Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling
Old 08-19-2009, 08:15 AM   #1
FairfaxGC
fairfaxgc's Avatar
Basement Window in Attached Garage
Has anybody dealt with this issue?
We are designing an attached garage to replace the carport in the attached picture. The Ho wants to keep the basement windows and wells but local code requires all openings to be fire rated. The easy fix is to remove the windows and close them off; however, we would like to accomodate the client of possible.
We are planning a 4" high cement curb around the wells to prevent potential gas fumes from entering the wells.
fairfaxgc is offline   Reply With Quote
Old 08-19-2009, 08:32 AM   #2
JonM's Avatar
Glass block
JonM is offline   Reply With Quote
Old 08-19-2009, 09:01 AM   #3
DavidC
DavidC's Avatar
Start with why does the client want the window and what is the extra budget to cover costs.
Good Luck
OK, rant if you must. For the love of Pete, use paragraphs and spell check.
DavidC is offline   Reply With Quote
Old 08-19-2009, 09:13 AM   #4
FairfaxGC
fairfaxgc's Avatar
The extra cost is not an issue up to about $4-5K. The existing basement is only under half the house and is being used as a home office. This is the only window in that space.
When the basement was finished, they modern egress laws were not yet in place thus the standard sized (fixed) window was left as is. The owner is looking for an operable glider rather than the fixed. Before we steered him towards covering the window up, I wanted to exhaust my options.
Old 08-19-2009, 09:31 AM   #5
I presume from the photo that the door mat is sitting on the carport & that the garage will encompass both the concrete steps & the existing window.
If that's correct - what about relocating the window to the far side (where the plants are) - which would give them an egress window (which I assume is required by code for rooms that could be considered a bedroom) - which, as a selling point would allow the homeowner to advertise the house (when they sell) as having another bedroom - even though they use it as an office?
Leaving the window in place & opening into the new garage seems inefficient & will defeat their desire for natural light anyway...
Scott (the ex-grunt-tanker-jarhead guy)
Panzer5 is offline   Reply With Quote
Old 08-19-2009, 09:38 AM   #6
FairfaxGC
fairfaxgc's Avatar
Interesting idea. The new garage will extend 1' in front of the brick wall pictured. An egress well would hide nicely in the corner behind a bush.
Harvey "Tribute" window enforcer Windows, Siding and Doors 27 05-05-2009 07:12 AM
basement window with dryer vent hole dougchips Windows, Siding and Doors 6 02-26-2009 02:33 PM
Basement under garage TNRocks Construction 9 10-28-2007 09:28 AM
Open Basement Wall; Insert Window? Help, Please! bluethumbnail Framing 5 08-25-2006 11:45 AM
Window Problem pburchett Windows, Siding and Doors 5 05-30-2006 11:14 AM
