Dust-Free Remodeling - Page 12 - Remodeling - Contractor Talk
Old 04-30-2016, 10:16 AM   #221
AGullion's Avatar
Rewards Points: 1,422
Re: Dust-Free Remodeling
No problem. Know problem . Anyone know how to edit?
AGullion is offline
Old 04-30-2016, 10:37 AM   #222
KAP's Avatar
Trade: Custom
Rewards Points: 28,628
Just bustin'... I think you can edit a post up to like an hour or so using the edit button (see below - don't know the exact cut-off), but then the button disappears and after that you'd have to ask a mod to change it...
KAP is offline
Old 04-30-2016, 10:43 AM   #223
AGullion's Avatar
Thanks man
AGullion is offline
The Following User Says Thank You to AGullion For This Useful Post:
KAP (05-05-2016)
Old 05-04-2016, 10:40 PM   #224
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
The blue poles from harbor freight crush the small diameter pokes from zip wall.
I found that at on this site, on the "harbor freight tools you actually use" thread.
The only better pole is fastcaps 3rd hand, and it's almost overkill it's so well made .
I totally disagree with you on this.
I have and use all three of these products.
For running plastic sheeting there is NOTHING faster and easier than zip poles.
The weight factor is huge when you are carrying over 10 poles into a project. Zip poles are the clear winner.
If you do a lot of plastic walls using these are the best choice
I have 2 sets of 10 poles.
3dr hand dust doors are the BOMB and for them to work you need 3 rd hand poles or a modification to the harbor freight poles.
For over all versatility Is the clear winner
It is strong enough to dead man drywall,
and stable enough to use as a laser stand.
I think the first 2 poles a contractor shold buy are a pair of these.
The harbor freight poles are cheap they are perfect for a good second string, I have 14 of them that I bring out on large projects or a second jobsite.
For the most part they suck for laser poles and I would not trust them for heavy over head support. you can use the FastCap plastic sheeting head on the harbor freight(you can use most 3rd hand accessories on the HF stuff.
charimon is offline
Old 05-04-2016, 11:23 PM   #225
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,618
Used this today on about 30 holes. Amazingly effective.
Half of all people are below average.
Golden view is offline
charimon (05-05-2016)
Old 05-05-2016, 01:25 AM   #226
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I noticed those today at HD and was curious about them.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 05-05-2016, 01:51 AM   #227
VinylHanger's Avatar
Rewards Points: 8,038
I saw that too. I didn't look close enough to see what it was.
VinylHanger is offline
Old 05-31-2016, 09:00 AM   #228
woodman2011's Avatar
Trade: Painter
Rewards Points: 14
Originally Posted by Journeyman T View Post
I'm interested in any tricks (other than the obvious) for minimizing dust when remodeling. Does anybody have some?
Hi, check out The Dust Cobra by Oneida. Its HEPA and apparently pretty powerful. Oneida is a good brand.
http://www.oneida-air.com/inventory.asp?catid={88398A7C-ADBE-46C7-976A-AEAD1AE24147}
For the sake of honesty, I'm a brand ambassador for Oneida, but I really stand by their products and have used their dust deputy for ages.
woodman2011 is offline
Old 06-01-2016, 06:49 PM   #229
AGullion's Avatar
How do you guys protect hardwood stair treads
AGullion is offline
Old 06-01-2016, 06:54 PM   #230
Nick1001's Avatar
Rewards Points: 201
Ram board cut to size and frog tape.
Nick1001 is offline
Old 06-01-2016, 06:56 PM   #231
AGullion's Avatar
Cool, been having issues with blue tape pulling finish off
AGullion is offline
Old 06-01-2016, 07:50 PM   #232
Nick1001's Avatar
Rewards Points: 201
Frog tapes definitely better, also costs more. I try not to leave it down too long. Change every couple days or once a week.
Nick1001 is offline
Old 06-07-2016, 09:07 AM   #233
Footage Tools Inc.
FootageTools's Avatar
Trade: Tools Manufacturing
Rewards Points: 82
Zip Walls all day.
FootageTools is offline
Old 12-12-2016, 12:38 PM   #234
Woodworker
ShadowLynx's Avatar
Trade: General Contractor, Remodeling, Finish Carpentry
Rewards Points: 154
Best way is to control the dust at the source. Always keep a vacuum on with cutting, sanding or grinding. Invest in either a HEPA dust extractor like the Dewalt one I just got myself as a early Christmas gift or use HEPA filters like Cleanstream in a regular Ridgid shopvac (which I did for years).
Have a helper hold the sucker where you are grinding/cutting/sanding or tape the hose to your tool. It won't catch all the dust, but it will get 99% of the really fine stuff that is the real problem. The stuff that it won't suck up on the spot are too heavy and falls straight to the ground. You can clean those up after. Zip walls are fine and good, but if you don't control the dust at the source, you'll just end up with a really dusty containment.
ShadowLynx is offline
Old 12-06-2017, 08:15 PM   #235
Pangdev's Avatar
Trade: general contractor
Rewards Points: 190
Zip wall are spring loaded poles that you can clip the plastic onto. Just cut the plastic to size and clip to the zip wall. Its very easy to hang the poles.
Pangdev is offline
Old 12-06-2017, 08:17 PM   #236
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,594
I just bought some zip wall stuff.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 12-06-2017, 08:27 PM   #237
tjbnwi's Avatar
Rewards Points: 4,146
Zip Wall, Build Clean, Ermator.
tjbnwi is offline
Old 12-09-2017, 01:30 PM   #238
Pangdev's Avatar
Rewards Points: 190
Zip walls are the best
Easy and affordable
Pangdev is offline
Old 12-09-2017, 08:15 PM   #239
Juan80's Avatar
Trade: General contractor
Rewards Points: 444
Fastcap has some nice dust barrier poles,and a magnetic door setup.
I bought what they call “ a contractor pack” .
4-poles and all the feet in a convenient carry bag.
Charlie
Sent from my iPad using Tapatalk Pro
Juan80 is offline
Old 12-10-2017, 08:20 AM   #240
Renaissance Man
superseal's Avatar
Rewards Points: 5,492
Charlie
That's what i use...a lot stronger than zip
supersealconstruction.com
superseal is offline
Free Tacos for America - Tuesday the 30th JamesNLA Off Topic (Non Trade) 1 10-30-2007 10:52 AM
