
So far it's a good product...
Lousy sales department!
Awesome, thanks for the summary!
Thanks.
About as much as I can say
except that I have reused
parts of them a couple of
times since.
Every thing they say it is.
Old 06-08-2009, 01:03 AM   #84
unhique
Guest
unhique's Avatar
Posts: n/a
Thanks Neolitic. I meant to ask which of the dropcloth (surfacePro, clean&safe pro, or clean & safe). I'm looking at probably the "Clean & Safe Pro" but debating which size to buy and how much for a safe quantity.
Old 06-08-2009, 09:42 AM   #85
neolitic
Guest
Posts: n/a
ADD?
http://www.dropcloth.com/cleanandsafe2a.html
Old 06-08-2009, 09:51 AM   #86
Darwin
Guest
Darwin's Avatar
Posts: n/a
Spray the working area with water . Dust will be at a minimum
Old 07-20-2009, 12:27 AM   #87
kpall312
Guest
kpall312's Avatar
Posts: n/a
I use 3rd hand. Cheaper then zipwall. Here is the link: http://www.coastaltool.com/other/fastcap/3rd_hand_contractors_kit.htm
Old 09-28-2009, 06:52 PM   #88
abacab
Guest
abacab's Avatar
Posts: n/a
I've used an old window air conditioner to create negative pressure in the rooms I'm working on. I put an extra filter on the front, just a piece of foam. Keeps the fine dust from drifting to other rooms in the house. I clean the extra filter once a day (okay I lie, I clean it when it needs it). This only works in the summer however.
Old 09-28-2009, 07:06 PM   #89
BCConstruction
Guest
BCConstruction's Avatar
Posts: n/a
We used to use a system like this. We lost the filter bag but the system worked very well when the bag was attached. If i remeber correctly our as about 7000cfm but they went over 20000cfm.
Old 11-21-2009, 01:43 PM   #90
plazaman
Guest
plazaman's Avatar
Posts: n/a
Hey, that little B I T C H fan is powerful! i have one the same size, but theres a problem with it, it runs fine for 10 seconds, then cuts off, starts again, any ideas?
If i could get that repaired and a sock for it, i'll be in business! (Where did you get the sock from?
Old 11-21-2009, 07:41 PM   #91
fez-head
Guest
fez-head's Avatar
Posts: n/a
Thats the cats ass right there - what is the proper name for it and where can I get one?
Thanks
Old 11-22-2009, 09:37 PM   #92
Wood Worx
Guest
Wood Worx's Avatar
Posts: n/a
Besides what everyone else has mentioned, I use a higher end air purifier. I will usually put this in the area that I am not working in. Any dust that gets around all the plastic will get drawn into this air purifier/filter. Seems to work good. I think I spent around 200 bucks.
Old 11-22-2009, 09:56 PM   #93
BCConstruction
Guest
Posts: n/a
Prob wont be worth getting anything like this in the near future if this stupid lead paint law comes through. All filtration will more than likley have to be neg pressure hepa filtration. Big Big bucks.
Old 11-22-2009, 10:39 PM   #94
charimon
Guest
charimon's Avatar
Posts: n/a
Like this lil jewel
http://www.discountcleaningproducts....te=google_base
500 Cfm $850 but she works like a Champ
Old 11-23-2009, 08:14 AM   #95
BCConstruction
Guest
Posts: n/a
Originally Posted by charimon View Post
Like this lil jewel
250-500 CFM is almost useless in most construction extraction work. You wanna be in at least the 5000CFM range to even attempt to pull a negative pressure enough to filter a room. But it does look cool lol
Old 01-09-2010, 12:05 PM   #96
Zmancan
Guest
Zmancan's Avatar
Posts: n/a
I usually apply the sticky plastic then rip 1/8"masonite (untempered is cheaper - about $6 a sheet here in Houston) to the size of the treads and tape all edges to the sticky plastic. Measure the size width of tread minus 2" (leaves room for good tape adhesion on ends and deduct 1" on your depth so you can tape next to the riser as you flush tape the front edge to the tread. This method has held up great for us. You also may want to cover the rail wall or newels to avoid damage to sheetrock, bannister or post. I'm sure you get the idea. Hope this helps.
btw - its also a good idea to tape masonite to risers. We use a very sticky 2" wide packaging tape to make sure our tape doesn't come loose from abuse. Its available through Rusco packaging - 713 996-7478
Old 01-14-2010, 04:40 PM   #97
technique
Guest
technique's Avatar
Posts: n/a
Just had a bunch of concrete cutting done today and I can highly recommend the diamond blade wet saws that create slurry instead of dust, I'll post pics of the project in my other thread.
Old 01-21-2010, 08:28 PM   #98
BCConstruction
Guest
Posts: n/a
Forgot about this thread. Here is the link for the fan and filter sock http://www.icscompany.net/confided_s...ation_syst.htm
I was also looking at this setup for far less money and thought about using a single bed sheet as a filter.
http://www.globalindustrial.com/p/hv...tilation-fan-2
I currently use a hunter 90245 as a air mover for creating neg or pos pressure. It works great and fits in door ways really well.
Old 01-21-2010, 08:45 PM   #99
festerized
Guest
festerized's Avatar
Posts: n/a
Old 01-21-2010, 08:58 PM   #100
drywallnflorida
Guest
drywallnflorida's Avatar
Posts: n/a
kinda like the zip wall poles but under 20.00 each
works great to keep dust contained!
http://www.harborfreight.com/cpi/cta...emnumber=66172
Free Tacos for America - Tuesday the 30th JamesNLA Off Topic (Non Trade) 1 10-30-2007 11:52 AM
