Bathroom Epoxy Paint
Old 01-06-2009, 10:02 PM   #1
PARENOS's Avatar
Trade: General Contractor and Radon Mitigation
I am about to start a new reno for myself. I am trying to find ways to cut some corners. The house is a 1300 sq ft ranch, with 3 beds and two baths. The one shared bath has a powder blue shower surround in it. It is in good shape, and the bathroom is very small. I would have to cut out the door to get the new surround into place. I have been looking at epoxy paint for fiberglass tubs. My local yard does not carry it, however the "associate" at HD said it works great. But I think I saw the same guy working at Walmart in the Deli earlier this month. Does anyone have any experience with these products. In all of my renos, I do a quality job, but this is also my money, and I need to try to trim some off of the budget. Is this an option?
PARENOS is offline
Old 01-07-2009, 12:24 AM   #2
General Contractor
jensenconstruction's Avatar
Trade: General Contracting and Painting
Re: Bathroom Epoxy Paint
The stuff they sell at Home Depot is junk, don't wast your time or money.
If you want to refinish your tub, find someone who specializes and have them do it. I have never seen a refinish job hold up for the long run. IMHO it's a temporary fix at best.
jensenconstruction is offline
Old 01-07-2009, 09:26 AM   #3
Pompass Ass
bwalley's Avatar
If you can't afford to do it right the 1st time, how will you find the money to do it the 2nd time?
bwalley is offline
Old 01-07-2009, 01:35 PM   #4
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
You could try Interlux perfection 2 part epoxy . The stuff gos on real good with just a roller ( Small foam roller 4"). Ive used it on my sail boat deck /nonskid and it looks good . This stuff is real tough and would last for years on a shower . My deck was done in 2000 and it still looks good . I would not attempt to spray the epoxy it would be a extreme health risk . All Grip 2 part epoxy is better but its much harder to work with , its not for the novice You can get it from jamestown marine supply or west marine. John I would drop in a new tub.
wellbuilthome is offline
Old 01-07-2009, 04:43 PM   #5
Bob Mariani's Avatar
Trade: electrical contractor; complete remodeling
To do this right you need an exhaust system to extract the fumes, a HVLP sprayer, good knowledge of spray painting and the correct materials. It is a lot of work. Anything you roll on or brush on or spray from a can will not last. A good refinishing will last the same as the finish on a new tub with proper care. Cost should be about 350 for a tub and 650 for tub and shower. About 8 different chemicals are used for the proper application.
Bob Mariani is offline
Old 01-22-2009, 08:23 PM   #6
bathroom guru
jarvis design's Avatar
I thought I would put my two cents in!!
I was involved in the bathtub reglazing industry for close to 18 years as well as doing bathroom renovations. I finally got out of it a couple of years ago because, as mentioned above, it simply will not last in the long run. I think the best you can do for a reglazed tub would be 7-10 years and that is if you baby it and make sure not to use any abrasive or harsh cleansers or drop something in it, etc.
And for those saying you can do it yourself?? I would say take a 4" roller and paint your car, then tell me what you think!! (seriously, it just isn't worth it - plus, unless you have the right ventilation and mask - you are going to burn out a lot of brain cells!!)
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-16-2008 12:44 AM
paint bubbles on door jambs moe2424 Painting & Finish Work 10 10-13-2008 10:05 PM
Roof paint Teetorbilt Roofing 3 05-07-2004 05:47 PM
