DensShield Question
Old 06-14-2006, 01:14 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
DensShield Question
I'm going to be installing a custom tile shower using DensShield now instead of Hardibacker. The ceiling won't be tiled, so instead of using green board sheet rock for the ceiling, is it okay to just use the DensShield we have on hand? I am reading the literature and it shows that you can skim coat DensShield with setting compounds to finish it like drywall, so this seems like we could do the same thing in the ceiling of the shower.
Mike Finley is offline
Old 06-14-2006, 04:49 PM   #2
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Re: DensShield Question
Give the Denshield ceiling thing a try and let us know how it goes. Sounds like you have done your research.
Just a note for you concerning hardi and dens. They will bloat and grow mold when contacted with water. I know this after conducting a year long back yard experiment. FWIW durock is the way to go.
Looks like some pros were here.
Gordo is offline
Old 06-16-2006, 09:29 PM   #3
Pearce Services's Avatar
You can skim it and finish it like sheetrock, But, I am not a good skim-coater, and found it a little bit of work to get the stuff to stick to the Denshield, make sure you remove all the dust from the surface first.
Pearce Services is offline
Old 06-16-2006, 10:41 PM   #4
The Deck Guy
Greg Di's Avatar
Mike,
I use DS a lot. You'll never go back to Hardibacker or CBU.
For the ceiling, use GP DensArmorPlus drywall. Wherever you're buying your DS from, should carry DAP.
Dealing with a little DS on the joint where shower wall turns into bath wall is ok to deal with, but DAP will be better for your ceiling. In fact, I don't ever want to hear you using Greenboard again. DAP is much better for a bunch of reasons. The only guys using greenboard today are doing so because they don't know any better. Now, you do.
BTW, Home Dopey carries DAP from time to time but they don't carry DS, so just get both in one trip from the yard.
Greg Di is offline
Old 06-16-2006, 10:46 PM   #5
reveivl's Avatar
Trade: Renovations
Greg, do you need to skim the dap?
reveivl is offline
Old 06-17-2006, 10:10 AM   #6
Chief Toilet Mover
Update - didn't use the DS on the ceiling, I forgot we were building out the ceiling over the shower with a radius arched front using trimtex products and this was more a call for drywall because of the size of it.
Don't beat me to hard greg, but there is some green colored drywall up there.
Couple of things - HD here does carry DS, but not the DA+ at least not that I have been able to sniff out. Might be a local thing.
Absolutely correct. This one job using DS has sold me on it. I can't even begin to explain what a difference this stuff makes. Biggest thing I hated about the 1/2 hardi was it wasn't really 1/2 and I always ended up having to skim coat some thinset to even it out to the drywall thickness. DS is real 1/2 and matches up perfectly. Takes mud super nice too. Cutting, carrying and working with it is awesome.
Going to DS from Hardi is as nice a jump as was going from cement board to Hardi.
The only complaint I have is the 32" width. I really like the Hardi 3x5 size.
Old 06-17-2006, 05:54 PM   #7
The Deck Guy
Greg Di's Avatar
You used to always have to skim it so the seams wouldn't flash, but GP has smoothed out the fiber face a lot since it first came out. Now, it's not absolutely required, but if it's a small job, I'll do it since it's so easy.
Greg Di is offline
Old 06-17-2006, 05:56 PM   #8
The Deck Guy
Greg Di's Avatar
I know. It's the most assanine thing going. It requires another stud/blocking to make the joint.
I'm glad you're sold. Where's my commission?
Greg Di is offline
Old 06-17-2006, 11:05 PM   #9
Rich Turley's Avatar
Trade: Residential Remodel
I've only used DS three times, but all three times I got 4X8 sheets, just like drywall. I didn't even know 32" was an option.
Rich
Rich Turley is offline
Old 06-18-2006, 10:37 AM   #10
Chief Toilet Mover
Rich
4x8 would be a dream, 3 large pieces cut and the shower walls would be prepped. But what would my helper do with the extra 2 hours he saved?
Old 09-10-2006, 01:16 AM   #11
alter_ego's Avatar
Trade: General contractor
I tcomes in 4x8 and I think 4x10 or 12..... I saw some over 8ft on a buddies comm site........... DS is the bomb.....
Alter
alter_ego is offline
Old 03-05-2010, 07:39 PM   #12
hwinte's Avatar
Using densshield for the first time for a new shower enclosure (walls). Anyone know if it needs to have corners floated and screwholes filled prior to using mastick or thinset?
hwinte is offline
Old 03-05-2010, 11:14 PM   #13
bbgcarpentry's Avatar
Trade: carpenter
blue dry wall is ok if you using the orange waterproofing stuff kerdi or schulter is nt it???????????????????????????????????????
for the walls
bbgcarpentry is offline
Old 03-05-2010, 11:17 PM   #14
Its all ball bearings
angus242's Avatar
Trade: Tile
for the walls
As long as local building codes allow, you can use standard drywall behind Kerdi.
Good thing we have this in a 3 1/2 year old thread
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 03-05-2010, 11:18 PM   #15
I like Green things
WarnerConstInc.'s Avatar
I use DS a lot. Now I am going to switch to the orange stuff.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 03-05-2010, 11:19 PM   #16
I like Green things
Good eyes!!
Old 03-05-2010, 11:28 PM   #17
angus242's Avatar
Trade: Tile
Green and orange kool aid
Good eyes!!
Yeah, I usually don't miss a tile thread so if I don't recognize it, chances are it's an old one.
Angus
angus242 is offline
Old 03-17-2010, 10:40 AM   #18
Tile Contractor So Cal
CDC54's Avatar
Trade: C-54 Tile Contractor in Southern California
Schluter does recommend just the regular drywall behind Kerdi for the best bond. I need to check with my local codes too.
Chad From CDC54.com
Temecula Tile Contractor
Temecula - Murrieta - Fallbrook -
CDC54 is offline
Old 03-17-2010, 05:06 PM   #19
Kevin M.'s Avatar
I've used D.S. quite a bit for the last 15 or so years. It's pretty much bullet proof. (If installed correctly) I recently helped a friend on a job using cbu, seemed like a return to the stone age.
Kevin M. is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Question about bidding vinyl wallcovering kanadaeh Painting & Finish Work 9 02-19-2009 05:29 PM
DensShield & Americast Tub tommyboy4 Remodeling 4 02-24-2007 12:31 PM
