Dirty Shower
Old 10-20-2009, 02:24 AM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Dirty Shower
Any idea how to take care of an old dirty shower? This lady says she's tried cleaning it with CLR, ammonia, bleach, everything, nothing will clean it. It would be a waste to replace the whole shower only because it's dirty. Is there a way to paint over it, or cover it?
KennMacMoragh is offline
Old 10-20-2009, 05:16 AM   #2
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Re: Dirty Shower
Paint over it? Now there is a great idea Behr premium plus to the rescue.
Here is a novel idea, YOU clean it!
Soft scrub,Krud Cutter,Scrubbing bubbles, etc,etc,etc and a little elbow grease will do it.The little old lady did not try hard enough.
chris n is offline
Old 10-20-2009, 08:10 AM   #3
Re: Dirty Shower
lol, no not Behr. This old lady is pretty tough, I saw her outside landscaping carrying some huge boulders around that most guys couldn't carry. I might try cleaning it for her, but I don't know if I'll end up spinning my wheels, they look like stains.
Old 10-20-2009, 08:17 AM   #4
Sean
SLSTech's Avatar
Re: Dirty Shower
Is that a fiberglass or acrylic base? Did she use comet or something else rough on it - then it is scratched up big time & will need to be redone or replaced
I know this place sells a fiberglass cleaner used for boats www.jamestowndistributors.com - you might have a source locally though that you can use
You could also try getting it steam cleaned
SLSTech is offline
Old 10-20-2009, 08:30 AM   #5
Ebbo's Avatar
Trade: Carpentry/Remodeling/Superintendent
Re: Dirty Shower
Yes you can refinish it. I do this for a living. It is sprayed with a HVLP compressor using aerospace epoxy paints you get from Midwest or Napco. I've done hundreds of tubs and fiberglass surrounds and tile with it.
http://www.midwestchemicals.com/
http://www.napcoltd.com/
Ebbo is offline
Old 10-20-2009, 08:34 AM   #6
Re: Dirty Shower
It's a shower from the 70's, so I'm guessing it's acrylic.
That's kind of what I was thinking Ebbo, I might see if I can find someone local who does that to give her a bid.
Old 10-20-2009, 09:24 AM   #7
TheCleaningDoc's Avatar
Trade: Websites SEO
Re: Dirty Shower
I have had good luck with barkeepers friend. comes in a can like comet but is safe enough to use on glass. You wouldn't believe what comes off with that stuff. You can get it at the local HD or Lowes. for about 2 bucks it is worth a shot.
Pat Motz
406-465-9334
TheCleaningDoc is offline
Old 11-08-2009, 07:08 PM   #8
brcon's Avatar
Trade: general contracting for residential remodeling
Re: Dirty Shower
If that's a fiberglass base, the hard scrubbing is prolly taking off the finish. Looks like dirt, but the more you scrub the worse it gets. Refinish or replace.
brcon is offline
Old 11-08-2009, 07:17 PM   #9
BCConstruction's Avatar
Trade: Construction
Re: Dirty Shower
If it is fiberglass and she has gone through the gel coat then you will prob have to have the tray refinished. It's a commen problem with fiberglass trays where the owner attacks the tray with abrrasives and does more harm than good.
BCConstruction is offline
Old 11-08-2009, 09:20 PM   #10
bathroom guru
jarvis design's Avatar
Re: Dirty Shower
Almost looks like cultured marble walls - which would mean a cultured marble base. If the case - they can be a PITA to get the stains out of.
Most of the time the roughen up the top coat (which is like gel coat) to provide anti-slip protection. Unfortunately, it also leaves the surface "open" and stains can get in.
If you are looking at the refinishing option, just be aware it is not going to last forever. Depending on the usage, the materials used, and the guy doing the job, a typical reglazing job should last 5-10 years. Your customer will not be able to use any of the aforementioned cleansers on the reglazed base.
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 11-08-2009, 09:21 PM   #11
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Re: Dirty Shower
brillo.
Darwin is offline
Old 11-25-2009, 09:10 PM   #12
no problem's Avatar
Re: Dirty Shower
You can suggest oven cleaner, this is the best thing to use on shower pans or even tubs.
no problem is offline
Old 11-25-2009, 10:36 PM   #13
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Re: Dirty Shower
You're a remodeling contractor. Put a proposal together to replace it! If replacement is out of the question call your next lead.
"Being willing is not enough; we must do". Leonardo da Vinci
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
bconley (11-27-2009)
Old 12-05-2009, 10:57 AM   #14
PlumbBob^2Pants's Avatar
Trade: Homebuilder
Re: Dirty Shower
Test lacquer thinner on a small spot and if it doesn't harm the surface go over the rest of the shower with it. Lacquer thinner is the best stuff I've used for bringing off stains, dirt, paint, etc.
PlumbBob^2Pants is offline
Old 12-05-2009, 11:04 AM   #15
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Re: Dirty Shower
How well does the paint hold up in situations like that over time? The painted showers/tubs and sinks (usually kitchen) that I've come across have failures around the drains within a few years. Though, you may be using better coatings than the ones I've seen.
Shawn Prentice is offline
Old 12-05-2009, 06:45 PM   #16
bathroom guru
Re: Dirty Shower
No reglazing material is going to last the same as an original finish. It is dependant on 2 things - the quality of the material and the workmanship. You could use the best material on the planet, but, if not prepped and applied properly, you're gonna have problems
519-495-4062
Old 12-05-2009, 07:04 PM   #17
Re: Dirty Shower
I agree. I've never done it on any of my jobs, although I've been asked and have been able to talk them in to installing a new product. I'm actually going to look at a bathroom Monday and the client mentioned something about painting the tile, but we'll see. If I did that, I'd rather have it done in an area that is not heavily used.
Old 12-05-2009, 09:14 PM   #18
bathroom guru
Re: Dirty Shower
Not that I am going to backtrack on my earlier post, but, I will say that I am not totally against reglazing - I just hate when reglazing companies say their sh*t is going to last for the long haul.
Tile reglazing will work well - even in a wet area (tub surround - not shower) - as it does not get the abuse a tub does - however, normally if you are doing the tile, you are doing the tub.
The only fixtures I like to see reglazed are antique clawfoot tubs and sinks - just forget about doing old farmhouse kitchen sinks or any kitchen sink for that matter!
519-495-4062
Old 12-06-2009, 10:45 AM   #19
Re: Dirty Shower
Thanks for the follow-up, Jarvis.
Old 12-07-2009, 12:00 AM   #20
wayne3434's Avatar
Trade: carpenter/remodeling
Re: Dirty Shower
refinish it. I have done a bunch and they look great. I use www.napcoltd.com
wayne3434 is offline
Tiled Shower - Question blackte Ceramic & Stone Tile 2 10-19-2009 10:24 AM
Custom shower base - granite Charles_cz Ceramic & Stone Tile 12 08-18-2009 09:05 PM
leaky shower head Sir Plums Alot Plumbing 3 04-07-2009 09:25 PM
care to share ideas for 2 person shower? 72chevy4x4 Ceramic & Stone Tile 12 02-24-2009 01:47 PM
Tiled shower leaks...Could use any advise at all... Jay22 Ceramic & Stone Tile 17 12-10-2008 07:15 PM
