Deck Balluster Alternative?
Old 04-12-2009, 10:30 PM   #1
McC's Avatar
Trade: Beginner
Any reason why you can't install horizontal 1x6 or 1x4s instead of typical vertical ballusters?
McC is offline
Old 04-12-2009, 11:11 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Re: Deck Balluster Alternative?
Outside of aesthetics, the only rules are that they be able to handle 200 pounds of [sideways] force, and not have any spaces which would permit passage of a 4" diameter ball.
At least that's the rule in most of the US. Since you didn't mention where you are, I didn't bother looking up Lithuanian regulations.
Good idea to update your member profile with your location.
Tinstaafl is offline
Old 04-12-2009, 11:36 PM   #3
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thumbs down
Too dangerous! Little ones will use this as a ladder. Can't do in My area.
Driftwood is offline
Old 04-13-2009, 02:54 AM   #4
Stewy's Avatar
Trade: home improvements and renovations
Same here, code violation
Stewy is offline
Old 04-13-2009, 09:56 AM   #5
Chris G's Avatar
Trade: Porch and Deck Builder
You can as long as they are not deemed climbable. So no spaces.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 04-14-2009, 10:16 AM   #6
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Smile
No spaces? I call that a wall !
Old 04-14-2009, 10:43 AM   #7
So, no chinese chippendale?
neolitic is offline
Old 04-14-2009, 03:41 PM   #8
Grand Rapids Remodeling
Paulie's Avatar
Balusters cannot produce a ladder effect I think was how our code is written.
I've always wondered though what about the decks I see that people run their 1 x 4's to make a diamond shape. At what degree of angle that is considered climbable?
Paulie is offline
Old 05-05-2009, 03:14 PM   #9
sorethumbs's Avatar
Trade: carpentry
What about horizontal cable systems? Are they considered "climbable"?
sorethumbs is offline
Old 05-05-2009, 03:20 PM   #10
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
I've recently seen two very nicely built handicap ramps in front of houses. Both had about 4 horiz 1x6 on both sides. I would say there most likely was a permit for them. Any comments ?
Back to the original op - no can do here too, the ladder effect re: children.
We Fix Houses is offline
Old 05-05-2009, 03:27 PM   #11
BuiltByMAC's Avatar
Trade: Construction
Originally Posted by We Fix Houses View Post
Both had about 4 horiz 1x6 on both sides. Any comments ?
More than likely, they weren't 30" above grade so no code would apply to those handrails. Even if they were taller than 30", there are jurisdictions that don't have "climbable" in their wording, merely that a 4" sphere can't pass through and must resist 200 lb. side force.
Mac
BuiltByMAC is offline
Old 05-05-2009, 07:16 PM   #12
Mac
Don't know if it was code
or inspector, but it worked if
I put them on the outside of
the posts, and the handrail
to the inside.
Have done the that way since,
and no questions.
neolitic is offline
Old 05-05-2009, 07:42 PM   #13
Chris G's Avatar
Dude, they're handicap ramps. Climbing....?
Chris G is offline
The Following User Says Thank You to Chris G For This Useful Post:
john5mt (05-06-2009)
Tags
ballister, balluster, baluster, deck, railing
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 09:02 PM
rebuilding daughter's double deck jciotti7 General Discussion 1 02-24-2009 08:32 PM
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 11:59 PM
Looking for deck and fence builder - Chicago west suburb Green_2 Help Wanted or Looking For Work 0 09-07-2008 06:34 AM
