Commercial Kitchen Stainless
Old 02-01-2008, 09:13 AM   #1
kauser667's Avatar
Okay, I have a commercial restuarant remodel job that the owner wants stainless on the walls in the kitchen. My question is behind the hood/cook area how do you attach to the wall?
The walls are currently block... I can glue all the other areas but I am concerned that the heat will be to much and release the glue behind the hood/cook area.
kauser667 is offline
Old 02-04-2008, 11:31 AM   #2
Univ. of Hard Knocks
beachremodlr's Avatar
Trade: Renovations & Remodeling
Re: Commercial Kitchen Stainless
I worked for my father for about 10 years doing nothing but stainless fabrication and installs for restaurants, schools, and big cafeterias. Many times I have put stainless on walls behind grills, hoods, dishrooms and other areas. We always used a contact cement, roll on from DAP, or a spray on that comes in a cannester similar to a propane tank with its own sprayer. Never had any problem with heat but we would reinforce our glue bond on the perimeter of the sheets /w anchors. predrilled holes in the metal - tranfer hole location to the wall - drill wall - insert wall anchor - glue & install metal and install s/s screws w/ countersunk shaped s/s washers. Another option is to get some s/s trimming parts (similar to "j" channel for vinyl siding, but much lower profile) these attach to the wall and the metal edges will slide into the groove for a non-puncture application. Always glue
Knowledge is Power. Learning more about what I do, Is all in a days work!
beachremodlr is offline
Stainless Steel Kitchens pyrosg Remodeling 13 02-07-2008 03:49 AM
EPDM RUBBER pricing (commercial) tekwrytr Roofing 3 12-01-2007 09:33 PM
Hardwood in Kitchen MikeTheBuilder Flooring 16 11-16-2007 08:52 PM
Any help appreciated on first commercial bid painterman2007 Painting & Finish Work 7 09-12-2007 08:26 PM
stainless steel kitchen cabinets bergenbldr Finish Carpentry 5 11-07-2005 02:02 AM
