Cracking Cinder Block Walls
I recently bought a 1950's house in a neighborhood with shifting soil. It is slab with cinder block walls which are cracked. I can't afford to fix the foundation, and given the soil problem it may not be fixable, so I've decided on laminate floating flooring. The issue is what to do about the cracks in the walls. Is there a filler product that will expand and contract or should we panel or what other alternatives are there on a tight budget? Thanks, Kathy
Re: Cracking Cinder Block Walls
Stabilize the foundation first or your problems are just going to get worse, perhaps jeopardizing the structure.
There are a number of temp. patches but they will all seperate as the structure continues to settle. |
| Vinly Siding on Cinder Block? | Henry5 | Windows, Siding and Doors | 19 | 01-09-2010 06:07 PM |
| R-Value of cinder block | mdshunk | Construction | 39 | 03-10-2009 08:01 PM |
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| Hanging objects off cinder block walls | RobertCDF | Construction | 7 | 04-26-2007 10:07 AM |
