Ceiling Leveling
Old 06-14-2011, 04:54 AM   #1
rbn's Avatar
Trade: gen builder
Ceiling Leveling
I do a lot of renovations in old terraced houses. The ceilings invariably need leveling. After taking down the lathe and plaster it's a time consuming job of packing out individual joists to level. Does anyone have any advice/product advice on speedier ways of leveling a ceiling?
rbn is offline
Old 06-14-2011, 05:31 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,304
Re: Ceiling Leveling
String it up and pack it out
greg24k is offline
Old 06-14-2011, 07:32 AM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,145
-Paul
Sir Mixalot is offline
The Following 8 Users Say Thank You to Sir Mixalot For This Useful Post:
Anti-wingnut (06-14-2011), EmmCeeDee (08-14-2011), JustaFramer (09-29-2011), moorewarner (06-24-2011), thezoo (10-06-2011), TimelessQuality (06-14-2011), WarriorWithWood (06-26-2011), WildWill (08-15-2011)
Old 06-14-2011, 04:41 PM   #4
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
Originally Posted by Sir Mixalot
-Paul
Exactly. Rotating laser level works well also.
Eric K is offline
The Following User Says Thank You to Eric K For This Useful Post:
thomasjmarino (06-14-2011)
Old 06-14-2011, 11:00 PM   #5
Yep!
I have a DeWALT 18V Cordless Rotary Laser I use mostly for acoustical/grid ceilings.
-Paul
Ceiling leveling-003.jpg   Ceiling leveling-004.jpg   Ceiling leveling-005.jpg   Ceiling leveling-006.jpg   Ceiling leveling-007.jpg
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
Dirtywhiteboy (06-15-2011), fdbservices (06-15-2011)
Old 06-24-2011, 06:48 PM   #6
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
laser level is the key. sister up some 2x4's or 2x6's depending how bad it is and start nailing it up.
blackbear is offline
Old 06-26-2011, 04:28 PM   #7
plazaman's Avatar
Rewards Points: 1,202
^ Laser level is key... 2x4 and 2x6s
plazaman is offline
Old 07-05-2011, 07:17 AM   #8
Johnyeager's Avatar
Trade: General Home Improvements (specialize in kit & bat
Try sistering ceiling joist instead of packing down.
Use 2x4 or 2x6.
Www.yeagerskitchens.com
Johnyeager is offline
Old 07-10-2011, 08:18 PM   #9
bagtowall's Avatar
Trade: General Contracting
Rewards Points: 25
Use 2x4 or 2x6.
I'm with you fella, if its ceilings in old (usually small) terraced houses go for sistering and a spirit level.
bagtowall is offline
Old 08-14-2011, 11:58 PM   #10
Design/Build
EmmCeeDee's Avatar
Trade: Design/Build
Rewards Points: 660
We just did this a few weeks ago. The difference in the existing joists was like +/- 1/2", often in adjacent joists. We scabbed 2x4's on one side of each joist with a string running across the two ends and middle. A laser would have worked equally well. Sir Mixalot's steel studs would have worked even better than 2x4s.
What's a terraced home?
EmmCeeDee is offline
The Following User Says Thank You to EmmCeeDee For This Useful Post:
Sir Mixalot (08-16-2011)
Old 08-15-2011, 03:57 PM   #11
bagtowall's Avatar
Rewards Points: 25
Over here in uk a terraced home is either a long building sub divided into 3 or more homes seperated by either one brick thick wall or 4'' anti blast stud wall. They're historically low budget meaning the cheapest compliant materials, usully resulting in uneven ceilings.
Or a two storey home where the upper level is alot smaller than the lower level and the spare area is made into an outside 'living area'.
BTW loving the 'man in black' avatar. The best songwriter/performer ever to grace our planet!!!
The Following User Says Thank You to bagtowall For This Useful Post:
EmmCeeDee (08-16-2011)
Old 09-29-2011, 02:56 PM   #12
General Contractor NYC
nycgcinc's Avatar
i would say use metal 2x3's and drop down the ceiling?
NYC General Contractor
nycgcinc is offline
Cathedral Ceiling with false ceiling stubbs187 Insulation 4 12-25-2010 04:53 PM
FS: Armstrong Cortega 769a ceiling tile Little Contractor Swap 0 04-03-2010 10:37 AM
Leveling concrete floor with ceiling restriction J-Peffer Remodeling 8 01-11-2010 02:09 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 05:43 AM
leveling ceiling mas Remodeling 4 05-16-2006 10:08 PM
