Basement Bath Insulation - Remodeling - Contractor Talk
Old 07-20-2017, 01:42 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,170
The bath was framed against a deeper garage floor wall (not an outer wall) near the center of the basement. That "garage wall" is actually poured about 10 inches behind the bath/plumbed wall framing.
It has been partly insulated with Craft paper insulation - Owens Corning R-13. Intend on putting it up on the remaining walls, ceiling and connected closet.
I don't see that a vapor barrier would give much help but on the plumbed wall, should this insulation be okay to use? Studs have all different spans. Any concern is with potential moisture coming from copper pipes.
artinall is online now
Old 07-20-2017, 06:14 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,607
Re: Basement Bath Insulation
If your concern is with condensation on the pipes (as opposed to leaking ), it makes all the sense in the world to have them surrounded with insulation and a vapor barrier. Insulation to help ensure that warm air doesn't get to them, and vapor barrier to hold back the extra moisture carried by warm air.
As long as you have no concerns about the pipes freezing in winter.
Tinstaafl is online now
Old 07-20-2017, 07:19 PM   #3
artinall's Avatar
It is a heated basement. Stays pretty much nice year round. That's why I like a bedroom in the basement.
Basement Walls and Insulation highpeaks Construction 6 07-21-2008 05:36 PM
Basement Wall Insulation robertc65 Insulation 5 03-10-2008 08:42 PM
Finishing Basement w/ Foil Faced Insulation orson Remodeling 0 03-10-2008 04:27 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
basement insulation bobcatnj Carpentry 9 01-03-2008 12:05 AM
