Chromed Rod Or Tubing For Detail.
I'm doing a remod in contemporary, not my style at all. In all of the shuffling around of walls, sliders, etc. we are stuck with a square support column in the middle of the living space. The designer wants to cover it in 1" glass tiles with round chrome corners to cover and protect the tile edges. The stock should be 3/8"+ in dia. and over 8' long. All that I'm finding is dimensionally ground and expensive, chrome over brass is what I'm thinking of but cannot locate smaller dims. Any ideas? No plastics, that idea went belly up before I finished my sentence.
Re: Chromed Rod Or Tubing For Detail.
Have you tried this site? Lots of choices, mostly stainless but stainless can be polished to a chrome appearance.
http://www.stainlesssteeltubing.biz/?source=overture My other recomendation would be to visit a machine shop. A good one should be able to get you anything you need. Good luck! Rob
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Trade: Renovation- Building
Teetor, Schluter makes quite a few corner details in all finishes. Check with your local high-end tile shop. They will be expensive and will most likely be special order.
| Pros/Cons Flex Line vs PVC for Waterfalls | Jacey | Plumbing | 15 | 08-17-2007 09:33 PM |
| Is it possible to repair P.E.X tubing? | Frankawitz | HVAC | 4 | 01-10-2007 02:32 PM |
| Pex tubing outside/underground | Woodcrafter74 | Plumbing | 18 | 12-07-2006 10:55 AM |
| Best Prices for Square tubing? | Schutter | Decks & Fencing | 2 | 04-11-2006 07:24 PM |
| a/c tubing | Unregistered | HVAC | 6 | 09-04-2004 03:57 PM |
