Cement Boarding Walls
Old 12-18-2006, 10:21 PM   #1
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
I have a small bathroom remodel that I will be starting next week and will be installing tile on the walls surrounding the tub. My question is, Is it acceptable to use a construction adhesive to glue the 1/2" cement board to the walls and use roofing nails to fasten it or should I stick with what Ive always done and use the cement board screws? I've seen a few tile guys on jobs use the roofing nails but Im not too sure about it? Just wondering if its worth saving the 10bucks for a small ass box of screws.
Eric K is offline
Old 12-18-2006, 11:53 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Cement Boarding Walls
It's to 'code' according to the CBU manufacturers.
I would dump that cement board and get yourself some DensShield instead. You'll be dumb-founded at the difference.
Mike Finley is offline
Old 12-19-2006, 12:04 AM   #3
Teetorbilt's Avatar
I use SS screws or nails in all potentially wet situations. How much extra does it cost to do a job right?
My Dad taught me to do the job right and screw the code. Code is the MINIMUM that you can do and pass inspection.
Build right and you will pass inspection.
Albert Einstein
Teetorbilt is offline
Old 12-19-2006, 08:49 PM   #4
phillytile's Avatar
Trade: Ceramic Tile and Marble
Contruction adhesive is fine for the walls and so are roofing nails. I usually use 1 1/4 or 1 1/2 nails depending on cement board thickness.
phillytile is offline
Old 12-19-2006, 09:55 PM   #5
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
I'll second that emotion
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 12-19-2006, 11:33 PM   #6
Interior Remodeling
Eric K's Avatar
What is DensShield? Is it that stuff that comes in a roll? I havent had much time today to do any real research on it online or supplyhouse wise. What makes it better? PROS / CONS?
Eric K is offline
Old 12-20-2006, 11:04 AM   #7
Chief Toilet Mover
It's similar to drywall. Cuts and installs identically to drywall. Has a water proof coating on it and ready to tile. As long as you tape and thinset the seams it's waterproof and fully warrantied. Home Depot even carries it.
Teetor you use SS screws for putting up CBU, but you don't care about grab rails having to be installed in studs? Don't see too much consistency in the thinking there. What's the thought process?
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
drywall mud over cement? mudgirl Construction 7 07-20-2007 08:27 PM
Cement Walls in a Plant YourWayPainting Painting & Finish Work 10 12-28-2006 09:25 AM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
