Baseboard To Metal Studs?
Old 06-01-2007, 06:52 PM   #1
MHMConstruction's Avatar
posted this in another section:
Baseboard to Metal Studs?
I'm running baseboard on a commercial remodel, and the new walls were all framed with metal studs/tracking.
what's the best way to fasten? I don't think my usual 2" finish nails in my little Porter Cable gun will do it.
or will it?
anyone?
MHM
MHMConstruction is offline
Old 06-01-2007, 07:30 PM   #2
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Re: Baseboard To Metal Studs?
a 15 gauge finish nailer might work. If not maybe trim head screws or construction adhesive.
In_Mexifornia is offline
Old 06-01-2007, 07:35 PM   #3
Fentoozler
Celtic's Avatar
Glue and shoot the nails at an angle...one this way / ; next this way \ .
Celtic is offline
Old 06-01-2007, 07:38 PM   #4
AtlanticWBConst's Avatar
Use trim head screws.
Links:
http://www.mcfeelys.com/screwlist.asp?sclass=tst
http://www.rockler.com/product.cfm?page=1355
It's industry standard...
- Build Well -
AtlanticWBConst is offline
Old 06-01-2007, 08:42 PM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
ET&F guns for steel studs and trim carpenters
Chris
Chris Johnson is online now
Old 06-01-2007, 09:00 PM   #6
C.C.R.'s Avatar
Trade: Remodeling contractor
That's the way to go. Construction adhesive and angle your nails. Don't aim for the studs just get the sheetrock. Thousands of feet of base never a problem
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline
Old 06-01-2007, 09:22 PM   #7
Fentoozler
Celtic's Avatar
That's comforting to know because I have only about 200' LF under my belt
Celtic is offline
Old 06-01-2007, 10:24 PM   #8
mdshunk's Avatar
Since I'm an electrician, people hardly ever ask me to install base trim. Good thing. Hard to say what it might look like.
mdshunk is offline
Old 06-01-2007, 10:38 PM   #9
send_it_all's Avatar
I use this method quite often, except instead of construction adhesive I use latex painters caulk. It's plenty strong and if it gets on the walls, you can actually remove it with a damp rag. Construction adhesive = not so easy to remove.
send_it_all is offline
Old 06-01-2007, 10:44 PM   #10
I actually ran a bunch of solid mahogany base at the Kodak Theater in Hollywood, where they hold the academy awards. They didnt want to see any fasteners, so we used a cleat on the wall with a 45* bevel screwed to the studs much like a hanging cleat for a wall cabinet. Then ripped the base with the opposing angle so it hooked onto the cleat. Then attached it with const. adhesive and carpenter's glue and used kickers held by a screw sticking out of a small hole in the ground to hold it until dry. It sucked out loud to do it that way, especially on curved walls.
Old 06-01-2007, 11:00 PM   #11
Fentoozler
Celtic's Avatar
I got mad skills
You know that....being an electrician is what I do between learning new trades.
Celtic is offline
Old 06-02-2007, 08:56 AM   #12
mickeyco's Avatar
Trade: Squirrel Handler
Construction adhesive, nails and carpenters glue on outside corners and dabs of hot melt glue every so many feet to act as a "clamp" while the construction adhesive is setting up, it stops the molding from pulling away from the wall or falling over.
mickeyco is offline
Old 06-02-2007, 07:30 PM   #13
Professional Remodeler
firemike's Avatar
I do mine the same way as Mickeyco, hot glue and construction adhesive (not a lot of adhesive, just enough to hold it on the wall) as you might be the one that has to take it off during the next remodel (been there, done that, learned the hard way!!!) Works like a charm and after a few pieces you get really quick at it too. Test fit the piece for flatness first, then you can see where you need the hot glue to hold it tight in the depressions.
I prefinish it when possible and only an occasional touch-up from a saw mark or scratch. No nail holes to worry about.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-02-2007, 07:33 PM   #14
Fentoozler
Celtic's Avatar
First...accept the FACT that I'm a total hack at carpentry ~ only do it at my own home....moving on...
Isn't that what caulk is for?
Celtic is offline
Old 06-02-2007, 07:45 PM   #15
firemike's Avatar
Originally Posted by Celtic;2on...
47290
Sooooo True!!!
It's also considerably cheaper than Chico for seal-offs!
-Mike-
Falcon Contracting
firemike is offline
Old 06-02-2007, 09:12 PM   #16
Fentoozler
Celtic's Avatar
You stay on your side of the yard and I'll stay on mine ...LMAO.
Celtic is offline
Old 06-02-2007, 09:53 PM   #17
Teetorbilt's Avatar
Y'all can bite! How about the guy that has to come in for the remod?
I do an estimate based on general construction methods and then find out that somebody has glued trim. Bad news for me and the HO.
Hit the base and the studs, let the caulk do the rest. Pretty p*ss poor but better than adhesive that can ruin a wall.
Albert Einstein
Teetorbilt is offline
Old 06-03-2007, 12:06 PM   #18
72chevy4x4's Avatar
commercial jobs I've come in behind have crewed the stained baseboard into the steel studs and filled and touched up the base. No adhesive on those jobs-I'm just reporting-but I did touch up in the same manner.
72chevy4x4 is offline
Framing with metal studs Rich Construction 39 12-16-2010 10:53 PM
Cabinets mounted to metal studs dayspring Finish Carpentry 3 06-14-2007 10:03 PM
Baseboard to Metal Studs? MHMConstruction Finish Carpentry 8 06-07-2007 10:57 PM
Metal Studs Vs. Wood Studs Towatei & Co. Drywall 7 05-12-2007 11:03 PM
