Dust Containment
Old 10-16-2017, 09:21 PM   #1
blbranch63's Avatar
Trade: Residential Renovation
Dust Containment
Has anybody found a good tape to use for dust containment barriers? We use 6 mil. plastic. Painters tape will never stay. Trying to find something else that adheres well to
plastic but won't damage the walls I am taping the barrier to. Any ideas?
blbranch63 is offline
Old 10-16-2017, 10:28 PM   #2
Talking Head
EthanB's Avatar
Rewards Points: 14
Re: Dust Containment
My go to was the Painter's Mate green tape. I'd run a heat gun(on low) over it as I was pulling it off to ensure that it released smoothly. Too much heat=residue, too little heat=missing paint.
Planer.....
EthanB is offline
Old 10-16-2017, 11:57 PM   #3
Hack
asevereid's Avatar
Rewards Points: 220
I saw a trick online that is like to try (but, to skip to the preference, I like to use 3M 2" blue tape) ; a fellow was installing a barrier and instead of taping the plastic to the walls, they ran masking paper and tape around the perimeter and then spray adhered the poly to the paper. Apparently it functions better than just tape to the wall and poly.
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 10-16-2017, 11:57 PM   #4
JAH's Avatar
Trade: carpenter
Rewards Points: 1,788
I tape plastic to walls with Frog painter tape. Then use Tyvek tape over the Frog. Tyvek tape works great on heavy plastic & Frog is easy on walls.
I also use Tyvek tape on Zip Wall zippers.
JAH is online now
The Following 2 Users Say Thank You to JAH For This Useful Post:
asevereid (10-17-2017), EthanB (10-17-2017)
Old 12-09-2017, 03:13 PM   #5
Pangdev's Avatar
Trade: general contractor
Rewards Points: 142
combination blue painters tape to place on the wall and plastic. Then gorilla tape atop the blue and plastic.
ALso
we use the zip wall barriers which limits the amount of tape needed bc they have the pressure strips that press the plasic to the wall and minimize any tape needed
Good luck
Pangdev is offline
The Following User Says Thank You to Pangdev For This Useful Post:
heavy_d (12-09-2017)
using a dust containment system? atached to sander.. thoughts jimbofloors Flooring 8 11-04-2016 12:09 AM
bad dust containment/ fans libluewater Sandblasting 14 07-31-2012 09:49 AM
bad dust containment/ fans libluewater Sandblasting 0 11-18-2011 07:11 AM
Helpful tips for the EPAs new mandate Paulie Lead RRP Discussion 20 04-10-2011 12:56 PM
Dust containment LeftHandedHammr Sandblasting 5 01-30-2009 01:11 AM
