Remodeler Extraordinare
Darker Tile, Or Granite In Steam Rooms
Anyone have any past experience with darker color tile or granite in a steam shower? I am just curious if any hazing or discoloration is prevalent over time with the darker colors?
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor |
Re: Darker Tile, Or Granite In Steam Rooms
Also, has anyone ever installed the steam unit with a tub? The specs for Mr. Steam call for the manifold to be no higher than 6-12" above finished floor....with a tub the manifold is obviously well above 6-12"
Any thoughts?
Remodeling GC
The tile color shouldn't matter, are you using kerdi? I would call Mr. Steam we usually set ours at 10 inches off floor to fill from bottom up.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
#4 | |
Re: Darker Tile, Or Granite In Steam RoomsQuote:
I will definitely call Mr.Steam today. As far as the steam room, we will probably just sheetrock with regular 1/2" rock, apply bituthene over and then lath wire nailed to the studs with a mortar bed. My setters are old school and have never used the Kerdi on our remodels
#5 | |
bathroom guru
Your "old school" installation will work adequately for a shower, but a steam room?? Do they really coat drywall with bituthene then nail lath to it, therefore creating a lot of holes? I know you are going to tell me that "that's the way its been done for so and so years", but, that doesn't mean it is the best way. I realize that in different parts of the Country their are different prevelant installation methods, but I honestly can't believe installations are still done this way. Myself, concrete board, kerdi, and epoxy grout is my preferred installation method, but thats just me. Cheers! |
Remodeling GC
I use durock then kerdi in all my steamers.
I can discuss the Kerdi with my tile subs. Definitely not opposing it, if there is a better way I am all for it....we are a strong believer in overkill on certain things and most importantly doing things right.
You don't see many residential steam rooms here in Northern California. This one is for medicinal purposes of my client. Its all in the works right now. Lets get back on topic here and focus.
I like Green things
Medicinal puposes in northern cali?
Sounds like a vaporizor room. Sweet, I mean oh. |
#9 | |
bathroom guru
![]() lmao ![]()
bathroom guru
Re: Darker Tile, Or Granite In Steam RoomsYour question about dark tile, any porcelain should do the trick as well as the majority of granites - although with the variety today I think I would consult with the supplier on that one. The only thing I would stay away from would be certain species of marble, like green, for example. Are you using epoxy grout?? Your question about locating the steam outlet, I am wondering if locating it under the spout would be a good spot?? Or, depending on the type and style of tub, between the overflow and the top edge?? |
#11 | |
#12 | |
As far as grout we will definitely be using epoxy grout.
Remodeling GC
For code they will rely on manufacturer specs like how big of an access etc...
#14 | |
Chief Toilet Mover
Trade: Bathroom Remodeling
6 inches above the tub is fine. The 2nd criteria to the spacing is keeping the steam head at a minimum of 4 inches away from anything that might react to the head of the head (like an acrylic tub). Keep in mind the more important issue here is how you will plumb the steam line when you doing something different then the more normal shower only installation. Keep the fall of the line to the steam head in mind and keep it within the manufacturers recomendations such as not creating a steam trap and having the fall in the right direction. |
bathroom guru
Re: Darker Tile, Or Granite In Steam RoomsNice, just curious, are you using Laticrete Spectralock?? |
Trade: Interior finishes
Dark tile, especially the grout, in showers tend to show crud and soap scum alot more than lighter tile. Ive noticed this mainly on tiled shower pans that people never clean. If the homeowner dosen't mind cleaning it regularly it shouldnt be a problem.
#17 | |
#18 |
Trade: Remodel contractor
I can highly recommend schluter school. I went to Anaheim in Dec. Nice motel, great food, and drinks all on Mr. Schluter. I am now a believer. Schluter might say sheetrock would be an acceptable backer board with kerdi. I would use cement board and kerdi.
| Granite Tile Counter Top | fonteez | Ceramic & Stone Tile | 10 | 02-27-2009 11:07 PM |
| Granite Tile on Countertop Help!?! | spartiatis | Flooring | 3 | 02-14-2008 07:55 PM |
| Granite Tile on a Formica Countertop Please Help. | spartiatis | Ceramic & Stone Tile | 10 | 02-14-2008 07:52 PM |
| 3/4 Oak - meets - tile rooms with tile | ctbuilder | Flooring | 3 | 12-12-2007 10:37 PM |
| Granite Tile Countertops over Laminate | c5150b | Flooring | 5 | 04-05-2007 11:57 PM |
