Cutting Off Exterior Metal Door
Old 11-30-2008, 03:50 PM   #21
home-work
homework's Avatar
Trade: carpentry
Re: Cutting Off Exterior Metal Door
Originally Posted by Mcdonoughman View Post
I cut off the door w/ no problem. I do have a gap now between door and theshhold. I guess I will cut out threshold and raise it up some
I guess its a little late now but, I came across this problem before.Took off the interior trim from top off door, there was enough room in the rough opening to raise door, removed rest of trim and screws pryed door up, spaced up, resecured with new screws and shims. Re-insulated reinstall trim. Outside did have to bend a new piece of metal for a header that was above the door.
homework is offline
Old 11-30-2008, 04:06 PM   #22
Patrick's Avatar
Originally Posted by genecarp View Post
Who advised him to cut the door? His question was "how do i cut a metal door". not SHOULD i cut the door......
Additionally, if a fellow tradesman got himself in a pickle due to a mistake, why would you find that amusing ?
Cause you should notice the tiles gonna hit the door BEFORE you lay the tile NOT AFTER The proper solution would have been to raise the door not cut it.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-30-2008, 04:22 PM   #23
genecarp's Avatar
Who said he did not notice ? The proper solution would be to raise the door, {IN MOST CASES}. Maybe he was dealing with a brick exterior, maybe the client did not have the budget to remove and rehang the door. Not seeing the details, we can only answer, to the best of our abilities the questions that are asked. And again, even if the OP did make a mistake, what is about a mistake , that may end up costing a fellow tradesman money that you find amusing? G
genecarp is offline
Old 11-30-2008, 04:43 PM   #24
dlcj's Avatar
Trade: home builder carpenter Central Alabama
I was biding a tile job for a lady once and the first thing i looked at was the clearence under the door. Was not enough for hardie and tile. Then i looked to see if room to raise, not. Closer inspection resulted in tearing up 4 layers of flooring buy previous owners. Had plenty room after that.
I know thats not an answer just one of my similar experiences.
It shouldn't be to hard to shim up the threshold with some treated shims or ply
dlcj is offline
Old 12-04-2008, 01:27 PM   #25
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
sell em a new door
go dart is offline
Old 12-04-2008, 03:58 PM   #26
slowsol's Avatar
Trade: General Contracting
Originally Posted by Burby View Post
If only a reasonable margin, G is correct instead of cutting existing threshold and getting into to the problem of disturbing the moisture seal / pan flashing that should be below. You never did say how much had to be cut off door. Depending on how much build up you did as well as the height of bottom of door to start with. It could be only a 1/4" up to 1".
Let me explain a bit more. This don;t just pertain to doors, any construction project I reply to.
I probably suggest a bit more than some do, but is because of I work 2 different lines of work, I guess, would be a way of saying it. Not saying others are right or wrong and or depending on what your customers will or won't accept. Not that my way is better than any other, just based on over 30 years of my experience.
Because of doing litigation work as well as upper end Construction.
So many doors I have changed out, have been because with time, H/Os got tired of never having a scatter rug in front of their door to wipe feet when entering, no joke, I can;t count the number of doors for this reason alone. In brand new homes as well. So many doors are installed just a 1/2 inch or less above finished floor making it impossible to have a decent scatter or throw rug in front of the door. Even if the customer loved their new floor at first, with time this seemed to always be an issue I would hear when asked what I could do to change this. Or if I changed a door for one H/O not long after, I received calls from several of their friends asking me to do the same for them as they thought they had to live with this problem. Listen to customers complaints of other workers and one can develop a better company. Customers are what make our Companies what they end up being. The simplest things can offer you a Customer base to keep you working thru the hardest of times, cause if there is a house, there is work as with healthcare.
Equally so, (especially here in the Southeast), I have done so many repair jobs pertaining to wood decay to the band joist under doors that have been tampered with to make work and or improper flashing pans.
There are a lot of Contractors out here that are starting out & or growing and wanting to grow in ways to always better themselves & their Company.
In these trying times we are in, this will break a lot of Companies, come back in the next year and see how many are still here self employed.
So if I can offer anything to anyone I try. As any of you know, for as many that are here, there are that many different ways to do the same job.
Having worked in litigation for the years I did, I learnt so much, from mistakes of others, regardless of the reason. So if I can help others by passing on things that could better their company & lives in general, I try to. None of which has to be followed, it don't matter to me if laughed at or ignored, but to some they will give some consideration. Depending on their part of the country and or knowledge of Contractors being or have been drug into a law suit, or dealing with what they believe to be difficult customers, it just may help them.
I still work today because I love my work, always have. I could have stayed retired, but due to customers request I returned to work, but work limited, 4 day work weeks if that & only for customers that understand the work schedule I choose to have. Once in a while depending on circumstances I will take on a new customer if referred to me by a long standing customer.
I hope everyone of us survive thru this economic mess we are in, keep in mind we are just in the beginning of this mess.
Keep the glass half full & you will survive well
Man, do you guys actually read this guy's posts? Everyone of them is like 3 pages long.
-John
We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today.
slowsol is offline
Old 12-04-2008, 04:01 PM   #27
MFWIC
Tmrrptr's Avatar
Trade: house painter
You could shim the threshold up?
Tmrrptr is offline
Old 12-07-2008, 06:57 PM   #28
plazaman's Avatar
it happens alot of this forum. typical answers are leave it to the pro, or you should of hired a pro from start. i think many guys dont realize that are no 2 scenarios in construction are alike.
plazaman is online now
Old 02-03-2009, 06:09 PM   #29
Locknload's Avatar
Trade: General Contractor, res and com. design/build
Might not be the correct application here but ....I remember back in the early 70's we had hw flooring put down on a town house job and couldn't raise the door ( masonry siding ) so we cut the door and found a " auto adjustable threshold " that pop'd up and down when you opened or closed the door ...
I thought it was great at the time ..but .. I have never seen it since ...( maybe it wasnt as great as I thought ) ..
Locknload is offline
Old 02-03-2009, 06:32 PM   #30
Al Smith
A W Smith's Avatar
You mean an automatic door bottom? Ive seen an automatic door sweep that drops down when the door is fully closed. Never seen a threshold do that.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 05-25-2009, 11:16 PM   #31
fez-head's Avatar
Trade: Contractor/ Business Owner/ Entrepreneur
Cutting off the bottom of the door voids the manufacturers warranty
fez-head is offline
Door install hell - customer angry HellisLikeNewrk General Discussion 17 06-04-2008 10:40 AM
Cutting a hollowcore door MrRSBMHandyman Windows, Siding and Doors 36 04-22-2008 10:41 PM
Altering an interior hollow core door Painter James Windows, Siding and Doors 2 12-30-2007 07:24 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
