Brick Removal To Reuse
Old 10-18-2009, 09:05 PM   #1
jakejorgenson's Avatar
Trade: GC/Carpentry
What is the best way to remove brick from a wall to re-use it on the addition? I have a project that has a full brick wall that they want to remove a section about 22' wide and 8' tall for a new opening and would like to try and re-use the brick for the addition to make it blend in better as a wainscot of brick. I've never had to remove brick as most remodels have been with stucco, wood siding, or some other exterior. Any suggestions? Thanks.
jakejorgenson is offline
Old 10-18-2009, 09:47 PM   #2
Sean
SLSTech's Avatar
Re: Brick Removal To Reuse
Carefully??? Seriously though - start at the top --- cold chisel & a hammer to the joint, one you get it going it comes down pretty easy
Stack it off to the side, and use the chisel to break the mortar off later by the new guy, on a rainy day, etc...
SLSTech is offline
Old 10-18-2009, 11:25 PM   #3
dkillianjr's Avatar
Yup thats the way I've done it in the past
dkillianjr is online now
Old 10-19-2009, 06:22 PM   #4
Warren's Avatar
Trade: framing/remodeling
Try an sds drill with a chisel attachment. Quicker than the other way and less wear and tear on your wrist. Start at top, work your way down. Just insert the chisel below each brick and the vibration causes them to raise up.
Warren is online now
Old 10-19-2009, 06:40 PM   #5
forsmant's Avatar
Trade: General Contracting, Remodeling
The new guys will love doing this, I know I did!
forsmant is offline
Old 10-21-2009, 05:24 AM   #6
Archania's Avatar
Trade: General Contractor, Electrician
I've done this before with an air chisel (when I was younger working for someone else)... half the bricks broke when I was trying to get the mortar off. Hopefully you you don't need too many of them to put back in there.
Archania is offline
Old 10-21-2009, 08:36 AM   #7
Sean
SLSTech's Avatar
you were using the wrong angle - as I recall it should be about a 15 to 25 degree angle, just like scraping a floor
SLSTech is offline
Old 10-21-2009, 09:06 AM   #8
SC sawdaddy's Avatar
Theres definitely a knack to getting them out without breaking them. It can be done but at the cost of some broken bricks for the learning curve.
You should use the cold chisel method as SLSTech described. There will be more control and less bats.
SC sawdaddy is offline
something for the masonry department dakzaag Masonry 2 05-08-2009 10:23 PM
Brick shelves dakzaag Masonry 28 03-30-2009 07:20 AM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
ICF brick ledge coupe33 General Discussion 7 11-29-2008 01:45 AM
Weight of brick removal Seab1209 Demolition 3 02-22-2008 01:18 PM
