Chief Toilet Mover
Trade: Bathroom Remodeling
Bond New Formica Over Old Formica Counter?
A customer called me today saying they burned a hole through their formica bathroom vanity with a candle. Can I bond new Formica over the old Formica or do you have to rip it all out and put in new substrate and then Formica on that as you would a new installation?
Re: Bond New Formica Over Old Formica Counter?
Mike, easy as pie.
Address the hole first, use a quick set epoxy to fill any low spots. I advise against bondo here. Sand the divot and any high spots level then sand the rest of the surface to break any gloss. Wipe with alcohol and procede like any other mica job. I resurface mica about every other month, have two jobs lined up right now. |
Chief Toilet Mover
Dat's what I figured. I was just going to fill the hole with some spackling and sand it, and the entire surface with 80 grit on an orbital, then rock on and collect a check.
Flooring Guru
Trade: Sales Manager
Don't forget to check for bubbles and loose spots.
I am sure you already know this.......
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Nix the spackle. You want to maintain a solid surface which is why I advised against bondo, too soft and could bubble in the future.
I usually use 60 grit, gives plenty of 'tooth'. You may want to approach corners/radii with a sanding block or inline sander to keep things flat and square. Orbitals on small surfaces tend to produce a crown. |
| Bond requirement for contractors license in CA | jgjrei | Contractor Licensing | 4 | 01-26-2009 09:04 PM |
| Formica Counter and Drop In Help | avimia | Remodeling | 6 | 04-29-2007 11:01 AM |
| formica repair | rservices | General Discussion | 13 | 12-03-2006 02:49 AM |
| painting formica | Alkyd | Painting & Finish Work | 12 | 06-27-2006 07:29 AM |
| Dust in counter top finish | SprayMan | Painting & Finish Work | 6 | 12-19-2005 08:06 PM |
