Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling
Old 03-25-2009, 10:52 PM   #1
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
Cut (trench) in Concrete
I'm turning an apartment, and when I removed the tub surround (because of water damage) found a 6" wide by about 4' long trench under the tub in the slab where they must have 'forgot' to fill after they 'forgot' to place a pipe in the slab. I believe it goes all the way down to dirt. Anyone got an idea how to fill it without pulling the tub too, what to fill it with (grout? foam?) or an opinion if it even needs filling? TIA
olyteddy is offline   Reply With Quote
Old 03-25-2009, 11:28 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Uh. To me, a "tub surround" consists of liner materials on the walls above the tub, to protect them from shower spray.
What pipe did they forget? The drain line?
If all of the plumbing is installed, intact and working properly, a bit of a hole under the tub is a complete non-issue, as long as it is supported properly and there are no cold air/insulation problems. But if you're worried about creepy-crawlies or whatever, just throw some mortar in to close it off.
Tinstaafl is offline   Reply With Quote
Old 03-26-2009, 12:01 AM   #3
Error Corrector
olyteddy's Avatar
Yeah, it looks like it was cut to place a missing drain line. It doesn't weaken the tub, but it does smell a bit musty. I guess I'll do what I can to close it off.
Old 03-26-2009, 08:38 PM   #4
PHB CONSTRUCTION LLC
paulie's Avatar
I don't get the part of the sentence (it was cut to place a missing drain line). Is that like, yes we have know bananas today?
If you can see it why is it a problem to fill it? A better question might be why spend the time to mess with it. If your flipping a apartment it's best not to spend time on non issue's. But that's just my opinion.
paulie is offline   Reply With Quote
The Following User Says Thank You to paulie For This Useful Post:
olyteddy (03-27-2009)
Old 03-26-2009, 08:41 PM   #5
mdshunk's Avatar
Let sleeping dogs lie. People rent nice carpet and a fresh paint job. Not filled trenches under tubs. Spend your money on the bling.
mdshunk is offline   Reply With Quote
The Following User Says Thank You to mdshunk For This Useful Post:
Old 03-26-2009, 09:00 PM   #6
paulie's Avatar
Couldn't have said it better myself.
Old 03-27-2009, 10:12 PM   #7
rock-it man's Avatar
Trade: Steel stud framer/ renovator
No banana's in Scrampton today!
rock-it man is offline   Reply With Quote
Old 03-28-2009, 04:13 PM   #8
Well, is the drain missing? Is it possible the trench was cut to make room for the drain?
boman47k is offline   Reply With Quote
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Kansas City Decorative Concrete - New Member ADC-Dustin Introductions 5 11-15-2008 10:24 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 08:10 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
